 Old 10-01-2019, 08:00 PM   #1
Whitebullet's Avatar
Posts: 24   (View Stats)
Whitebullet has a little shameless behaviour in the past
Default Shift resistance
I found similar threads but not the same.
New slave, Southbend Stage 2, Fomoco trans fluid.
I get resistance shifting into R 1,2,3, less as gears go higher. I bleed the slave each time the resistance subsides for a few days then comes back. With bleeding there is dark oil, about 3 to 4 ounces, that i bleed to somewhat clear. I blead all the brakes to clear all the old oil out of the system. What else can i do or check?
May be a unrelated issue but i have to smash the clutch into the carpet, maybe the How To Clutch Adjust would help this. Slave seems to move the fork about a half inch.
TIA
06 MS6 GT
SP63 Stage 1, bnr s3, hpfp, cai, cs tmic, southbend stage 2, E30 tune
Whitebullet is offline   Reply With Quote
 Old 10-02-2019, 06:25 AM   #2
Jeff23spl's Avatar
Posts: 2,233   (View Stats)
Sorry to ask but just to make it clear ? fomoco oil was poored into the trans not the brake tank right ?
when parked not running is the shifter work ok ?
If pedal goes to the floor it indicate master/slave problems or something with the fork vs clutch kit. Was it a brand new kit with a new flywheel where the fw height is set to match the disk and pp height ?
Have you checked if the pedal isn't craked ? i did read about some issue with speed 6 where an heavier pp is too much for the pedal linkage
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 10-02-2019, 06:32 AM   #3
Fomoco oul in the trans
Still slightly notchy when parked and engine off
It’s a new oem fork with a new clutch/smf kit
Thanks
06 MS6 GT
 Old 10-02-2019, 07:51 AM   #4
shamie's Avatar
Posts: 952   (View Stats)
new throw out bearing?
 Old 10-02-2019, 08:11 AM   #5
Yep new tob
06 MS6 GT
 Old 10-02-2019, 10:38 AM   #6
Db09ms3's Avatar
Posts: 536   (View Stats)
Is the slave OEM Mazda? Might need to check the clutch pedal bracket underneath the dash.
Stockish
 Old 10-02-2019, 10:45 AM   #7
It is a Perfection Clutch slave from Rock Auto. I don’t see any leaks from it.
Will check under dash for cracks in the peddle assembly or firewall
06 MS6 GT
 Old 10-02-2019, 11:16 AM   #8
Db09ms3's Avatar
I'd hate to say to spend more money but try purchasing the OEM Mazda slave for this car.
Granted I have a speed3 but the importance may apply to the 6's.
But.
Stockish
The Following User Says Thank You to Db09ms3 For This Useful Post:
Whitebullet (10-02-2019)
 Old 10-02-2019, 11:21 AM   #9
But.
Probably a good idea.
What are signs of a bad master clutch cylinder?
06 MS6 GT
Gears have major resistance at WOT bova MazdaSpeed 6 - Engine, Transmission & Driveline 30 03-29-2011 05:48 AM
Need some heat resistance for PG Mani BreakTheStatic MazdaSpeed 3 - Engine, Transmission & Driveline 16 01-16-2009 08:43 AM
Low-rolling resistance tires going mainstream Haltech Automotive News 0 07-14-2008 05:00 PM
Page generated in 0.29507 seconds with 23 queries
