 Old 04-02-2010, 01:18 PM   #1
boostntomuch's Avatar
Posts: 99   (View Stats)
boostntomuch is a name known to allboostntomuch is a name known to allboostntomuch is a name known to allboostntomuch is a name known to allboostntomuch is a name known to allboostntomuch is a name known to all
Groaned at 19 Times in 12 Posts
Default spark plugs
i tried to search but couldn't get a clear answer. i have a 07 ms6 with intake and BOV and motor mounts. i want to change my spark plugs but i don't know what kind will be the best choice and what should the gap be set at? help a newbie out. part numbers will help. corksport downpipe is on order too.
boostntomuch is offline   Reply With Quote
 Old 04-02-2010, 01:20 PM   #2
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
this thread should help you a ton - http://www.mazdaspeedforum.org/forum/foru...ge-1-2-a-5692/
 Old 04-02-2010, 01:45 PM   #3
Spoolme's Avatar
Posts: 1,041   (View Stats)
Spoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the world
Groans: 54
looks like Philly has taken care of you. Stick with the stock and remember to check the gap before installing.
Parting out!
http://www.mazdaspeedforum.org/forum/forum/f229/spoolme-parting-out-76016/
Spoolme is offline   Reply With Quote
 Old 04-07-2010, 07:21 AM   #4
dagrimey1's Avatar
Posts: 1,246   (View Stats)
Default Go Stock
NGK Laser Iridium Spark Plugs
Applications: MAZDASPEED 6, MAZDASPEED 3 (OE Replacement)
Part Number: 3787, ILTR6A-8G
Gap: .032" gap
Thread Size: 14mm
Reach: 26.5mm
Heat Range: 5
 Old 04-29-2010, 04:20 PM   #5
nosaccordh22's Avatar
Posts: 30   (View Stats)
nosaccordh22 is a jewel in the roughnosaccordh22 is a jewel in the roughnosaccordh22 is a jewel in the roughnosaccordh22 is a jewel in the rough
Groaned at 7 Times in 4 Posts
agreed, no reason to go with a different temp plug OEM will work
nosaccordh22 is offline   Reply With Quote
 Old 05-03-2010, 03:26 PM   #6
amoosenamedhank's Avatar
Posts: 1,368   (View Stats)
amoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the world
Groans: 53
Groaned at 31 Times in 22 Posts
I guess what I'm also wondering is what what point people are noticing the plugs are running too hot? In that linked thread a bunch of people ask the question but no one seems to answer it. There is obviously a certain point where the colder plugs are necessary.. so what is that point?
amoosenamedhank is offline   Reply With Quote
 Old 05-03-2010, 03:34 PM   #7
pewpew
Sacrilicious's Avatar
Posts: 2,452   (View Stats)
Groaned at 9 Times in 9 Posts
1 step colder plugs are needed if you run higher boost than the stock 15.6psi. if you're running stock boost levels, don't bother getting colder plugs, because all it's going to do is foul faster. i would recommend just getting another set of the stockers...they work just fine.
btw...is there a particular reason you want to change the plugs? have you checked them out to see if they actually need changing? how many miles do you have on your car?
Sacrilicious is offline   Reply With Quote
 Old 05-03-2010, 04:01 PM   #8
Groans: 53
No No I get all of that.. I'm wondering, roughly, at what point are people see the stock temp range plugs running hot. Obviously the stock plugs temp plugs work fine for a stock car... but at what point are those plugs looking too warm?
 Old 05-03-2010, 04:20 PM   #9
pewpew
well, since people have trouble running cobb stage 1 OTS maps without colder plugs, then it looks like 17-18 psi is already too high. so from the looks of it, just 2-3 psi is enough to require colder plugs, so unless you run a very conservatively retuned cobb map or SB tune, you're going to need an upgrade.
The Following User Says Thank You to Sacrilicious For This Useful Post:
amoosenamedhank (05-03-2010)
spark plugs bombdotcom MazdaSpeed 3 - Engine, Transmission & Driveline 1 02-23-2010 04:46 AM
How do my spark plugs look? SgtP MazdaSpeed 3 - Engine, Transmission & Driveline 9 07-17-2009 12:01 AM
E3 spark plugs MS3Zoom24 MazdaSpeed 6 - Engine, Transmission & Driveline 7 06-07-2009 03:35 PM
spark plugs speedster 3 Mazdaspeed3/6 General Discussion 32 10-22-2008 06:01 PM
Are these spark plugs ok? Meder MazdaSpeed 3 - Engine, Transmission & Driveline 8 10-09-2008 12:21 PM
Page generated in 0.29382 seconds with 26 queries
