  • 1 Post By chapy18
 Old 04-02-2014, 12:58 PM   #1
mikelevi's Avatar
Posts: 362   (View Stats)
mikelevi is the leader of the worldmikelevi is the leader of the worldmikelevi is the leader of the worldmikelevi is the leader of the worldmikelevi is the leader of the worldmikelevi is the leader of the worldmikelevi is the leader of the worldmikelevi is the leader of the worldmikelevi is the leader of the worldmikelevi is the leader of the worldmikelevi is the leader of the world
Default Weird Electronic sound from Engine bay
So I was hearing this weird electronic noise every 30 seconds after I turned my car off. Even pulled the battery and could still hear it. Any thoughts?https://www.youtube.com/watch?v=krO0...ature=youtu.be
mikelevi is offline   Reply With Quote
 Old 04-03-2014, 10:01 AM   #2
mikelevi's Avatar
no one?
 Old 04-03-2014, 10:42 AM   #3
Bludypoo's Avatar
Posts: 287   (View Stats)
Bludypoo is the leader of the worldBludypoo is the leader of the worldBludypoo is the leader of the worldBludypoo is the leader of the worldBludypoo is the leader of the worldBludypoo is the leader of the worldBludypoo is the leader of the worldBludypoo is the leader of the worldBludypoo is the leader of the worldBludypoo is the leader of the worldBludypoo is the leader of the world
I've heard tales of vehicles being controlled by computers before but i think this new evidence suggests that it might not be pure legend.
OP... your car is a transformer. run for your life.
Bludypoo is offline   Reply With Quote
The Following 5 Users Say Thank You to Bludypoo For This Useful Post:
Agent_Orange (04-03-2014), calizoomzoom (04-03-2014), Cujo (04-03-2014), ItsNox (04-05-2014), pzr2874 (04-03-2014)
 Old 04-03-2014, 10:43 AM   #4
manila's Avatar
Posts: 1,767   (View Stats)
The sound that I am hearing sounds like something from a start up sequence on a digital camera...STRANGE
'12 MS3 Black Mica w/ Tech
 Old 04-03-2014, 10:48 AM   #5
Bludypoo's Avatar
you have an AP... when flashing maps you've yet to hear the same exact sound over and over while it's flashing?
 Old 04-03-2014, 10:54 AM   #6
mikelevi's Avatar
Its strange it doesnt sound like any other noise I hear. I was thinking maybe a bad relay or fuse pushing power to the alarm or horn, but it doesnt sound like that
i do not have an AP
Last edited by mikelevi; 04-03-2014 at 10:54 AM. Reason: MSF Database - Automerged Doublepost
 Old 04-03-2014, 10:56 AM   #7
Bludypoo's Avatar
Ah, after actually listening to your video i assume you are talking about the weird beeping noise... yeah no idea.
I thought you were referring to the sound the car makes when flashing a map or sometimes just sitting that sounds almost like a hard drive being written to or a CD being read.
 Old 04-03-2014, 11:02 AM   #8
Agent_Orange's Avatar
Posts: 3,575   (View Stats)
Groans: 665
Do you have both terminals off the battery or just the negative?
 Old 04-03-2014, 11:06 AM   #9
mikelevi's Avatar
to add, I've also had an issue last few months where all my electronics in my vehicle would shut off after I accelerated from a stop, lights, stereo, dash and then 1 second later come back on. This would happen for 2 days until my car would be completely dead. I would wait 5 minutes and everything would come on would be reset like I pulled the battery. Its a new battery, I checked all the grounds and the alternator. This happened twice in the past two months. Once the car was back on it would act as normal again.
both were off the battery
Last edited by mikelevi; 04-03-2014 at 11:42 AM. Reason: MSF Database - Automerged Doublepost
 Old 04-03-2014, 02:40 PM   #10
fretburnr's Avatar
Posts: 226   (View Stats)
fretburnr is the leader of the worldfretburnr is the leader of the worldfretburnr is the leader of the worldfretburnr is the leader of the worldfretburnr is the leader of the worldfretburnr is the leader of the worldfretburnr is the leader of the worldfretburnr is the leader of the worldfretburnr is the leader of the worldfretburnr is the leader of the worldfretburnr is the leader of the world
No joke, I thought I was nuts but my 6 does this too. After a drive home from work, I park in the garage, then while chatting with roommate etc it starts making this very similar noise. He thought I was nuts until it interrupted him talking. Now he agrees it's real. For several, even dozens of minutes after the car has been off, it still puts out an occasional beep or whistle sound.
I have not been able to find a location other than somewhere near the intake/hpfp/battery as best I can tell. Up close it sounds like a whistle and not an electronic noise. I had wondered if it was the squeak sound of pressure bleeding off either internal to the fuel pump or something in the PCV system.
