  • 1 Post By bcmurphy87
 Old 01-19-2011, 05:29 PM   #1
Jarods7920's Avatar
Posts: 1,415   (View Stats)
Default Speed 6 and Cx7 transfer case the same?
I have been looking at pictures and they look exactly the same? Does anyone know for sure if that are.
 Old 01-19-2011, 06:02 PM   #2
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
Supposidly they are not the same. I have a extra cx-7 tcase that I picked up for $200 from a very nice lady that was kicking her old man to the curb and selling his shit on ebay. They both look the same to me, both of the cases have the same part numbers inside as far as I can tell but the part numbers for the entire case is different.
2006 Mazdaspeed 6
 Old 01-19-2011, 08:15 PM   #3
Jarods7920's Avatar
Ya, i figured they wouldnt have the same part numbers, but they look very similar. The only thing i would think is that the gearing in the inside may be a bit different.
 Old 01-19-2011, 08:46 PM   #4
Speeeeeed
06Speed6's Avatar
Both the manual and automatic trans cx-7 have identical part numbers except for the entire assembly. The ms6 has the same the same parts as far as I can tell, except for the entire case, what bugs me is that with the ms6 there seems to be an interchange where some of the tcase part numbers were updated from XXXXXXA to XXXXXXB or XXXXXXC etc and I assume the part is basically materially the same except for some small update that doesnt change its bolt on compatibility.
I suppose that there is a chance that if you swap to one updated part, it requires all of the updated parts to function properly.
The cx-7, from what I can see, has all of the updated numbers and it doesnt even list the old ms6 numbers. The ms6 lists all the cx-7 numbers along with some alphbetically earlier part numbers.
I know for a fact that the ms6 case was updated and I assume a alphabetically later part number was issued to set it appart from the leaking cases. If that is the case, then all the cx-7s should use the updated case.
The case part numbers for the cx-7 Auto are:
LN0327500B 1 AN (LN03-27-500C) - 071001
ER*9** -109304
LN0327500D 1 071001 -
ER*9**109304-
cx-7 Manual are:
LN0527500
ms6 is:
LN0127500L 1 AN (LN01-27-500M) - 060501
GG1*** -663315
LN0127500N 1 AN (LN01-27-500P) 060501 - 070201
GG1***663315-703890
LN0127500P 1 070201 -
GG1***703890-
2006 Mazdaspeed 6
The Following 2 Users Say Thank You to 06Speed6 For This Useful Post:
djuosnteisn (09-11-2012), Docnox (01-21-2011)
 Old 01-20-2011, 09:42 AM   #5
Jarods7920's Avatar
Well i suppose soon enough we will know if these items will mix and match well. I am using a speed 6 transfer case and a cx7 rear end. There has to be a way to find out what the gearing for each individual box is. Front and rear for both vehicles.
 Old 01-20-2011, 10:55 AM   #6
Speeeeeed
06Speed6's Avatar
I almost bet the ms6 rear diff gear ratio is 1:1, but I havent checked.
2006 Mazdaspeed 6
 Old 01-20-2011, 11:36 AM   #7
qtrmile beast's Avatar
Posts: 2,423   (View Stats)
The transfercase and gears are the same but where you hook the drive shaft up is TOTALLY different. When i found out that my transfercase was cracked we had a cx7 in the shop and i was matching up the cases and they were the same except for those things. Also you can't pull the part where the driveshaft hooks up at off on the cx7 one but you can on the mazdaspeed6. think i have pics somewhere i'll look for them...
track weight 3220
street weight 3370
The Following 2 Users Say Thank You to qtrmile beast For This Useful Post:
06Speed6 (01-20-2011), psychophyr (01-20-2011)
 Old 01-20-2011, 11:19 PM   #8
Speeeeeed
06Speed6's Avatar
I have a cx-7 case and the driveshaft flange is removable, the case looks the same to me.
2006 Mazdaspeed 6
 Old 01-20-2011, 11:26 PM   #9
paveltol's Avatar
Posts: 520   (View Stats)
paveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the world
Groaned at 23 Times in 2 Posts
They are the same! One of my friends is driving a cx7 transfer case for a couple of months already.. It just took him to change the driveshaft flange or do some other minor work to fit the 6.
paveltol is offline   Reply With Quote
The Following 2 Users Say Thank You to paveltol For This Useful Post:
06Speed6 (01-21-2011), Jarods7920 (01-21-2011)
 Old 01-21-2011, 09:32 AM   #10
How did you remove it then as there is no bolt in the center like the speed6 as it looks like it was riveted on ? do you have pics the transfer cases?
track weight 3220
street weight 3370
 Old 01-21-2011, 01:26 AM   #11
Speeeeeed
06Speed6's Avatar
I kinda thought so, wonder what exactly he did to the driveshaft.
