Like Tree20Likes
 Old 06-29-2013, 08:07 PM   #1
Captain KR's Avatar
Posts: 2,320   (View Stats)
Captain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the world
Groans: 391
Groaned at 75 Times in 49 Posts
Default purple drank oil pressure woes
so i noticed i have a small leak around my ofh (oil filter housing) i started investigating because i obviously cannot go back to the track dripping oil. I've always noticed that i have had higher than normal oil pressure but somehow i had convinced myself that my excessive cc pressure was causing the issue...... wrong obviously! So I'm wondering what everyone else oil pressure is who has a built motor and maybe if there is some sort of remedy to this issue or something that i have over-looked.....
idle 50 psi
cruising 75-80 psi
wot 100+
I've been through 2 sensors to test and have an genpu ofh with an sandwich plate running Mobil1 15w50
also i have recently pulled my oil pan off and inspected my oil pickup for clogs blah blah and it is complete and healthy
moore automitive 4/13/13 515whp 511 tq
Mason Dixon Raceway 11.289 @125 1.845 60'
Killah Built
Powered By Purple Drank
Last edited by Captain KR; 06-29-2013 at 08:07 PM. Reason: MSF Database - Automerged Doublepost
Captain KR is offline   Reply With Quote
The Following 7 Users Say Thank You to Captain KR For This Useful Post:
BlueStreak (07-03-2013), djuosnteisn (07-01-2013), redboat (04-07-2014), rfinkle2 (07-03-2013), silvapain (07-01-2013), SilverDemon (06-30-2013), SPEED6 KILLAH (07-01-2013)
 Old 06-29-2013, 08:41 PM   #2
Will, higher weight oil does increase oil pressure. Also, high volume oil pumps do the same because generally they pump about 20% more oil through the engine. When using a stock pump, it works harder to pump thicker oil resulting in increased pressure. However this doesn't always hold true.
To keep pressure inline with new engines using thicker oil, it's been recommended by my experience with several engine builders to switch to a larger oil pan and high volume oil pump.
The Following 7 Users Say Thank You to Haltech For This Useful Post:
Captain KR (06-29-2013), Downmented (07-04-2013), helmetface (06-29-2013), Micha (07-02-2013), MonstaSpeed6 (06-30-2013), redboat (04-07-2014), silvapain (07-01-2013)
 Old 06-29-2013, 08:46 PM   #3
Captain KR's Avatar
Groans: 391
Will, higher weight oil does increase oil pressure. Also, high volume oil pumps do the same because generally they pump about 20% more oil through the engine. When using a stock pump, it works harder to pump thicker oil resulting in increases pressure.
I had close to the same oil pressure issues when i was running rotella (yesterday) sorry i should have mentioned that in my op and i realizes a thicker oil will bring up pressure but i am pegging that gauge at wot so that is the one thing that is kinda worrying me
Killah Built
 Old 06-29-2013, 08:51 PM   #4
So you are seeing oil squeezing from the oil filter location because of the high oil pressure? You may be at risk of blowing your rear main seal if you aren't careful. I've personally never had oil pressure that high before.
I'd be looking at the ofh as the source... Those sandwich adapters are shit and without screens at the fitting locations can lead to clogging.
Captain KR (06-29-2013), redboat (04-07-2014)
 Old 06-29-2013, 08:53 PM   #5
Captain KR's Avatar
Groans: 391
yea i get seep from multiple locations at the oil filter housing...... around the housing itself where the gasket meets the block and at the bridge of the seal of the oil filter
Killah Built
 Old 06-29-2013, 08:54 PM   #6
Pull it out along with the sandwich. I believe this may be the cause of your problem.
 Old 06-29-2013, 09:10 PM   #7
Captain KR's Avatar
Groans: 391
There is no doubt and issue i'm just confused how lets say a blockage could cause higher oil pressure...... i would think it would lower the pressure? Regardless it is coming off i'm just trying to get my nigga mind working before i got fucking shit up and tearing shit apart
Killah Built
 Old 06-29-2013, 09:28 PM   #8
Outlaw4shrt's Avatar
Posts: 751   (View Stats)
Outlaw4shrt is the leader of the worldOutlaw4shrt is the leader of the worldOutlaw4shrt is the leader of the worldOutlaw4shrt is the leader of the worldOutlaw4shrt is the leader of the worldOutlaw4shrt is the leader of the worldOutlaw4shrt is the leader of the worldOutlaw4shrt is the leader of the worldOutlaw4shrt is the leader of the worldOutlaw4shrt is the leader of the worldOutlaw4shrt is the leader of the world
not sure if this helps or not, but before my engine let go and was running healthy, my oil pressure was at about 100psi at start up, and then would drop to about 60 psi cruising and 80 psi at WOT. It might dip down to as low as 40 psi at idle IIRC.
