![]() Join Date: Jun 2010 Location: Hartford, CT
Rep Power: 0 ![]() ![]() ![]() Thanks: 57
Groaned at 14 Times in 8 Posts
(Thread Starter) | Not Ranked : 0 score Dont have the money for both, searched both and both look like great upgrades. was wondering if any one had an opinion on which one to get if i can only get one. is one more needed/beneficial for the other. current mods - ht tune, cai, tip, tp, tmic if i do more upgrades it will prob only be a cb and or dyno tune w a ap. - not sure if that would make a diff in which mount to get thx in advance for you opinions/advice |
![]() Join Date: Nov 2010 Location: Lancaster, PA
Rep Power: 1111 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,516
Groans: 56
| Not Ranked : 0 score *most* people only get the front diff mount. and that is *usually* sufficient.. unless you are qrtermile beast and have the front turbine tech mount and still snap the rear one. but in all honesty, the front one is the one to get. im assuming you wont be busting out 1.6 60' times so you will be fine. |
| The Following 2 Users Say Thank You to SIXual Panda For This Useful Post: | Docnox (03-02-2011), giordanos4 (03-02-2011) |
![]() Join Date: Mar 2008 Location: Pittsburgh, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,174
Groans: 45
| Not Ranked : 0 score why not get the front one and just get bushings for the rear one, they aren't expensive from turbine tech. i've been running that combo for 3 years now without any problems. |
| The Following User Says Thank You to bova For This Useful Post: | giordanos4 (03-02-2011) |
(Thread Starter) | Not Ranked : 0 score I just saw the bushings on SU website, If I buy those they fit right into the stock part? If so I would prob get the front mount + those. I also see a lot about the rear motor mount. But I remember looking @ it with 60k miles on the car and it looked great (maybe the previous owner replaced it bc i bought the car used)so I am hesitant to buy a new one if the stock one isnt as bad as everyone says. I was pretty suprised to see it in such good shape especially with the way i drive and the few mods i have. do yous guys have a rmm? |
Groans: 56
ahhhh rear motor mount. if it is stock. which you can tell just by looking at it if it isnt (it will most likely be machined and not a cast mount) then replace it with either the cp-e, streetunit, or i think SURE makes one too.. it doesnt matter if it "looks good" the stock rmm is garbage and then thank me later. its not just replacing it with it stiffer mount blah blah blah, it literally makes the drivability of the speed6 so much better. saves those harsh 1-2 shifts, you dont feel the engine move as much when you tap the gas or shift quickly. it is money well spent. | |
| The Following 2 Users Say Thank You to SIXual Panda For This Useful Post: | Docnox (03-20-2011), giordanos4 (03-02-2011) |
![]() Join Date: Mar 2009 Location: Portlandia, Oregano
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,295
Groans: 196
| Not Ranked : 0 score Ever seen a the upper rear diff mount snap? It's not from the bushings...
__________________ |
| The Following 2 Users Say Thank You to triplejumper18 For This Useful Post: | MarkyMark (03-02-2011), SIXual Panda (03-02-2011) |
Groans: 45
| Not Ranked : 0 score It actually is from the bushings, if you look how terrible they are they allow way to much movement causing it to snap. the new bushings don't allow it to move at all. |
| The Following User Says Thank You to bova For This Useful Post: | gigs2000 (03-02-2011) |
(Thread Starter) | Not Ranked : 0 score yeah the busings looked awful in a print out from turbine tech. i think ill stick with the frotn mount and brace bushings. thanks for the info whatcha think about the rear motor mount? |
Groans: 45
| Not Ranked : 0 score rear motor mount is good for getting rid of the engine movement that causes hard shifting. |
Groans: 45
| Not Ranked : 0 score also look into the AWR rear mount, i have the 88 durometer one and the vibrations it add really aren't that bad or even felt, and basically not noticeable if you have a AP and can up your idle. |
(Thread Starter) | Not Ranked : 0 score when i say it looked good i just meant the bushing wasnt torn on it or anything it. the car drives harsh so i guess even a stock non ripped one sucks. i really dont want any vibes @ all its my daily driver so i was looking to get the soft or normal duro rated one. i would like nice smooth shifting though. |
Groans: 45
| Not Ranked : 0 score it's my daily driver to and i notice nothing and no one else that rides with me notices it either, the only thing they say is my exhaust is loud when you are in the back seat. |
| The Following User Says Thank You to bova For This Useful Post: | SIXual Panda (03-02-2011) |
Groans: 56
| Not Ranked : 0 score yeah, i have the CP-e rmm, and really, you could kinda tell for about a week or so that it was stiffer, but still its not like it vibrates everything. then after that, it broke in a little bit and you really dont even notice it at all. if anything, my exhaust causes more vibrations than my motor mounts do. hahaha |
| Not Ranked : 0 score forget the front diff mount. has anyone heard of a failure of the front one? no get the stiff diff and be done with it. those are the bushings that are hollow and allow all the movement.
