 Old 02-17-2015, 12:47 PM   #1
VirtueMS3's Avatar
Posts: 36   (View Stats)
VirtueMS3 has much to be proud ofVirtueMS3 has much to be proud ofVirtueMS3 has much to be proud ofVirtueMS3 has much to be proud ofVirtueMS3 has much to be proud ofVirtueMS3 has much to be proud ofVirtueMS3 has much to be proud ofVirtueMS3 has much to be proud of
Default Will Gen1 Speed6 Intake Manifold fit on my Gen1 Speed3?
Hey guys, I tried searching but the terms were rather general and I did not come up with much that could be of help. I have a 2008 MazdaSpeed3 and I need an Intake Manifold core for a PNP project and since my Speed3 is my daily I cant have any down time. I don't have any experience with the Speed6s and a local guy has a bunch of them at a yard and is willing to part with a manifold. I've found a few Speed3 Manifolds but they're more expensive, and require shipping on top of that, so if I can save a few bucks for other things that'd be great, but I won't skimp on something that won't easily be swapped out.
Pretty simple question: Will a Gen1 Speed6 Intake Manifold fit on a Gen1 Speed3? If any modifications are needed, what may they be?
Thanks in advance!
2008 Cosmic Blue Mica Grand Touring - Purple Drank Tuned // AutoTech Internals // COBB AccessPort V3 // BNR S3 Turbo // ATP Catless Downpipe // HKS Hi-Power Exhaust // Treadstone TR8 FMIC Core // JBR FMIC Piping // HTP 3.5" Intake w/ Tray // GoFastBits TMS Respons Bypass Valve // JBR Bypass Tube // Damond EGR Delete // Damond Short Shift Plate // JBR Counterweight // Grimmspeed 3-Port EBCS // 3 Bar MAP Sensor // NGK 6510 Spark Plugs
Parts Collection - Damond Oil Catch Can // Sonic Tuning Coilovers // JBR Tru-Torsion.125 Rear Sway Bar + Brackets // CP-E Triple Gauge Pod // AEM Gauges: Boost, Wideband, Oil Pressure w/ Damond Sender Unit
Future Plans - E85 // Damond PMM & TMM // AEM Meth Kit
VirtueMS3 is offline   Reply With Quote
 Old 02-18-2015, 06:35 AM   #2
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
Yup, the IM's are the same.
340hp / 371tq
Code Monkey (02-18-2015), Mauro_Penguin (02-18-2015)
 Old 02-18-2015, 08:36 AM   #3
I doubt someone has a bunch of speed 6 s in a yard. Make sure you don't get an intake manifold off a regular four cylinder Mazda 6
sporkbomb (02-18-2015)
 Old 02-18-2015, 10:36 AM   #4
sporkbomb's Avatar
Posts: 295   (View Stats)
sporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the world
I guess the term, "bunch', is usually relative when used. Suppose "bunch" is equivalent to "three". Would that be so hard to believe despite the low production numbers of said vehicle?
Ultimately though ... your advice is absolutely useful -- especially to someone who has shit for brains and has somehow misplaced a clue.
2007 MS3 GT
Autotech CDFP Internals || Cobb AP, SRI, TIH, DP, CB, BPV, EBCS, FSB & RSB || cp-e Injector Seals, EGR Delete|| JBR OCC, Shifter Plate, PMM & TMM, TB & Intake TIG, Coolant Bypass|| Mazdaspeed Coilovers || TRZ RMM|| TWM Bushings || MOOG Front & Rear Endlinks
2006 MS6 GT (ZZB Rebirth)
Autotech CDFP Internals || BNR Stage 3 || Bosch 3 Bar || Cobb AP || cp-e Injector Seals, CBE, DP || ETS TMIC || Full Race EM || H&R Coilovers || JBR Mounts, 3.5" WP Aluminum Intake || Matt Damond OCC, Shifter Plate, EGR Delete || Racing Beat Rear Endlinks || Relentless PnP IM || SPC Balljoints || Whiteline RSB || The Company of Which I Will Not Name Front & Rear Diff Mounts
1990 Miata
I like it raw
sporkbomb is offline   Reply With Quote
 Old 02-18-2015, 10:39 AM   #5
Heck it's pretty rare to see more than one Speed6 even at a NATOR meet, much less several of them in a bone yard available to be picked over...
340hp / 371tq
Easter Bunny (02-18-2015), sporkbomb (02-18-2015)
 Old 02-18-2015, 10:44 AM   #6
it would definitely be surprising
 Old 02-22-2015, 09:13 PM   #7
VirtueMS3's Avatar
Hey all. First I would like to thank @TiGraySpeed6 for the quick result. To the others, I thank you for your concern but this would be purchased from an acquaintance of mine. He works at a local yard... yes yard, who specializes in imports: Hondas, Speeds, 350z, G35, etc. He had 6 in the lot, but now has 4. He is awaiting the word on if his partner wishes to sell the engines as a whole or if he is going to part them. *taps foot*
I know its not common, but its possible!
~ Ryan
The Following User Says Thank You to VirtueMS3 For This Useful Post:
TiGraySpeed6 (02-23-2015)
Page generated in 0.27954 seconds with 23 queries