Jay
'14 focusST
'03 330i
fretburnr is offline   Reply With Quote
 Old 04-04-2014, 09:12 AM   #11
mikelevi's Avatar
Do you have upgraded internals or a restricted Banjo Bolt (i've got both)? Could be some some sort of pressure bleeding. If its electrical must be a charge Relay or something still holding power.
 Old 04-04-2014, 09:21 AM   #12
fretburnr's Avatar
I've got Autotech internals, standard oil banjo.
Jay
'14 focusST
'03 330i
 Old 04-04-2014, 09:27 AM   #13
Police - Grammarhead
Vansquish's Avatar
Put your intercooler shroud back on.
 Old 04-04-2014, 09:33 AM   #14
chapy18's Avatar
Posts: 159   (View Stats)
chapy18 is the leader of the worldchapy18 is the leader of the worldchapy18 is the leader of the worldchapy18 is the leader of the worldchapy18 is the leader of the worldchapy18 is the leader of the worldchapy18 is the leader of the worldchapy18 is the leader of the worldchapy18 is the leader of the worldchapy18 is the leader of the worldchapy18 is the leader of the world
Pull off your intake hose between your throttle body and intercooler. Then turn your ignition to the run position for a little bit then back off. You don't have to start it up. After you shut off your vehicle about 10-20 seconds the throttle plate moves through a sequence. Mine sounds difference but you can hear it. Maybe it is some sort of squeak coming off of that. With the intake hose off you will be able to watch it and see if that is what it is. I noticed this when doing a compression tests.
mikelevi likes this.
2006 Black MS6 GT
For POWER!!!! - Cobb AP V3///HTP 3.5" Intake///Sure Test Pipe//Magnaflow CBE///Freek Tune///CS HPFP
For Looks - CS Shift Noob, Aftermarket Steering Wheel, CS LED Interior Light kit, 15% window tint all around, 70% window tint on windshield
For Handling - CS Front Upper Control Arms, CS rear Camber Arms, CS Sprtings, Whiteline Rear Sway Bar, AWR End links, JBR Trilogy Mounts, CPE rear diff mount, Turbine Tech Front Diff mount, Konig Backbone 18X8.
Big Build in the Works
chapy18 is offline   Reply With Quote
 Old 04-04-2014, 09:38 AM   #15
kornybun's Avatar
Posts: 119   (View Stats)
kornybun is the leader of the worldkornybun is the leader of the worldkornybun is the leader of the worldkornybun is the leader of the worldkornybun is the leader of the worldkornybun is the leader of the worldkornybun is the leader of the worldkornybun is the leader of the worldkornybun is the leader of the worldkornybun is the leader of the worldkornybun is the leader of the world
My 2012 Speed3 has done this several times before. I believe it's happened since new. Sounds like someone swinging.
-kornybun
kornybun is offline   Reply With Quote
 Old 04-04-2014, 10:05 AM   #16
mikelevi's Avatar
I took it off while I was installing CS SRI and TIP that day. But thanks
The Following User Says Thank You to mikelevi For This Useful Post:
Vansquish (04-04-2014)
 Old 04-04-2014, 10:05 AM   #17
fretburnr's Avatar
I'm familiar with that one, and that only lasts for a short bit.
This squeak will repeat occasionally for up to 20-30 mins.
Jay
'14 focusST
'03 330i
 Old 04-04-2014, 10:09 AM   #18
mikelevi's Avatar
I'll try that this weekend.
Yeah, it did last for about 15 minutes the last time I noticed it. Strangely the duration kept to about every 30 seconds, it did not elongate over time which leads me to believe its electrical. Wouldnt the pauses increase over time if it where in fact pressure bleed?
Last edited by mikelevi; 04-04-2014 at 10:09 AM. Reason: MSF Database - Automerged Doublepost
 Old 04-04-2014, 10:12 AM   #19
chapy18's Avatar
Well that one is weird.
2006 Black MS6 GT
weird ass sound after cobb sri bombdotcom 2010 MS3 - Turbo Induction 35 04-22-2013 04:44 PM
weird sound when depressing the clutch vballbwing MazdaSpeed 3/6 - Troubleshoot/Diagnostics 17 09-16-2012 03:24 PM
Weird sound out of tranny richkidone 2010 MS3 - Engine, Transmission & Driveline 11 02-05-2012 02:07 PM
Weird engine heat smell??? ms6fanatic MazdaSpeed 6 - Engine, Transmission & Driveline 4 11-15-2011 05:49 AM
Does my engine sound okay? Qtip MazdaSpeed 3 - Engine, Transmission & Driveline 2 04-05-2010 08:16 PM
Page generated in 0.42944 seconds with 27 queries