EDIT: I did have a tiny weep from my sandwich plate as well.
2006 TGM MS6
Cobb AP w/ SELFtune // Split Second AIC1-V4H // Stratified Guardian Angel // Stratified Boost Dial // ATP GTX3071r IWG // Devils Own Stage 1 WMI // JMF v2 Intake Manifold // 4 x Siemens DEKA IV 60 lph Injectors // Outlaw4shrt In-Tank Fuel Pump Kit w/ 255 lph pump // CP-E CDFP // CP-E SAFEseals // Clutchmasters 350 & flywheel // CX Racing FMIC // HTP 3.5" Intake // 3.5 Bar MAP // Cobb EBCS // Forge BPV v1 // XS Power Exhaust Manifold // M2 Downpipe w/ Highflow Cat // Corksport 80mm CBE // Blackworks Racing VTA OCC // NGK +1's // JBR EGR delete // Speedy 17x7.5 Lite Fin's w/ Hankook Ventus V2 225/50/R17 // TooLateTuning Springs // Bilstein B6 HD Shocks // Whiteline RSB // SPC Adjustable Ball Joints // Airlift 1000 "Drag Bags" // JBR 80 duro RMM // JBR 80 duro TMM // JBR 80 duro PMM // CP-E RDM // Turbine Tech FDM // OEM Spin-On Oil Filter Conversion // Prosport Oil Pressure and Oil Temp Gauge with Oil Filter Adapter Plate, Boost and EGT Gauges // AEM UEGO Wideband O2 & Fuel Pressure Gauges // Block8head MS6 dual 52mm vent pod // Lotek triple 52mm gauge pod // Prosport EVO Single Gauge Pod // Cobb Knob // Corksport LED Kit // Corksport LED Fogs // LED Tails // Audi LED DRL's
2008 MazdaSpeed 3 - R.I.P. 1/3/13
- from ENM 2014
well actually, if you count the number of holes you'll see we have just enough
Outlaw4shrt is offline   Reply With Quote
The Following User Says Thank You to Outlaw4shrt For This Useful Post:
 Old 06-29-2013, 09:31 PM   #9
Captain KR's Avatar
Groans: 391
nigga dont say that -___-
Killah Built
The Following 2 Users Say Thank You to Captain KR For This Useful Post:
AZSPEED3 (06-30-2013), xI Leveler Ix (06-30-2013)
 Old 06-29-2013, 09:33 PM   #10
BobtailedSnail's Avatar
Posts: 1,375   (View Stats)
If the pump can achieve the same flow rate then a smaller orifice would mean more pressure is required. However it could also be skewed by wherever the oil pressure sensor is placed (before or after the restriction). Just throwing ideas
Skreets be calling...
The Following 3 Users Say Thank You to BobtailedSnail For This Useful Post:
Captain KR (06-29-2013), djuosnteisn (07-01-2013), Easter Bunny (06-30-2013)
 Old 06-29-2013, 09:49 PM   #11
I don't know man. I was surprised too at the pressure when I first put the gauge on. I wouldn't go tearing into anything yet until you have a guess at what your baseline should be.
EDIT: what were your pressures before? or did you just put the gauge on?
2006 TGM MS6
- from ENM 2014
 Old 06-29-2013, 09:56 PM   #12
crtguns's Avatar
Posts: 464   (View Stats)
crtguns is the leader of the worldcrtguns is the leader of the worldcrtguns is the leader of the worldcrtguns is the leader of the worldcrtguns is the leader of the worldcrtguns is the leader of the worldcrtguns is the leader of the worldcrtguns is the leader of the worldcrtguns is the leader of the worldcrtguns is the leader of the worldcrtguns is the leader of the world
Groaned at 340 Times in 107 Posts
Daft Punk will fuck your car up.
It might make it go faster sometimes.
