![]() Join Date: Mar 2008 Location: Ontario, Canada
__________________ 2007 Mazdaspeed 6 -Cobb SRI - Forge BPV - Custom Test Pipe |
![]() Join Date: Jun 2010 Location: Santa Fe NM
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,637
Groans: 371
| Not Ranked : 0 score could be cause you havent donated |
| The Following 4 Users Say Thank You to I Love Brownies For This Useful Post: | gtarman77787 (01-17-2011), jwilkins88 (12-10-2010), marriioo (12-08-2010), ZipprSuitdSungod (12-16-2010) |
(Thread Starter) | Not Ranked : 0 score I wish it was that simple lol
![]() Join Date: Apr 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10
| Not Ranked : 0 score Brake light might be due to low brake fluid? Traction control light... I'm not sure about.
__________________ 2012 BMW 135i //M-Sport |
| The Following User Says Thank You to ms3brendan For This Useful Post: | Tommy (01-21-2011) |
![]() Join Date: Mar 2010 Location: Manassas, VA
Rep Power: 2313 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,791
Groans: 35
| Not Ranked : 0 score Have you been in any accidents?
__________________ CP-e Atmosphere GTX3076r w1.06 Tial | JMF IM | NATOR D.C. FMIC | JBR Wide Path | Autotech Internals | HKS SSQV2 | Ebay DP | Denso ITV24 | CP-e RDM | AutoExe Strut Tower Bar | Whiteline RSB | Sonic Tuning Coils | DSS Driver Side Axle | JMF OCC BT - 395 awhp 345 awtq @ Moore Automotive 4/12/2014 on 93 octane Stock Turbo - 331 awhp 397 awtq @ Moore Automotive 11/10/2012 on ~e48 12.263 @ 111.75 mph 1.669 60' 11/17/2012 |
![]() Join Date: Nov 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12
| Not Ranked : 0 score Sounds like a wheel speed sensor. |
![]() Join Date: Jul 2009 Location: Key West, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,273
Groans: 143
| Not Ranked : 0 score I actually had that happen to me yesterday, I was installing my new SURE SRI and TIP, I forgot to plug in my mass air flow sensor after I installed it. The traction control light and brake light came on, as well as the check engine light. fixed itself after I plugged the MAF back in. |
| The Following User Says Thank You to thehead For This Useful Post: | RichieRichness (12-08-2010) |
(Thread Starter) | Not Ranked : 0 score never been in any accidents and I havent worked on my car in a long time. I'm also noticing a bad smell like something burning in the engine bay but I cant figure that out either, dont know if theyre related issues or not.
| Not Ranked : 0 score Did you check what thehead mentioned? Making sure your MAF is plugged in?
(Thread Starter) | Not Ranked : 0 score I checked my maf last night and its plugged in, still cant figure this out.
![]() Join Date: Nov 2010 Location: Philadelphia, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 26
| Not Ranked : 0 score On MINIs, a bad wheel speed sensor will cause the ABS/DSC/TPM/brake, etc light.
__________________ |
(Thread Starter) | Not Ranked : 0 score The smell is there every time I drive the car but the tcs and brake light only come on about half the time I drive.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 194
| Not Ranked : 0 score Start checking things, brake fluid, brakes, just start looking for anything out of the ordinary if you dont know wear to start, what kinda of burning smell is it? burned oil?
__________________ Long Block Built by GPwerks and Loose Screw Motor Sports https://www.gp-werks.com/ http://www.crossoverauto.com ^Any Parts, Great Prices^ |
![]() Join Date: Nov 2010 Location: NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 530
Groans: 68
| Not Ranked : 0 score Undoubtedly zoom zoom boom within the next 5 working days. Unless, of course, you donate. Then the moderator will turn off your warning lights. |
![]() Join Date: Jan 2010
Rep Power: 0 ![]() Thanks: 0
![]() Join Date: Feb 2010 Location: Charlotte Nc
| Not Ranked : 0 score updates?
__________________ [SIGPIC][/SIGPIC] 2006 Mazdaspeed6 |
![]() Join Date: Dec 2008
Rep Power: 0 ![]() ![]() ![]() Thanks: 15
| Not Ranked : 0 score I had similar issue awhile back and topping off brake fluid fixed it. Fluid was just at the low mark. DCS and brake light would come on without any rhyme or reason. Sometimes it was one, sometimes the other, sometimes both. Sometimes would pop on during hard cornering, sometimes just cruising straight. Sometimes turned off by itself, other times turned off after cycling ignition but not always. Which reminds me to check my brake fluid again. Kinda wondering why I lost so much fluid in first place. |
![]() Join Date: Nov 2008 Location: Sumter, South Carolina
Rep Power: 0 ![]() Thanks: 10
Groaned at 25 Times in 7 Posts
| Not Ranked : 0 score i had the same issues. but i found out my sensor wires were cut. after i fixed that all was good. so check the sensor and the wiring. |
![]() | | #19 | ![]() |
| Banned ![]() Join Date: Feb 2010 Location: Waste Milford North JerZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,140
Groans: 444
Groaned at 154 Times in 97 Posts
| Not Ranked : 0 score when it snowed last week, i was going down my street, i ripped the e-brake and slid my back end out a little, just to play -- and after that, the same lights came on and stayed on for a while -- i got to a stop light, turned off the car, and turned it back on -- the lights went off so uh... whens the last time you turned off your car? .... jk |
![]() | | #20 | ![]() |
| Banned ![]() Join Date: Jun 2008 Location: misery
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11,510
Groans: 1,940
| Not Ranked : 0 score suggesting the maf was fucking retarded. car won't go too far with the maf unplugged. lol |
![]() | | #21 | ![]() |
Groans: 444
![]() | | #22 | ![]() |
![]() Join Date: Nov 2010 Location: Hudson, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7
| Not Ranked : 0 score Happened to me. It was brake fluid. |
| HELP! Traction control light and Weird idle after motor mount install? | xcoldricex | MazdaSpeed 3 - Engine, Transmission & Driveline | 15 | 05-20-2010 04:16 AM |
| e-brake and traction light coming on | baja2700 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 13 | 05-03-2010 08:49 AM |
| Customizing Traction Control with LC | Trader | Cobb ATR Support | 6 | 08-19-2009 10:10 PM |
| Traction control light | tuners | MazdaSpeed 3/6 - Suspension & Brakes | 1 | 07-20-2009 06:14 PM |
| Traction Control (MS3 specific) | SLS MS3 | Cobb ATR Support | 15 | 06-08-2009 01:08 PM |
