 Old 03-21-2019, 03:23 PM   #1
mazda_speed_6's Avatar
Posts: 84   (View Stats)
mazda_speed_6 is just really nicemazda_speed_6 is just really nicemazda_speed_6 is just really nicemazda_speed_6 is just really nice
Default Tire wear effecting t case?
The front tires on my speed 6 wear out a little faster in the inside than the rest of tire. I did some research and seems a lot of speed 6 wear the inside of the tire Im gonna take it for a alignment. My question is since its wearing out the inside of the tire a little fast will that cause any damage to my transfer case if I drive it around for a while till I'm able to get an alignment? All 4 tires are the same brand and size and there brand new.
2006 MS6 sri/tbe/cpe diff mount/TS bpv/AT internals/jbr motor mounts/COBB acessport/stratified ots map/act 6 puck
mazda_speed_6 is offline   Reply With Quote
 Old 03-21-2019, 03:51 PM   #2
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
Nothing to worry about at all.
Camber and toe affect the wear on inside and outside edges. Probably too much toe on yours. Camber is not adjustable unless you install SPC Adjustable Upper Ball Joints.
mazda_speed_6 (03-22-2019)
 Old 03-22-2019, 06:36 AM   #3
LenSpeed6's Avatar
Posts: 164   (View Stats)
LenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud of
Bring it in for an alignment and they will tell you if anything is bad, thats how i found out that I had bad balljoints and basically rebuilt the front end and all is well now.
06 Speed6
White/Black interior
Sure Diff Mounts, JBR Intake, JBR I/C Hoses, Wiesco pistons .5mm over, Molnar H-Beam Rods, King bearings, New to me Cylinder Block, CS turbo, CS catted turbo back exhaust, CS HPFP, CS EBCS, CS injector seals, AP v3, FREEKTUNE, rebuilt clutch from Falcon Clutch with kevlar lining, DM PCV plate, DM stage 1 OCC, EcoBoost oil pump, vented oil cap with baffle, Speed Solutions PTO bearing caps, All Damond mounts
To think... this is suppose to be my winter car... because,
'72 AMC Javelin AMX 366 CI, 4speed 13.13 quickest 1/4 mile et so far
'12 1/2 Triumph Daytona 675R stock some how
'79 AMC Spirit AMX, 4.6L stroker I6
LenSpeed6 is offline   Reply With Quote
The Following User Says Thank You to LenSpeed6 For This Useful Post:
 Old 03-22-2019, 11:24 AM   #4
Thanks for the info guys. I had dropped the subframe to remove the transmission must of messed up the alignment when I put every thing back together
 Old 03-22-2019, 11:33 AM   #5
Groans: 211
The subframe mounting holes are slightly oversized. I loosened mine and twisted it in one particular direction to achieve more caster on the passenger side. Its moves very little but does make a difference.
When you take out the subframe best to first find reference points and take measurements. Then put it back where it was before dis-assembly.
need help with tire wear Fxracer 2010 MS3 - Wheels & Tires 3 04-17-2014 07:34 PM
Tire wear Ron Gen2 MS3 General Discussion 25 05-16-2013 03:25 PM
Inner tire wear much Dmurray06 2010 MS3 - Wheels & Tires 23 11-29-2012 09:20 PM
Bad Inner Tire Wear MattJackson86 MazdaSpeed 3/6 - Wheels & Tires 3 03-09-2010 07:43 PM
Bad inner tire wear cm-jp1 MazdaSpeed 3/6 - Suspension & Brakes 27 12-05-2009 08:19 PM
Page generated in 0.25600 seconds with 22 queries
