 Old 08-10-2019, 11:34 PM   #1
BR1JZL's Avatar
Posts: 40   (View Stats)
BR1JZL is a splendid one to beholdBR1JZL is a splendid one to beholdBR1JZL is a splendid one to beholdBR1JZL is a splendid one to beholdBR1JZL is a splendid one to beholdBR1JZL is a splendid one to beholdBR1JZL is a splendid one to behold
Default What else to do while doing the chain?
Hey yall,
So turns out the guy that replaced the timing and VVT actuator had it slightly mistimed (got the tools to check timing and used this guide http://foxed.ca/rx7manual/manuals/NC...0Procedure.pdf).
Both my crank and cam seem out, Crank the M6 bolt isn't going in at all and the cam slots can't be lined up.
So I am going to tackle the job and was thinking of changing the water pump, friction washers, crank bolt and maybe the chain guides. Was wanting to know what else I should change while I'm at it,like the chain tensioner, chain adjuster, oil pump chain? Do these things usually go faulty?
Car has around 195,000 kms for reference
Mods slowly coming along!!!! Autotech HPFP, CircuitWerks Down/Testpipe, Cobb Accessport V2 and a CPE Turbo Inlet Pipe (Waiting to put it on)
BR1JZL is offline   Reply With Quote
Is there a way to tell if my vvt chain has been done? JackDG Mazdaspeed3/6 General Discussion 7 02-07-2019 04:00 PM
Page generated in 0.22153 seconds with 20 queries