Captain KR likes this.
crtguns is offline   Reply With Quote
The Following 4 Users Say Thank You to crtguns For This Useful Post:
Captain KR (06-29-2013), Downmented (07-04-2013), helmetface (06-30-2013), silvapain (07-01-2013)
The Following User Says NO Thank You to crtguns For This Un-useful Post:
Tokay444 (07-01-2013)
 Old 06-29-2013, 10:04 PM   #13
qtrmile beast's Avatar
Posts: 2,423   (View Stats)
I using royal purple 5w30 right now and i my pressure is about 30-35 at idle and i think about 80 at wot... I will get a video soon of a cold start until it warms and then a could of runs so that you can see....
track weight 3220
street weight 3370
The Following 2 Users Say Thank You to qtrmile beast For This Useful Post:
Captain KR (06-29-2013), drknyte (06-30-2013)
 Old 06-29-2013, 10:08 PM   #14
Captain KR's Avatar
Groans: 391
the pressure has always been there
Killah Built
The Following User Says Thank You to Captain KR For This Useful Post:
Outlaw4shrt (06-29-2013)
 Old 06-30-2013, 02:02 AM   #15
Nishan
ms3blackmica's Avatar
Posts: 5,635   (View Stats)
@NJSPEED3;
www.tunedbynishan.com
atvfreek (06-30-2013), Captain KR (06-30-2013)
 Old 06-30-2013, 06:30 AM   #16
atvfreek's Avatar
Posts: 7,787   (View Stats)
@Dano; what do you see for pressure?
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
 Old 06-30-2013, 09:06 AM   #17
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
Im with Kevin, toss the sammich plate. They are not designed for the oil flow that our engine has. When I did my remote oil cooler/filter I did the filter solely because no available sammich plate has 1/2" or larger ID orifices throughout, they all neck down somewhere or are too small to begin with.
2006 Mazdaspeed 6
The Following 4 Users Say Thank You to 06Speed6 For This Useful Post:
atvfreek (06-30-2013), Captain KR (06-30-2013), SLOWHATCH (06-30-2013), Tokay444 (07-01-2013)
 Old 06-30-2013, 09:13 AM   #18
Sid3wayS's Avatar
Posts: 6,790   (View Stats)
Groans: 97
So not to take away from this thread and start a new topic but what would then be recommended vs the sandwhich plate?
TEAM LUXURY
The Following 2 Users Say Thank You to Sid3wayS For This Useful Post:
Captain KR (06-30-2013), Monotonous ONE (06-30-2013)
 Old 06-30-2013, 09:31 AM   #19
Captain KR's Avatar
Groans: 391
@MATT DAMOND;
something along the lines of this probably DM | Oil Pressure Sensor Adaptors
Sid3wayS likes this.
Killah Built
 Old 06-30-2013, 10:21 AM   #20
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
I'll have to double check but its fairly high. Prosport Sammich plate
10-40 oil
90PSI cold Idle but would need to check the rest.
I may do some tuning today and can check.
 Old 06-30-2013, 11:44 AM   #21
Captain KR's Avatar
Groans: 391
@Downmented; @SIXual Panda; @superskaterxes; @SPEED6 KILLAH;
@djuosnteisn; @rfinkle2; @SilverDemon;
I got a couple things that i am going to try the housing is coming off and getting inspected, i'm going to remove the sandwich plate and see how my oil pressure responds
Killah Built
Last edited by Captain KR; 06-30-2013 at 11:44 AM. Reason: MSF Database - Automerged Doublepost
The Following 3 Users Say Thank You to Captain KR For This Useful Post:
djuosnteisn (07-01-2013), Downmented (06-30-2013), SilverDemon (06-30-2013)
 Old 06-30-2013, 11:49 AM   #22
alphasaur's Avatar
Posts: 2,847   (View Stats)
Groans: 235
Restrictions increase pressure but decrease overall flow (unless pressure is increased enough to compensate)
Think of fat/cholesterol accumulating in vascular tissue, blood pressure goes up.
100% kind of unrelated, but my miata is about 30psi at idle 60 psi wot lolol.
/Turbo ep3 BWAAAAA PSH
/speed 3- bye
/lol nator.
The Following User Says Thank You to alphasaur For This Useful Post:
 Old 06-30-2013, 11:50 AM   #23
Captain KR's Avatar
Groans: 391
Originally Posted by alphasaur View Post
Restrictions increase pressure but decrease overall flow.
Think of fat accumulating in vascular tissue, blood pressure goes up.
did you just say chicken?
Tokay444 likes this.
Killah Built
Downmented (07-04-2013), Tokay444 (07-01-2013)
 Old 06-30-2013, 11:53 AM   #24
alphasaur's Avatar
Groans: 235
fried?
