| Banned ![]() Join Date: Mar 2011
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 15
Groaned at 9 Times in 7 Posts
(Thread Starter) | Not Ranked : 0 score On street unit there is a brace (no mount upgrades?) Front mount, rear mount Rear bushings (reuse the stock mount?) from TT CPE rear diff mount So....is it enough to just upgrade the bushings? Would that be the same as say, the CPE mount? Thanks! |
| The Following User Says NO Thank You to oh_yeams6 For This Un-useful Post: | manelscout4life (09-26-2011) |
| Not Ranked : 0 score Search is your friend. This dead horse has been beaten to a pulp. Dont get just bushings, they are nearly worthless. The street unit rear mount and the AWR front mount is a good upgrade.
![]() Join Date: Apr 2008 Location: STL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 727
| Not Ranked : 0 score I'm running a cpe upper rear and a turbinetech forward mount. It is pretty solid back there. Bushings alone aren't worth it by any means.
__________________ '06 Mazdaspeed6 GT - Titanium Gray - ATP 3076r - CP-e XCel Intake - CP-e FMIC - CP-e 4" TIP - COBB AccessPORT - Medieval EWG Manifold - Tial 44mm EWG - ATP Downpipe - Custom 3" Dual Magnaflow CBE - JBR EGR Block Off - HKS SSQV BPV - mrlilguyCDFP (KMDv1) - Denso ITV-22 Plugs - F2 BSD & Baffle - CP-e Upper Rear Diff Mount - TurbineTech Forward Rear Diff Mount - TurbineTech Front Motor Mount - AWR Rear Motor Mount - Tanabe Strut Tower Brace - Technafit SS Clutch Line - RPM Sport Springs .75/1.1 - TWM Stage 2 SS w/bushings - COBB Shift Weight - Défi-Link BF Boost Gauge - Innovate LC-1 Wideband - Hardwired Passport 8500 X50 - AuxMod Basic for CarPC - |
| 2zz mr-s ![]() Join Date: Nov 2010 Location: katy, tx
Rep Power: 3483 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
Groans: 239
| Not Ranked : 0 score some advice, if you decide to do the rear diff mount, you might as well buy a rsb too, since they both require about the same type of work to install
__________________ [07:25 PM] Pu Manchu: the second rule is "don't tell anyone" [07:25 PM] Pu Manchu: the first rule of tranny fucking is "don't do it" |
| The Following User Says Thank You to dooderek For This Useful Post: | xfeejayx (09-27-2011) |
| The Following User Says NO Thank You to dooderek For This Un-useful Post: | manelscout4life (09-26-2011) |
(Thread Starter) | Not Ranked : 0 score What does a rear mount offer that the bushings won't? So, a front mount would be needed in addition to the rear then...interesting |
| Not Ranked : 0 score The metal of the rear mount stress cracks and they is how they fail.
![]() Join Date: Jul 2008 Location: Tucson, AZ
Rep Power: 739 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 517
lots of us run just the top mount and it works fine.
__________________ JDMFresh.com 1990 Mazda Miata NASA Time Trials/Time Attack, Global Time Attack A miata may be gay, but its probably faster than your car around a track. That's pretty gay. | |
| The Following 3 Users Say Thank You to jroc For This Useful Post: |
(Thread Starter) | Not Ranked : 0 score Is the CPE mount the "top" mount? I really don't want to drop 500 on two mounts if I don't have to. If the one mount is enough, such as the CPE or sure Dreadnaught or SU StiffDiff...it would be nice |
![]() Join Date: Mar 2011 Location: Saddle Brook, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,589
Groans: 92
| Not Ranked : 0 score sure motorsports has upgraded diff mounts
__________________ KILLAH BUILT PTE 5862 @29psi JMF MANI METH TUNED BY NISHAN 11.54@123 What does your new map trap |
![]() Join Date: Jul 2011 Location: Santa Fe, NM
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9
| Not Ranked : 0 score just buy both SURE juggernaught and SURE dreadnaught whoever tells you that you only need the lower rear dif brace also called the dreadnaught is an idiot! do both and you wont have to worry about ever needing to replace them again and your launches will be cherry!
__________________ [SIGPIC][/SIGPIC] 1992 miata, track beast here I come with 2 bride seats!! (current)3076r speed6 owner (traded) 2000 camaro 415rwhp thru midwest chassis fab (sold) |
| The Following User Says NO Thank You to ColonR For This Un-useful Post: | xfeejayx (09-27-2011) |
![]() ![]() Join Date: Jun 2010 Location: Morton Grove, il
Rep Power: 1485 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16,886
Groans: 78
| Not Ranked : 0 score I'm running the dread only. I was amazed how much more solid the setup felt with just the top mount upgrade. have launched as high as 6k no problems. get the top mount first. if you can swing it, get both.
__________________ "Well, Racecar=Broke. Other kinds of awesome may not, but racecar does. But racecar=best kind of awesome." -Wetz QFT |
(Thread Starter) | Not Ranked : 0 score Would you think that a "thunk" noise upon shifting (most of time) from the rear (sounds like that area), could be failed mounts on the diff? I know the epic "thump launch" is a diff issue... |
| Not Ranked : 0 score On my car it was the trans mount, but I think the rear diff was on its way out as well because I replaced the diff mounts first and it reduced the chunk sound.
| Rear diff locks while turning after SURE diff mount and brace install | wettoast | MazdaSpeed 6 - Engine, Transmission & Driveline | 47 | 11-04-2018 04:50 PM |
| Rear diff mount and rear sway bar | bcmps | MazdaSpeed 6 - Engine, Transmission & Driveline | 16 | 03-25-2014 06:33 PM |
| Rear or Front rear diff mount? | Its2realj | Mazdaspeed3/6 General Discussion | 0 | 06-05-2011 08:45 PM |
| rear diff "stiff diff" brace vs. rear diff front mount | giordanos4 | MazdaSpeed 6 - Engine, Transmission & Driveline | 18 | 03-03-2011 08:38 AM |