| The Following 2 Users Say Thank You to superskaterxes For This Useful Post: | Jedyboyrokr (03-03-2011), MarkyMark (03-02-2011) |
![]() Join Date: Mar 2010 Location: Colorado Springs, CO, USA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,160
Groans: 201
| Not Ranked : 0 score Ugh, here's the deal. Front MOUNT doesn't fail. Front mount BOLTS fail. They fail because the dumbasses at Mazda only attached that mount to ONE side of the diff casing and did so with non-grade series bolts. However, grade series bolts might crack the aluminum casing, so the BEST option is to get a front mount that has additional connection points, like the Turbine Tech or the upcoming (soon) SURE Juggernaught. The front mount prevents twisting and side-to-side movement of the diff, but plays a limited role in power delivery to the wheels. The TOP MOUNT (rear diff rear mount, same thing) is the primary power-bearing mount, and it actually breaks. The arms themselves AND the connecting bolts shear. The cheap ass bushings allow so much movement that SOMETHING has to give, and the mount itself is shit-cheap, so usually the arm goes. I highly recommend doing both mounts, but if one is going to break, it's MUCH better for the front mount bolts to shear. Mine did, and I was still able to drive (lightly, like a grandma) until I replaced them, which was easy as cake and cheap ($36 for the replacement bolts from Mazda). However, if the top mount breaks just right, you could lose your whole damn diff and axles. And as qtrmile beast found out, if just one arm or a bolt goes, you'll bog every launch. IMHO, do both. I am. As soon as the Jugg is in, both are going on my car, and I won't launch hard until they're on. It's worth the money to lose the headache and worries. As far as an RMM, its primary purpose in the MS6 is to reduce motor movement that results in shift thump during hard shifting. It also puts power to the wheels more effectively, but is not nearly as crucial as the diff mounts IMHO.
__________________ Stealth01 2006 Mazdaspeed6 GT Black Cherry Mica, Two-tone Leather interior, Sunroof, Bose SURE Full3 Aeros ID300 | SURE Shortcut | SURE Countershift | SURE Anchors | SURE AGS Atom Shift Knob | SURE Torque R6 RMM | SURE Ventus in Hybrid Mode | SURE Dreadnaught | SURE Juggernaught | SURE Flow M6 TP | SURE Charge Tubes | SURE Return | SURE S6 Side Motor Mounts | SURE Breather Line | Hawk HPS F/R Brake Pads | StopTech F/R Rotors | Technafit SS BL | Technafit SS Clutch Line | Primewell PZ900 Tires (blech) | Red LED Dome & Door Lights | O-series Stubby Antenna | Cobb AP | ACT 6 Puck Clutch w/Prolite FW | Autolite XP Plugs (One Step Colder) | Whistler Pro-78SE Hard-wired | STRATIFIED Tuned by Lex | COMING SOON: Autotechs | SURE TIG Read my stories: https://www.smashwords.com/books/view/55318 Last edited by Stealth01; 03-02-2011 at 10:23 AM. |
| The Following User Says Thank You to Stealth01 For This Useful Post: | MarkyMark (03-02-2011) |
(Thread Starter) | Not Ranked : 0 score why are you waiting on the new mount to come out is it cheaper than the turbine tech? |
| The Following User Says Thank You to giordanos4 For This Useful Post: | MarkyMark (03-02-2011) |
Groans: 201
| Not Ranked : 0 score Yes. By $100.
__________________ Stealth01 2006 Mazdaspeed6 GT Black Cherry Mica, Two-tone Leather interior, Sunroof, Bose SURE Full3 Aeros ID300 | SURE Shortcut | SURE Countershift | SURE Anchors | SURE AGS Atom Shift Knob | SURE Torque R6 RMM | SURE Ventus in Hybrid Mode | SURE Dreadnaught | SURE Juggernaught | SURE Flow M6 TP | SURE Charge Tubes | SURE Return | SURE S6 Side Motor Mounts | SURE Breather Line | Hawk HPS F/R Brake Pads | StopTech F/R Rotors | Technafit SS BL | Technafit SS Clutch Line | Primewell PZ900 Tires (blech) | Red LED Dome & Door Lights | O-series Stubby Antenna | Cobb AP | ACT 6 Puck Clutch w/Prolite FW | Autolite XP Plugs (One Step Colder) | Whistler Pro-78SE Hard-wired | STRATIFIED Tuned by Lex | COMING SOON: Autotechs | SURE TIG Read my stories: https://www.smashwords.com/books/view/55318 |
(Thread Starter) | Not Ranked : 0 score when is it comming out? |
![]() | | #19 | ![]() |
Groans: 201
| The Following User Says Thank You to Stealth01 For This Useful Post: | giordanos4 (03-03-2011) |
| HOW-TO: Replace Rear Diff Front Mount Bolts | Stealth01 | MazdaSpeed 6 - How-To's | 14 | 05-11-2011 11:28 AM |
| rear diff front mount probs | laocas01 | MazdaSpeed 6 - Engine, Transmission & Driveline | 12 | 01-29-2010 12:36 AM |