/speed 3- bye
/lol nator.
 Old 06-30-2013, 11:56 AM   #25
Captain KR's Avatar
Groans: 391
fried?
only way to cook it
alphasaur likes this.
Killah Built
Easter Bunny (06-30-2013), Micha (07-02-2013)
 Old 06-30-2013, 12:00 PM   #26
alphasaur's Avatar
Groans: 235
only way to cook it
bitch can cook idgaf what she says.
/speed 3- bye
/lol nator.
The Following 4 Users Say Thank You to alphasaur For This Useful Post:
Captain KR (06-30-2013), Downmented (07-04-2013), Easter Bunny (07-01-2013), Micha (07-02-2013)
 Old 06-30-2013, 12:03 PM   #27
Captain KR's Avatar
Groans: 391
i would let her call me a nigga on live tv for a goo and tasty meal
Killah Built
The Following 5 Users Say Thank You to Captain KR For This Useful Post:
alphasaur (06-30-2013), AZSPEED3 (07-01-2013), Easter Bunny (07-01-2013), Micha (07-02-2013), Tokay444 (07-01-2013)
 Old 06-30-2013, 12:13 PM   #28
Downmented's Avatar
Posts: 3,040   (View Stats)
Groans: 493
Subbed for possible fucks to give later, right now i have no fucks to give for your nigga problems!
700HP CLUB
11.479@124mph
#DIX
The Following 2 Users Say Thank You to Downmented For This Useful Post:
BobtailedSnail (07-01-2013), redboat (04-07-2014)
 Old 06-30-2013, 12:32 PM   #29
Captain KR's Avatar
Groans: 391
im hungry
Killah Built
 Old 06-30-2013, 01:57 PM   #30
SilverDemon's Avatar
Posts: 3,034   (View Stats)
On my prosport gauge (recall function) it has maxed out at 100 psi, but I am not sure when that happens. I mean does that kind of pressure show up during a WOT run, or does show up when I am moderately accelerating when the engine oil is not quite up to temp.
I have the gauge set to alert me when it goes below 20PSI, but I do not have a way to alert me when it goes high. Shit happens too quick on a wot run to be staring at a little gauge...lol! I need a passenger to watch it for me, or I guess I could figure out a way to set my gopro up to watch it.
EDIT:
I forgot to mention, I do not have a sammich plate. I threaded a fitting into the stock port and "T"ed from that fitting to adapt the OEM sending unit and then the prosport sending unit.
rfinkle2 and Captain KR like this.
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
The Following 6 Users Say Thank You to SilverDemon For This Useful Post:
06Speed6 (07-02-2013), Dano (06-30-2013), Downmented (06-30-2013), Easter Bunny (07-01-2013), ms3blackmica (07-01-2013), qtrmile beast (07-01-2013)
 Old 06-30-2013, 02:10 PM   #31
Trail of Fail
Dano's Avatar
EDIT:
I have the "halo" series which might be what you have. I let the car reach temp then reset the recall function the make a run. Then you know the max is either WOT or close
I wanted to tee off the oem port but i was rushing and the plate was easy. If the consensus is they are bad then ill make the switch
Do you have a source for the parts you used?
Tappin
 Old 06-30-2013, 02:13 PM   #32
nothing to see here....
drknyte's Avatar
Posts: 501   (View Stats)
drknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the world
Groans: 39
Groaned at 43 Times in 18 Posts
Identical specs as me except I have a 3 not a 6. On a cold start it is above 100 at idle.
2008 Mazdaspeed 3 GT in Black Mica:
60ft: 2.167
1/8: 9.052
1/4: 13.922 @ 100.37
(26psi tire pressure & stock tires)
CP-E CAI; CP-E Turbo Inlet Pipe; CP-E RMM; Engals ETD; TRZ TM; PG ExhMani; JBarone Shifter Weight, E4 Performance Shift Knob; Solid Shifter bushings; JBarone SSP
drknyte is offline   Reply With Quote
 Old 06-30-2013, 02:31 PM   #33
Those are some insanely high oil pressures. Will, are you seeing any blow by or catching large amounts of oil in your CC at all? I'm quite curious how these high pressures are affecting your pcv setup.
** Edit **
So I've been cruising some scoobie forums and other assorted rice... Seems that 80-100 psi is not unusual. I'd just address the leak and remove that sandwich plate. No reason why you can't tee off the original sensor like Dano did.
