 Old 09-17-2008, 07:26 PM   #1
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
Neutral  -1 score
Default SUPER CUSTOM FMIC!!! SIDE TO SIDE BITCHES!!!
ok well most of you know ive been working on a custom FMIC for weeks now and i finally got it done.....almost. i received all my pipes and couplers yesterday but they forgot to send my core so i essentially finished the project w/o the core......
here goes nothing..........
STEP 1: REMOVING THE BUMPER!!!!
take off screw and fastener here:
4 bolts underneath infront of each tire:
1 bolt in the next to these 4 towards the middle of the car on each side:
2 fasteners in each wheel well:
1 bolt at the tip of the bumper where it connects to the fender:
slip off each side as shown and lift off bumper. you will need to disconnect any harnesses before u can actually pull it all the way away from the car:
some general under bumper picts:
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
 Old 09-17-2008, 07:26 PM   #2
Must Have Teh 10's!
FINAL PRODUCT PICTS:
here was my final parts list and what i paid for each item:
2.25" pipe: $13 each piece
1 X L-pipe 18" $13
2 X 45deg bent 18" $26
3 X Straight pipe 18" $39
Silicone Hoses:
2 X 2.25" Straight $8
4 X 90deg 2.25" $60
2 X Reducer from 2.5"-2.25" $8
1 X 45Deg 2.25" $15
T-Bolt Clamps:
18 X 2.25" $36
2 X 2.5" $4
1 X 2.75 $2
1 X 2.0 $2
the core was:
CXRacing INTERCOOLER FMIC 28x7x2.5 $91 shipped
i did have to remove the washer fluid res but i bought another universal one from pepboys for 13. you can transplant the pump from the stock one too so its an easy swap. i plan to put it right infront of the CAI where the old airbox used to be.
please entertain me with questions. im having a friend bead roll all the pipes for me and i will try and take measurements for you guys but i basically just jut to size and testetd and retested. you also have to cut the radiator support just a little (seen in pict) which was no big deal. i made my own BOV flange from scratch so that wasent a problem for me but u can always get a universal pipe with a flange already on it from ebay. i also used heat reflective wrap on the hot pipe that stretches across the engine. that can be found here..
http://www.pegasusautoracing.com/productde...s.asp?RecID=395
total all said and done it cost me around 350 including shipping. i did however do all the work myself and i had access to a machine shop.
 Old 09-17-2008, 08:20 PM   #3
Boost Whore
Unoriginalusername's Avatar
Posts: 1,757   (View Stats)
Unoriginalusername is the leader of the worldUnoriginalusername is the leader of the worldUnoriginalusername is the leader of the worldUnoriginalusername is the leader of the worldUnoriginalusername is the leader of the worldUnoriginalusername is the leader of the worldUnoriginalusername is the leader of the worldUnoriginalusername is the leader of the worldUnoriginalusername is the leader of the worldUnoriginalusername is the leader of the worldUnoriginalusername is the leader of the world
Groans: 223
+1 for inginuty but engine bay astecics are still worth some IMO lol
"God created turbo lag to give v8's a chance"
Unoriginalusername is offline   Reply With Quote
 Old 09-17-2008, 08:41 PM   #4
Must Have Teh 10's!
funny how u say that, my valve cover is drying as we speak in my basement......
and functionality over looks anyday......
 Old 09-18-2008, 10:32 AM   #5
bnoon's Avatar
Posts: 1,770   (View Stats)
The only thing that makes it look ugly are the wrapping and that keeps it cooler. Function over form FTMFW!!!
