 Old 03-28-2011, 10:18 AM   #1
banzairx7's Avatar
Posts: 84   (View Stats)
banzairx7 has much to be proud ofbanzairx7 has much to be proud ofbanzairx7 has much to be proud ofbanzairx7 has much to be proud ofbanzairx7 has much to be proud ofbanzairx7 has much to be proud ofbanzairx7 has much to be proud ofbanzairx7 has much to be proud of
Default Traction Control light coming on
I went and finally did a track day with my 6 saturday. I had a strange incident with the traction control light though. I ended up in a four wheel slide at around 80mph with the DSC off. A few seconds after I get the car straightened out the traction control light came on. I pulled off the track shut the car off twice and the light was still on. I then drove over to the pits and half way over the light finally shuts off. Any ideas why the light came on and then took so long to go off? I could see it coming on if I had the DSC engaged but with it off not sure why it lit up.
K&N Drop in, Cobb AP Stage 1 - 93, CP-e rear motor mount, AWR tranny mount, Koni Yellows, Whiteline rear sway bar, SPC adjustable ball joints, Turbine Tech Diff mount. SU rear Diff mount, Labonte Methanol injection
banzairx7 is offline   Reply With Quote
 Old 03-28-2011, 10:29 AM   #2
WWP6's Avatar
Posts: 71   (View Stats)
WWP6 will become famous soon enoughWWP6 will become famous soon enough
possibly diff overheating?
Was it the little car emblem light or the 4x4 light?
WWP6 is offline   Reply With Quote
 Old 03-28-2011, 10:36 AM   #3
triplejumper18's Avatar
Posts: 2,569   (View Stats)
Groans: 196
Can you pull the code?
 Old 03-28-2011, 10:38 AM   #4
I Love Brownies's Avatar
Posts: 3,791   (View Stats)
I Love Brownies is the leader of the worldI Love Brownies is the leader of the worldI Love Brownies is the leader of the worldI Love Brownies is the leader of the worldI Love Brownies is the leader of the worldI Love Brownies is the leader of the worldI Love Brownies is the leader of the worldI Love Brownies is the leader of the worldI Love Brownies is the leader of the worldI Love Brownies is the leader of the worldI Love Brownies is the leader of the world
Groans: 371
+1 on diff overheating
I Love Brownies is offline   Reply With Quote
 Old 03-28-2011, 10:42 AM   #5
[MSF STIG]
FORZDA 1's Avatar
Posts: 1,206   (View Stats)
Nah, the slide triggered the light because the wheels were turning at different speeds and the sensors reported it to the ECU. No problem as the light will go out after a few feet of rolling all together. All is normal, even with DSC OFF, the TCS is still "ON", but "disengaged". The light will flash if the TCS is "engaged" and the wheels slip.
FORZDA 1 is offline   Reply With Quote
The Following 3 Users Say Thank You to FORZDA 1 For This Useful Post:
breakfstincluded (12-03-2011), I Love Brownies (03-28-2011), triplejumper18 (03-28-2011)
 Old 03-28-2011, 12:18 PM   #6
banzairx7's Avatar
It was the car with squiggly lines that lit up. I think Forzda post answered it. Just one more question- When the light is illuminated is anything effected? Does it cut engine power or effect the AWD in anyway or maybe even ABS?
traction control light on.... countrymanjeff MazdaSpeed 3/6 - Troubleshoot/Diagnostics 17 04-01-2016 07:08 PM
Traction control & brake light coming on dutchbuffalo MazdaSpeed 6 - Engine, Transmission & Driveline 21 01-21-2011 07:14 AM
HELP! Traction control light and Weird idle after motor mount install? xcoldricex MazdaSpeed 3 - Engine, Transmission & Driveline 15 05-20-2010 04:16 AM
e-brake and traction light coming on baja2700 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 13 05-03-2010 08:49 AM
Traction control light tuners MazdaSpeed 3/6 - Suspension & Brakes 1 07-20-2009 06:14 PM
Page generated in 0.26085 seconds with 24 queries
