 Old 07-23-2019, 02:41 PM   #1
-Six-'s Avatar
Posts: 14   (View Stats)
-Six- has a little shameless behaviour in the past
Default Rear differential coupler question
Anyone know of a way to test the rear differential coupler? I have my diff apart, replacing the coupler casing because it cracked (new front mount will be part of this when done). I noticed signs of excessive heat on the input shaft and some tarnishing on one side of it.
Now I'm not sure if these things are due to it driving briefly with a wonky cracked case, or a deeper failure in the coupler itself. Had no DTC prior to pulling it, but is there any other tests/indications I might be able to use?
-Six- is offline   Reply With Quote
 Old 07-24-2019, 10:05 AM   #2
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
Looks pretty normal. I'd reuse it.
Sent from my SM-G960U using Tapatalk
-06 MS6
-Corn fed 07 MS3 - Sold
-Six- (07-24-2019)
 Old 07-24-2019, 09:02 PM   #3
-Six-'s Avatar
It seemed ok in operation too, ohmed it out and it's within spec too, just made me a little paranoid. One weird thing @phate, the output shaft bolts were finger tight! Like easily loosened by hand! I know you've probably had these apart before, have you come across that too?
Intake coupler question Boostman07 MazdaSpeed 3/6 - Turbo Induction 3 04-28-2012 02:40 PM
Rear differential coupler timjs MazdaSpeed 6 - Engine, Transmission & Driveline 4 01-25-2012 10:29 AM
Coupler Question N|njutsu55 MazdaSpeed 3/6 - Turbo Induction 2 11-02-2009 02:32 PM
Page generated in 0.24453 seconds with 22 queries