2008.5 MS3 GT - Sold!
2013 Ford Focus SE - Sold!
2002 BMW M3 - Sold!
 Old 09-18-2008, 10:34 AM   #6
jweller's Avatar
Posts: 426   (View Stats)
jweller has a brilliant futurejweller has a brilliant futurejweller has a brilliant futurejweller has a brilliant futurejweller has a brilliant futurejweller has a brilliant futurejweller has a brilliant futurejweller has a brilliant futurejweller has a brilliant futurejweller has a brilliant futurejweller has a brilliant future
$350 is a pretty good price for putting all of that together. The heat wrap is the only part I don't really like the looks of but I understand why. You can always have it sent out to get it coated by jet hot or something similar. I would have done the top pipe across the valve cover as one piece, even if it did raise the cost.
you're going to dyno it right? hurry hurry hurry!
jweller is offline   Reply With Quote
 Old 09-19-2008, 04:58 PM   #7
Hypnotized's Avatar
Posts: 184   (View Stats)
Hypnotized is a splendid one to beholdHypnotized is a splendid one to beholdHypnotized is a splendid one to beholdHypnotized is a splendid one to beholdHypnotized is a splendid one to beholdHypnotized is a splendid one to behold
good job!
Hypnotized is offline   Reply With Quote
 Old 09-22-2008, 03:11 PM   #8
Must Have Teh 10's!
FINALLY DONE!!!!!!!!!
wow i am crazy tired. this turned out to be alot more work then i had thought. after i mounted the core i found out that my pipe angles that were leading to the core were a little off and i had to modify some of the pipes. i diddent have to buy any extra piping but i changed my design a little which u can see in the picts. i also had to cut the bumper a little right behind the foglight housings (which you cant see because they are being covered by the fog light covers. i also had to bend the horn bracket to get that to fit with the piping as well. in the end though everything worked out really well and im glad i did it.
driving impressions:
i only drove home from school so i havent really had a chance to get on it but it was holding boost fine so i have no leaks. i also realized that i was heat soaking a little because the "cold" pipe is getting too hot so i am going to wrap the extra heat reflective tape i have onto it and see what happens. i noticed no added lag at all with the system and so far i am very happy.
The Following 4 Users Say Thank You to superskaterxes For This Useful Post:
BaseballD2 (05-17-2009), gsrtype1 (09-22-2008), MazMusic (03-21-2009), Zeya (09-22-2008)
 Old 09-22-2008, 03:19 PM   #9
gsrtype1's Avatar
Posts: 7,514   (View Stats)
Groans: 102
BADASS!
 Old 09-22-2008, 03:32 PM   #10
Fux Wit It
Darksun280's Avatar
Posts: 9,214   (View Stats)
Groans: 175
Nice job. Mad respect for doing all that yourself.
Carry on citizens....
10.7 @ 133 auto 1G DSM
 Old 09-22-2008, 03:49 PM   #11
Hypnotized's Avatar
i cant see were you have the flange for your bov. Good job on everything!
 Old 09-22-2008, 07:34 PM   #12
pewpew
Sacrilicious's Avatar
Posts: 2,452   (View Stats)
Groaned at 9 Times in 9 Posts
kudos to you for having the balls to try that, man...gj!
Sacrilicious is offline   Reply With Quote
 Old 09-22-2008, 08:33 PM   #13
Must Have Teh 10's!
see third pict from bottom
 Old 09-22-2008, 09:06 PM   #14
Grim's Avatar
Posts: 2,395   (View Stats)
Groans: 70
what happened on the left side of your engine bay?
Grim is offline   Reply With Quote
 Old 09-22-2008, 09:06 PM   #15
kingpin748's Avatar
Posts: 2,611   (View Stats)
Groans: 78
Looks like a lot of work. Great job on the pictures. I get so sick of people posting shitty pictures.
In reality I love lenny
kingpin748 is offline   Reply With Quote
 Old 09-22-2008, 09:11 PM   #16
Must Have Teh 10's!
elaborate.......
 Old 09-22-2008, 09:18 PM   #17
kingpin748's Avatar
Groans: 78
I think he's talking about the rusty looking stuff.
