![]() Join Date: Apr 2012
Rep Power: 0 ![]() Thanks: 1
![]() Join Date: Jan 2012 Location: Milwaukee, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 975
| Not Ranked : 0 score your issue is you have run out of material on your clutch. delaying the repair will cause more part failure. I also think the adjustment would be pointless. FYI the speed6 has a higher engagement point anyways. you can replace with stock (luk kit) and get a lightweight flywheel to save on costs |
| Could a slipping clutch cause KR? | AntiStock | MazdaSpeed 6 - Engine, Transmission & Driveline | 2 | 07-01-2010 02:23 PM |
| My clutch is slipping | ms3jake | MazdaSpeed 3 - Engine, Transmission & Driveline | 29 | 03-03-2009 05:37 PM |