2006 Mazdaspeed 6
 Old 01-21-2011, 06:10 AM   #12
Jarods7920's Avatar
That is good news for sure! I found a new t case and rear end for 600 bucks!
 Old 01-22-2011, 09:20 PM   #13
Speeeeeed
06Speed6's Avatar
I dont have pics handy. I didnt take it off.
2006 Mazdaspeed 6
 Old 09-11-2012, 06:21 PM   #14
bcmurphy87's Avatar
Posts: 1,435   (View Stats)
what was the outcome of this. It seems my transfer case drain bolt fell out and i need a new one.
06 Speed6 GT- Sold
 Old 09-11-2012, 06:34 PM   #15
Mistersix's Avatar
Posts: 2,585   (View Stats)
+1 to that. Subbing for possible results. I'm ready to fix my weeping transfer case.
 Old 09-12-2012, 10:29 AM   #16
Jarods7920's Avatar
the stub shafts are what make them different it think, unless the gear drive is different inside.
 Old 09-25-2012, 06:14 PM   #17
bcmurphy87's Avatar
Hey guys you can use a cx7 case all day. I bought a used low low mileage cx7 case off a 2007. You do have to swap the flange and then remove te splines from your old case and swap tem over. It's so easy though. Took like 10 minutes to swap over the intermediate shafts. Unbolt the one shaft pull it out then tap the other shaft out. I used the back of a screw driver and a small hammer ImageUploadedByTapatalk1348618394.002150.jpgImageUploadedByTapatalk1348618422.138270.jpg
Jh8909 likes this.
06 Speed6 GT- Sold
The Following 7 Users Say Thank You to bcmurphy87 For This Useful Post:
06Speed6 (09-25-2012), Don06speed6 (09-25-2012), Jh8909 (09-26-2012), memin (09-25-2012), Mistersix (09-26-2012), Raider (09-26-2012), torquemaniac (10-28-2014)
 Old 09-25-2012, 10:59 PM   #18
Speeeeeed
06Speed6's Avatar
Originally Posted by bcmurphy87 View Post
Hey guys you can use a cx7 case all day. I bought a used low low mileage cx7 case off a 2007. You do have to swap the flange and then remove te splines from your old case and swap tem over. It's so easy though. Took like 10 minutes to swap over the intermediate shafts. Unbolt the one shaft pull it out then tap the other shaft out. I used the back of a screw driver and a small hammer Attachment 75518Attachment 75519
Cough write up cough
2006 Mazdaspeed 6
bcmurphy87 (09-26-2012)
 Old 09-26-2012, 09:41 AM   #19
bcmurphy87's Avatar
it is done your pleasure
06 Speed6 GT- Sold
 Old 09-26-2012, 06:26 AM   #20
writeup or ban, @bcmurphy87.
I am still pissed at you over the GoPro, banhammer is a little dusty....
bcmurphy87 (09-26-2012), Code Monkey (09-26-2012)
 Old 09-26-2012, 09:31 AM   #21
bcmurphy87's Avatar
How to made for you guys now go save lots of money!!!! BCMURPHY87 for president
http://www.mazdaspeedforum.org/forum/foru...6/#post1650286
@Raider
Raider likes this.
06 Speed6 GT- Sold
The Following 2 Users Say Thank You to bcmurphy87 For This Useful Post:
EdgeAutosport.com (09-26-2012), Raider (09-26-2012)
My Transfer case/PTO is done... LoresonDE MazdaSpeed 6 - Engine, Transmission & Driveline 10 02-24-2010 05:09 PM
My Transfer case/PTO is done... LoresonDE MazdaSpeed 3 - Engine, Transmission & Driveline 5 02-08-2010 09:41 PM
transfer case pic 06speed MazdaSpeed 6 - Engine, Transmission & Driveline 9 01-11-2010 07:13 AM
transfer case pics? Jarods7920 MazdaSpeed 6 - Engine, Transmission & Driveline 0 12-03-2009 09:24 AM
Page generated in 0.40292 seconds with 27 queries