 Old 09-22-2008, 09:41 PM   #18
BaseballD2's Avatar
Posts: 196   (View Stats)
BaseballD2 has a brilliant futureBaseballD2 has a brilliant futureBaseballD2 has a brilliant futureBaseballD2 has a brilliant futureBaseballD2 has a brilliant futureBaseballD2 has a brilliant futureBaseballD2 has a brilliant futureBaseballD2 has a brilliant futureBaseballD2 has a brilliant futureBaseballD2 has a brilliant futureBaseballD2 has a brilliant future
animals in the engine bay FTL!
06 MazdaspeeD 6 Black Mica
Drowned
BaseballD2 is offline   Reply With Quote
 Old 09-22-2008, 10:04 PM   #19
Must Have Teh 10's!
lol correct. when i first bought my car it sat in the drive way for about a month and apparently some animals got in my engine bay and ate the shit out of all that heat protective stuff all around the engine bay. WTF RIGHT?
 Old 10-08-2008, 03:36 PM   #20
H3llfir3's Avatar
Posts: 255   (View Stats)
H3llfir3 is the leader of the worldH3llfir3 is the leader of the worldH3llfir3 is the leader of the worldH3llfir3 is the leader of the worldH3llfir3 is the leader of the worldH3llfir3 is the leader of the worldH3llfir3 is the leader of the worldH3llfir3 is the leader of the worldH3llfir3 is the leader of the worldH3llfir3 is the leader of the worldH3llfir3 is the leader of the world
i have the same core, fits really nice does it =]
2006 black Mica MS6 GT- It has tons of shit on it and it's still slow.
NATOR of Florida
H3llfir3 is offline   Reply With Quote
 Old 10-08-2008, 03:59 PM   #21
MazdaMan13's Avatar
Posts: 532   (View Stats)
MazdaMan13 is a splendid one to beholdMazdaMan13 is a splendid one to beholdMazdaMan13 is a splendid one to beholdMazdaMan13 is a splendid one to beholdMazdaMan13 is a splendid one to beholdMazdaMan13 is a splendid one to beholdMazdaMan13 is a splendid one to beholdMazdaMan13 is a splendid one to behold
very nice
MAZDAMAN13 - 2.221, 9.378 @ 78.89, 14.309 @ 99.72 (CBE) no power-shifting
DON'T SLEEP ON THE MAZDA...:phillyb:
JDM PARKING LOL
MazdaMan13 is offline   Reply With Quote
 Old 10-08-2008, 04:20 PM   #22
aragorn764's Avatar
Posts: 172   (View Stats)
aragorn764 has a reputation beyond reputearagorn764 has a reputation beyond reputearagorn764 has a reputation beyond reputearagorn764 has a reputation beyond reputearagorn764 has a reputation beyond reputearagorn764 has a reputation beyond reputearagorn764 has a reputation beyond reputearagorn764 has a reputation beyond reputearagorn764 has a reputation beyond reputearagorn764 has a reputation beyond reputearagorn764 has a reputation beyond repute
good job man
aragorn764 is offline   Reply With Quote
 Old 10-08-2008, 04:45 PM   #23
lestat13's Avatar
Posts: 102   (View Stats)
lestat13 has a spectacular aura aboutlestat13 has a spectacular aura about
Holy shit balls! Good for you!!
If you guys agree that the same parts should work for a MS3, I will give this a try
Subbed for more driving impressions
lestat13 is offline   Reply With Quote
 Old 10-13-2008, 09:47 AM   #24
Super Unique's Avatar
Posts: 137   (View Stats)
Super Unique is just really niceSuper Unique is just really niceSuper Unique is just really niceSuper Unique is just really nice
Dude,
WTF do they put on the roads where you live?
that body rot settled in pretty damned quick on the passenger side strut tower....
Super Unique is offline   Reply With Quote
 Old 10-13-2008, 10:41 AM   #25
Must Have Teh 10's!
Originally Posted by Super Unique View Post
Dude,
HAHAHAHAHA thats NOT body rot (thank god). some sort of animal got into my engine bay when my car used to just sit and ate the shit out of all the wool firewall protector stuff. its ate the entire hood liner and under belly pan stuff as well.
as far as driving impressions i couldent be happier with this setup, everything is great.