The Following 4 Users Say Thank You to Haltech For This Useful Post:
atvfreek (06-30-2013), BobtailedSnail (07-01-2013), Downmented (06-30-2013), redboat (04-07-2014)
 Old 06-30-2013, 02:43 PM   #34
Nishan
I'd say go with the T Will.
TBH, that is what I will do myself.
 Old 06-30-2013, 03:30 PM   #35
Tappin
No, I do not have a parts list of the fittings. That was one of the first things I did to the car back in '07. It's not hard to figure out, a couple of street ells a close nipple and a "t" Everything is 1/8" npt. You might have to work at getting everything clocked correctly.
One more thing to take into consideration, if brass is used, be extremely careful not to over tighten the fittings, or you will hate your life.
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
Last edited by SilverDemon; 07-02-2013 at 02:30 PM. Reason: wrong size mentioned on the fittings
The Following 3 Users Say Thank You to SilverDemon For This Useful Post:
06Speed6 (07-02-2013), Dano (06-30-2013), ms3blackmica (07-01-2013)
 Old 06-30-2013, 04:00 PM   #36
Trail of Fail
Dano's Avatar
what are you trying to say...I'm lazy or stupid...or both
so it IS 1/8" NPT...I figured the OEM port was metric.
that will give me a place to start.
The OEM sender looks bigger than my Prosport sender for sure. I'll figure it out.
Captain KR (06-30-2013), SilverDemon (06-30-2013)
 Old 06-30-2013, 04:03 PM   #37
Hahahaha!!! I would never say that about you! I am on my phone right now, i might have some pics of the assembly on my computer. If not, I am do for an oil change soon so I can snap some pics then.
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
The Following 5 Users Say Thank You to SilverDemon For This Useful Post:
atvfreek (06-30-2013), Captain KR (06-30-2013), Dano (06-30-2013), Easter Bunny (07-01-2013), taf0422 (07-01-2013)
 Old 07-01-2013, 12:37 AM   #38
** Edit **
I believe blow by was a concern for him.
 Old 07-01-2013, 07:26 AM   #39
SPEED6 KILLAH's Avatar
Posts: 1,176   (View Stats)
I took look at the video you post WILL just have a few questions .
1: What is your coolant temps like?
2: what is your rpm set at Idle?
3: what side did you install the oil pressure sensor at?
4: what year did you get the oil housing from?
I also seen you posted up that you have small leak around oil filter housing filter housing did you replace the gasket and clean the surface area really good?
NOTE:
The oil pressure can vary with oil viscosity and temperature.
Oil pressure (reference value) [oil temperature: 100 °C {212 °F}]
43.1—79.9 psi} [3,000 rpm
WILL if you look at the video you posted when you rev to at 2500rpm you oil pressure at 76psi its really hard to tell with that gauge.
SPEED6 KILLAH is offline   Reply With Quote
The Following 10 Users Say Thank You to SPEED6 KILLAH For This Useful Post:
06Speed6 (07-02-2013), Agent_Orange (09-14-2013), atvfreek (07-01-2013), Captain KR (07-01-2013), Downmented (07-01-2013), Micha (07-02-2013), qtrmile beast (07-01-2013), rfinkle2 (07-03-2013), RichieRichness (07-02-2013), taf0422 (07-01-2013)
 Old 07-01-2013, 10:49 AM   #40
So as i am on my way out to the runs i decided i would make these vids for you and it was with my blackberry so sorry for the shaky video kind of hard to hold it straight when the boost comes on so i had to slow the boost down..
Idle oil pressure just starting the car...
Cruising pressure
Cruising a few minute after warm up
Cruising at about 60 sorry i stated 80 in the vid but the speedo said different!!
Had to turn the boost down and slow the ramp speed to get a clear video of WOT..
Hope this helps a little... As i started before i am running royal purple oil with the spin on filter and on this change i used a 5w 30 oil..
track weight 3220
street weight 3370
The Following 9 Users Say Thank You to qtrmile beast For This Useful Post:
06Speed6 (07-02-2013), Captain KR (07-01-2013), Easter Bunny (07-01-2013), Micha (07-02-2013), ms6ms6 (07-02-2013), Realgib3 (07-03-2013), SilverDemon (07-01-2013), SPEED6 KILLAH (07-01-2013), taf0422 (07-01-2013)
Page generated in 0.65012 seconds with 35 queries
