 Old 01-08-2014, 07:20 AM   #1
h0rsies's Avatar
Posts: 133   (View Stats)
h0rsies has a reputation beyond reputeh0rsies has a reputation beyond reputeh0rsies has a reputation beyond reputeh0rsies has a reputation beyond reputeh0rsies has a reputation beyond reputeh0rsies has a reputation beyond reputeh0rsies has a reputation beyond reputeh0rsies has a reputation beyond reputeh0rsies has a reputation beyond reputeh0rsies has a reputation beyond reputeh0rsies has a reputation beyond repute
Default Oil stick assembly
While taking off the intake manifold, I accidentally disconnected the entire oil stick assembly from the oil pan. I have attached a photo so nervy one can see where it is disconnected. I just jammed it back in but it seems to wiggle around and there is a small rubber gasket that is destroyed. Any idea how to safely reassemble this so it won't pop out again? Thanks for the help.
atp 2871r, cobb ap,front mount, devils own stage 2 meth,hks ssqv, pg exhaust manifold,port/polished intake mani,intake mani spacer,dnp exhaust electrical cutout,cobb dp, custom exhaust, cpe sri intake,cpe tip, cpe hdfp, turbosmart manual boost controller,itv 22,greddy occ,cpe injector seals, cobb front/rear sways,dominant E rear camber arms,awr endlinks,su front mount, tower bar, drilled slotted rotars/hawk pads
h0rsies is offline   Reply With Quote
 Old 01-08-2014, 12:48 PM   #2
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
It's held in by a bolt on the intake manifold. There should be a tab on the dipstick tube up there.
-06 MS6
-Corn fed 07 MS3 - Sold
silvapain (01-08-2014)
 Old 01-09-2014, 07:29 AM   #3
h0rsies's Avatar
Thanks for the reply. I know what you mean but I was wondering if I have to replace the rubber gasket that seems to have been destroyed where the tube enters the block.
 Old 01-09-2014, 10:01 AM   #4
Eth Fiend
phate's Avatar
I think I would. Mazda part # 9XG0-12-610 - $7.93 MSRP. Or just find an oring that fits, lol.
-06 MS6
h0rsies (01-09-2014)
Leaking oil Dip Stick MS3 RussM MazdaSpeed 3 - Engine, Transmission & Driveline 11 02-28-2017 01:51 PM
CX-7 hit with the ugly stick mikomi CX-7 > General Lounge + New Member Welcome 9 12-10-2010 08:08 PM
DIP STICK BLOWED OUT johnnyspeed6 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 20 12-06-2010 12:22 PM
Dip Stick Blowing Out...? AutoXRacer MazdaSpeed 3 - Engine, Transmission & Driveline 58 01-18-2009 09:52 AM
Page generated in 0.24940 seconds with 22 queries