 Old 10-13-2008, 11:29 PM   #26
I'm a caveman
gtlaw's Avatar
Posts: 758   (View Stats)
gtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the world
Groans: 68
Groaned at 22 Times in 16 Posts
as far as driving impressions i couldent be happier with this setup, everything in great.
damn I thought that was rust too, but your car is pretty corroded. it must have been driven in the snow.
gtlaw is offline   Reply With Quote
 Old 10-19-2008, 12:39 PM   #27
dukebrown's Avatar
Posts: 264   (View Stats)
dukebrown is the leader of the worlddukebrown is the leader of the worlddukebrown is the leader of the worlddukebrown is the leader of the worlddukebrown is the leader of the worlddukebrown is the leader of the worlddukebrown is the leader of the worlddukebrown is the leader of the worlddukebrown is the leader of the worlddukebrown is the leader of the worlddukebrown is the leader of the world
Sub
dukebrown is offline   Reply With Quote
 Old 10-19-2008, 03:02 PM   #28
LateralSpeed's Avatar
Posts: 27   (View Stats)
LateralSpeed is just really niceLateralSpeed is just really niceLateralSpeed is just really niceLateralSpeed is just really niceLateralSpeed is just really nice
Congrats man, everything looks great, good job! And lol @ the animals in the engine bay...
'04 VR Mazdaspeed Miata - '05 6MT RX8 Stock
FM Downpipe-running open downpipe | FM Intake | MBC 11psi | 27x7x2.5 FMIC | Falken Azeniz rt615 215/40/17 | Autometer boost gauge | Passport Escort 9500i | removed visors | Denso Recirc Valve | Supra Injectors waiting to be installed...
LateralSpeed is offline   Reply With Quote
 Old 10-19-2008, 03:23 PM   #29
danesti's Avatar
Posts: 4,186   (View Stats)
Groans: 137
you ever solve the coolant temp problem?
let me know!!!
2008 STi
Intake
Turboback
AP
 Old 10-19-2008, 04:27 PM   #30
m4tic's Avatar
Posts: 4,928   (View Stats)
would any of those universal piping kits on ebay fit the bill for this? and these cores are mad cheap!
2017 Daytona 392
STOLEN//2015 BMW S1000R
2007 MS6 w/ Cheez
 Old 10-19-2008, 04:31 PM   #31
Must Have Teh 10's!
let me know!!!
bought some WW and going to try that tomm. also need to find a way to route some air into there.
all my piping was from EBAY but i had to cut most of it to fit. total cost was around 350
 Old 10-19-2008, 04:37 PM   #32
m4tic's Avatar
this core looks neat
eBay Motors: CXRacing Intercooler 23x11x3 ECLIPSE TALON DSM Supra (item 330279460804 end time Oct-24-08 17:30:00 PDT)
2017 Daytona 392
2007 MS6 w/ Cheez
 Old 10-20-2008, 08:22 PM   #33
BaseballD2's Avatar
yeah thats the coat most people go with if your going with the same side piping
Drowned
 Old 03-21-2009, 05:33 PM   #34
MazMusic's Avatar
Posts: 120   (View Stats)
MazMusic is a name known to allMazMusic is a name known to allMazMusic is a name known to allMazMusic is a name known to allMazMusic is a name known to allMazMusic is a name known to all
very nice indeed
MazMusic is offline   Reply With Quote
 Old 03-30-2009, 06:51 PM   #35
carter8622's Avatar
Posts: 12   (View Stats)
carter8622 is an unknown quantity at this point
holy shit thank you skater. ive been searching for a way to pipe on my intercooler. the idiot that had my ms6 b4 had no clue what was going on so i have to fix everything. and your post just saved me a lot of headache and hassle....... thank you
carter8622 is offline   Reply With Quote
 Old 03-30-2009, 08:38 PM   #36
Must Have Teh 10's!
