 Old 02-07-2009, 03:17 PM   #1
demonspeed's Avatar
Posts: 204   (View Stats)
demonspeed has a reputation beyond reputedemonspeed has a reputation beyond reputedemonspeed has a reputation beyond reputedemonspeed has a reputation beyond reputedemonspeed has a reputation beyond reputedemonspeed has a reputation beyond reputedemonspeed has a reputation beyond reputedemonspeed has a reputation beyond reputedemonspeed has a reputation beyond reputedemonspeed has a reputation beyond reputedemonspeed has a reputation beyond repute
Default Theory: Build before Build
So the first failure point (mechanical) on the MZR is the rods, correct? I know of people, mostly in the DSM crowd, that have replaced rods and pistons through the bottom of the engine, without actually removing it from the car, is that possible on the Speed3?
demonspeed is offline   Reply With Quote
 Old 02-07-2009, 04:06 PM   #2
Rods can be plopped in from the bottom, but i dont know about the pistons.
 Old 02-07-2009, 04:36 PM   #3
MarkyMark's Avatar
Posts: 1,624   (View Stats)
Groans: 62
how do you insert a rod onto the wrist pin without the piston being removed from the engine?
i say replace all of it.
MarkyMark is offline   Reply With Quote
 Old 02-07-2009, 08:00 PM   #4
You have to remove the head.
 Old 02-07-2009, 08:09 PM   #5
Grim's Avatar
Posts: 2,395   (View Stats)
Groans: 70
Step 1.Remove oil pan
Step 2.Remove head
Step 3.Undo rod caps
Step 4.Pull piston and rod assembly out.
Grim is offline   Reply With Quote
 Old 02-10-2009, 06:52 PM   #6
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
You cannot pull the rods out of the bottom of any engine that I know of, and I am 100% certain that you cannot reinstall a new set from the bottom of a engine on any engine ever made after 1940.
Problems:
#1 the wrist pin
#2 the piston cannot be removed
#3 the piston rings cannot be compressed and pushed into the cylinder from the bottom
#4 the crank is completely in the way
#5 if the crank isnt in the way you run a good chance of scratching the rod bearing surface on the crank which would require machining
#6 the main bearing girdle is in the way and would have to be removed, this would require a balance shaft delete
2006 Mazdaspeed 6
Sq build Strytnyne MazdaSpeed 3/6 - Car Audio & Electronics 10 12-18-2008 03:19 PM
Big turbo kit, build one or not? ptperformance Mazdaspeed3/6 General Discussion 33 10-12-2008 02:55 PM
Update on build. EvilMonkey Mazdaspeed3/6 General Discussion 27 10-09-2008 08:56 AM
Introduction and build EvilMonkey MazdaSpeed 3 - Engine, Transmission & Driveline 20 07-18-2008 07:25 AM
Page generated in 0.26833 seconds with 25 queries
