 Old 04-06-2013, 12:34 AM   #1
Stew's Avatar
Posts: 176   (View Stats)
Stew has a reputation beyond reputeStew has a reputation beyond reputeStew has a reputation beyond reputeStew has a reputation beyond reputeStew has a reputation beyond reputeStew has a reputation beyond reputeStew has a reputation beyond reputeStew has a reputation beyond reputeStew has a reputation beyond reputeStew has a reputation beyond reputeStew has a reputation beyond repute
Default 18.5 PSI??? What's going On???
I was driving around tonight and noticed my boost spiking on my boost gauge. So I decided to plug in my AP and double check. Sure enough, it was spiking to as much as 18.6 psi before settling back down to 16.5. I took a few logs so that I can see what is going on.
My mods are:
I just this week put on a Cobb SRI and Corksport TIP. I also have an AP of course
Corksport RMM, MT-90 trans fluid, Short Shift Plate
I am running the Stage1+SF+TIH 93 v231 map. One possible reason for the overboost could be that this tank is only 91 octane. Just wanted to see if anyone had input, cause as the map description states, Peak boost is supposed to be 16.5 psi.
Stew is offline   Reply With Quote
 Old 04-06-2013, 12:51 AM   #2
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,992   (View Stats)
Groans: 546
post a log, goddamnit, not some screenshot, then maybe someone can help you.
preferably a solid 4th gear log.. 2500 - 6500 rpm.
94 M
MS6
IS350
 Old 04-06-2013, 12:59 AM   #3
Stew's Avatar
Ok. Wasn't sure if I could upload an excel file. Probly should have read the valid file extensions.
Here are the actual logs.
 Old 04-06-2013, 03:06 PM   #4
boostdmazda3's Avatar
Posts: 1,177   (View Stats)
boost spiking and holding are two very different things.
boostdmazda3 is offline   Reply With Quote
 Old 04-06-2013, 03:16 PM   #5
6Y MAZDA's Avatar
Posts: 1,775   (View Stats)
WAIT...
You said you have a CS SRI but you are running a Stage1+SF+TIH 93 v231 map....Wtf.
You're supposed to run the Stage1+CS+TIH map...
1996 Miata
 Old 04-06-2013, 05:38 PM   #6
Stew's Avatar
No. I have a COBB SRI and a CS TIP. I reflashed the map to the correct 91 octane today when I filled up. MAybe that will fix the issue. I'll have to run a couple more logs and see.
 Old 04-06-2013, 05:43 PM   #7
6Y MAZDA's Avatar
My bad, i swear i saw CS SRI lol. Reading fail.
Using the wrong octane shouldnt affect boost though. Probably just need to adjust your WGDC tables.
1996 Miata
 Old 04-06-2013, 05:56 PM   #8
Stew's Avatar
That's ok. Alright, so I'm totally new to the whole tuning thing. What are WGDC tables? I don't even know exactly what all the columns on the chart mean or what they should be. I have been trying to read up on it.
STewart
EDIT: I do know the basics, but I thought that WGDC tables were only for using ATR?
 Old 04-06-2013, 06:56 PM   #9
6Y MAZDA's Avatar
STewart
Yes, you'd have to edit the WGDC tables in ATR.
EDIT: I just looked at the two logs you posted...i don't see 18psi anywhere. I see 14-16.5 psi. Looks right to me.
Only 2 cells of 17.5 but OTS maps are +/- 1.5 degrees of what they claim.
Your logs are fine. I wouldn't adjust anything...at least nothing to worry about. Like i said...OTS maps are +/- 1.5 degrees of what they claim. It even says that on the Map notes.
1996 Miata
The Following User Says Thank You to 6Y MAZDA For This Useful Post:
Stew (04-06-2013)
 Old 04-06-2013, 07:11 PM   #10
Redline143's Avatar
Posts: 930   (View Stats)
Redline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the world
If you are overboosting, lower your commanded WGDC to 5 below the values trend your logs show for each 1psi you're overboosting to see if it helps--most of the time this addresses the issue. 5 is just a starting point--each car responds differently...
Redline143 is offline   Reply With Quote
 Old 04-06-2013, 10:40 PM   #11
Stew's Avatar
Ok, thanks. How do I get ahold of a copy of ATR? I didn't get one with my AP.
You are right 6Y Mazda, it does say +/- 1.5, I was just worried about over boost. I have another log with a couple 18+ psi in it. Those were just a little shorter so I posted them. I'm going to try a couple more logs when I get a chance and see what happens with the map change.
STewart
 Old 04-06-2013, 10:51 PM   #12
Hoyoman's Avatar
Posts: 302   (View Stats)
Hoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the world
Groans: 43
Groaned at 6 Times in 3 Posts
Go to cobb website press atr and submit application and they will send you your copy through email
2012 black mica MS3 ; 3.5 HTP/ Catless DP/ AT HPFP/ APV2/ FMIC/ GFB BOv/ 3" CBE/ RMM/ XXR 530(18x9 +33)/ NT05 245/40/18/ 3bar map/ 3 port EBCS/ bnrs3/ DO stg2 dvc30/ REAR swaybar/ EBC Yellow/ CS Inj seals/ PNP IM/ Manley H-Beam/ Manley platinum piston 87.5/ soon...... PI+ BNRs6+ 44mm TIAL+ ACT 6 puck
E35 meth d012 26psi 420/451 self tuned/built
Hoyoman is offline   Reply With Quote
 Old 04-06-2013, 10:52 PM   #13
IlleztImportz's Avatar
Posts: 169   (View Stats)
IlleztImportz has a reputation beyond reputeIlleztImportz has a reputation beyond reputeIlleztImportz has a reputation beyond reputeIlleztImportz has a reputation beyond reputeIlleztImportz has a reputation beyond reputeIlleztImportz has a reputation beyond reputeIlleztImportz has a reputation beyond reputeIlleztImportz has a reputation beyond reputeIlleztImportz has a reputation beyond reputeIlleztImportz has a reputation beyond reputeIlleztImportz has a reputation beyond repute
STewart
You get ATR by going on the Cobb website. But before that, you should read a few of these stickies MazdaSpeed 3/6 - ECU Computer Tuning - Mazdaspeed Forums . I learned quite a bit before I actually started messing with ATR and calibrations.
IlleztImportz is offline   Reply With Quote
The Following User Says Thank You to IlleztImportz For This Useful Post:
Stew (04-06-2013)
 Old 04-06-2013, 10:55 PM   #14
Stew's Avatar
I actually just started reading those last night. I downloaded a couple of the guides and when I get time, I'm gonna start trying to understand them. Will be ordering HPFP internals soon so that I can keep going with mods. And more mods is a motivation to learn about ATR. Thanks for the help.
Page generated in 0.32356 seconds with 26 queries