lol np. shoot me a PM if u need any details
 Old 04-18-2009, 05:59 AM   #37
buddhabum's Avatar
Posts: 254   (View Stats)
buddhabum has a reputation beyond reputebuddhabum has a reputation beyond reputebuddhabum has a reputation beyond reputebuddhabum has a reputation beyond reputebuddhabum has a reputation beyond reputebuddhabum has a reputation beyond reputebuddhabum has a reputation beyond reputebuddhabum has a reputation beyond reputebuddhabum has a reputation beyond reputebuddhabum has a reputation beyond reputebuddhabum has a reputation beyond repute
I'm doing the same thing right now on my 6 but using 2.5" piping. Had to cut the back of my headlight assembly and part of the bumper support but it will look real close. Weird how your coldpipe was heatsoaking though...
'06 MS6 Black Mica
Street Unit Block, CP Pistons (9.0:1), Pauter Rods, CPBoost Top-mounted Turbo Exhaust Manifold w/ Tial 38mm External Wastegate, Custom 3", CP-E FCF (No Boost cut, 3.25" MAF), CP-E PnP Standback V2, CP-E HPFP, CP-E FMIC Core w/ Custom piping, Denso Spark Plugs, Custom Inlet w/ 3.25" MAF Housing, VCTS Delete, EGR Block-off, Saikou Michi OCC, Fidanza Flywheel, HD Signature 18x8" MSR Wheels, HTR Z III's 235/40/18, BS Delete, TWM Stage 2 SS Kit, Dashhawk, Perrin EBCS.
buddhabum is offline   Reply With Quote
 Old 04-18-2009, 08:06 AM   #38
ZoomZoom09MS3's Avatar
Posts: 16   (View Stats)
ZoomZoom09MS3 is an unknown quantity at this point
Haha mad nice!
ZoomZoom09MS3 is offline   Reply With Quote
 Old 04-18-2009, 04:49 PM   #39
Clean Baldy's Avatar
Posts: 14   (View Stats)
Clean Baldy is an unknown quantity at this point
It's been a while since you've done this, how is it holding up? I have been doing research on this as well.
I have only a Cobb AccessPort at the moment and a gutted airbox. I was going to buy a Test Pipe and create a custom FMIC and be done... (hopefully)
Clean Baldy is offline   Reply With Quote
 Old 04-18-2009, 05:50 PM   #40
mike8748's Avatar
Posts: 396   (View Stats)
mike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the world
Good job on the DIY FMIC
07'MazdaSpeed3 Stage2+SF 93 FMIC Custom Map
Current Mods: COBB AP, COBB SRI, COBB Inlet, COBB Cold Air Box, COBB Shift Weight, COBB STS, COBB PCV Catch Can, COBB Rear Sway Bar, M3M FMIC, TWM Shifter Bushings, FORGE BPV, Nator Rear MM, TurboXS DP, TurboXS RP, TB BYPASS MOD, MSD Dash Hawk, Denso 2-Step Colder plugs, Eibach Springs, BSD, KMD ver2 internals, EGR delete, PTP intake cooler kit, CNT Racing CBE, PG Exhaust Manifold
mike8748 is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f106/super-custom-front-mount-intercooler-side-side-11705/
Race Roots Project Mazdaspeed6 Pictures!!! - Mazda6 / Atenza This thread Refback 02-10-2010 02:31 PM
Side Moldings... wtf mazda? Haltech MazdaSpeed 3/6 - Appearance 31 07-08-2013 12:10 PM
oem heated side mirrors cosmicspd3 MazdaSpeed 3/6 - Appearance 46 03-12-2009 12:39 PM
Choosing Your Next Side-by-Side Utility Vehicle Haltech Automotive News 0 09-10-2008 09:50 PM
looking for this side lip kit-ideas Speed6SLEEPER MazdaSpeed 3/6 - Appearance 5 06-26-2008 10:23 AM
Page generated in 0.60176 seconds with 46 queries
