 Old 01-21-2012, 06:09 AM   #1
Copper's Avatar
Posts: 6   (View Stats)
Copper is an unknown quantity at this point
Default -30 Celsius and Stock Turbo
Hey all,
I live in Alberta, and last couple of days have been quite cold...and my Mazdaspeed6 hasn't been liking it!
First of it stutters during cold starts, to a point it turns of 2 seconds later, and I have to hold rpms at 2.5 to keep it going for a minute.
Secondly, it stuttered when running yesterday, rpms started falling, as if it was running out of gas.....I smelled a burning smell in the cabin and engine bay... almost as if plastic melting.... but I saw no smoke...and the car turned of.
10 Minutes later, the car started and ran properly ever since....until today...the rpms started falling again when stopped on a stop sign, same smell again.... but this time it stayed on... the burning smell is in the exhaust now, constantly!
My question is.... is it possible the turbo is going? burning oil when stopped? or am I looking at something different?
Thanks in advance!
[SIGPIC]06 MS6/// Edmonton[/SIGPIC]
Copper is offline   Reply With Quote
 Old 01-21-2012, 06:22 AM   #2
MrShark's Avatar
Posts: 289   (View Stats)
MrShark is the leader of the worldMrShark is the leader of the worldMrShark is the leader of the worldMrShark is the leader of the worldMrShark is the leader of the worldMrShark is the leader of the worldMrShark is the leader of the worldMrShark is the leader of the worldMrShark is the leader of the worldMrShark is the leader of the worldMrShark is the leader of the world
Hasn't been quite that cold in NY, but I did have a similar issue. It wound up being a cracked coil pack, moisture got in because of the heating cycle and allowed it to arc. Not implying it's your issue but sounds similar, any CEL?
MrShark is offline   Reply With Quote
 Old 01-21-2012, 07:54 AM   #3
Bob-o's Avatar
Posts: 1,312   (View Stats)
Hell yeah! Another Albertan!
My car takes a second to start as well, but once it does its alright... So it may just be you. Have you tried cleaning your MAF?
 Old 01-21-2012, 08:48 AM   #4
predapio's Avatar
Posts: 8,939   (View Stats)
Groans: 309
Holy fuck that's cold.
What a lovable bunch we are!!
cld12pk2go (01-21-2012), daafisch (01-21-2012)
 Old 01-21-2012, 08:53 AM   #5
MS309's Avatar
Posts: 673   (View Stats)
MS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the world
Didn't Q have the same issue? @MZDSPD.
'11 CWP Speed3
More torque than your right arm.
MS309 is offline   Reply With Quote
 Old 01-21-2012, 08:54 AM   #6
kritz's Avatar
Posts: 7,290   (View Stats)
Groans: 95
Also have you tried moving about 1500 -2000 miles south?
Nator is what it does.
The Following 8 Users Say Thank You to kritz For This Useful Post:
asall667 (01-28-2012), cld12pk2go (01-21-2012), daafisch (01-21-2012), Docnox (01-29-2012), Easter Bunny (01-21-2012), phate (01-25-2012), predapio (01-21-2012), psychophyr (01-29-2012)
 Old 01-21-2012, 08:54 AM   #7
Sid3wayS's Avatar
Posts: 6,790   (View Stats)
Groans: 97
Might want to look into wolverine oil pan heaters.
TEAM LUXURY
 Old 01-21-2012, 10:47 AM   #8
Bob-o's Avatar
Q's problem was PCV
 Old 01-21-2012, 11:32 AM   #9
Dmurray06's Avatar
Posts: 3,279   (View Stats)
More Albertians....good to see, hope everything is fine, but id get it checked out for sure.
 Old 01-21-2012, 05:20 PM   #10
Frequentflyer's Avatar
Posts: 1,959   (View Stats)
Originally Posted by Copper View Post
Hey all,
Thanks in advance!
Try to get some spark plugs in a hotter heat range, but for some reason I dont think its cold related.
Tapa-daba-do
Frequentflyer is offline   Reply With Quote
The Following User Says Thank You to Frequentflyer For This Useful Post:
 Old 01-21-2012, 06:42 PM   #11
Copper's Avatar
I just checked and my coolant seems quite low!!! So im kinda fearing a head gasket might have gone?
Also today is only -14 (T-shirt timeee), and its no longer smoking as much of the white smoke, nor is there a melting smell to it.
Another thing I noticed lately, and I know winter weather isnt helping, but all I am getting per tank is around 300km! Is it just me?
LMAO
 Old 01-21-2012, 07:08 PM   #12
kritz's Avatar
Groans: 95
It is dipping below 20 degrees F tonight so I plugged in the wolverine pan heater! lol
 Old 01-21-2012, 07:13 PM   #13
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
Hey all,
Thanks in advance!
If you have a tuning solution like an AP, then you can increase your idle RPM tables for low temp to keep it running.
 Old 01-22-2012, 12:38 AM   #14
MS309's Avatar
LMAO
lol idk have you been idling the car more ? Letting it warm up for 10 mins ? Etc ? I just filled up tonight after our harsh week, got 400 kms, still ha two bars left. Does awd suck up another 100 kms of gas ? Idk I'm drunk, so thank god for autocorrect.
'11 CWP Speed3
 Old 01-23-2012, 08:54 AM   #15
steedspeed's Avatar
Posts: 582   (View Stats)
steedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the world
I suggest moving to BC. When its minus 30+ in Alberta it is only minus 17 here in the Okanagan Valley. Way less mosquitos in summer too!
steedspeed is offline   Reply With Quote
 Old 01-23-2012, 09:24 AM   #16
MS309's Avatar
I don't think I'd be able to afford 91 octane anywhere in BC.
'11 CWP Speed3
 Old 01-23-2012, 09:34 AM   #17
zkrick's Avatar
Posts: 447   (View Stats)
zkrick is the leader of the worldzkrick is the leader of the worldzkrick is the leader of the worldzkrick is the leader of the worldzkrick is the leader of the worldzkrick is the leader of the worldzkrick is the leader of the worldzkrick is the leader of the worldzkrick is the leader of the worldzkrick is the leader of the worldzkrick is the leader of the world
Groaned at 48 Times in 7 Posts
WTF is Celsius?!? Im from america i speak AMERICAN!
2012 Black Mica MazdaSpeed 3 Tech
. H & R Springs . . Sure Counter weight . . Sure anchors . . Sure Shortcut . . Sure RMM . . Injen CAI . . Cobb TIP . . Cobb Tuning XLE BPV . . JBR Knob .
You mad bro?
Originally Posted by Mazdaspeed_3 View Post
I ain't donating shit.....
YOU AND YOUR PUNK ASS HOMMIES CAN
Kick
Fucking
ROCKS!
zkrick is offline   Reply With Quote
 Old 01-23-2012, 09:39 AM   #18
SRTie4k's Avatar
Posts: 1,715   (View Stats)
SRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the world
Groaned at 68 Times in 44 Posts
Maybe you should invest in an electric block heater.
08.5 Mazdaspeed 3 - Cobb AP w/ Boost Targetting at 17psi, CP-E Nano SRI, ETS 3.25" TMIC, SU Test Pipe, CP-E RMM, Bilstein Sports, Cobb Springs, Progress RSB, Short Shift Plate, SU Solid Shifter Bushings, Dashhawk, Gold 18x8.5 Rota G-Force's, 235/40/18 Hankook Ventus V12's
253WHP/274WTQ on a Mustang Dyno before tune, 282WHP/318WTQ in VD after tune
97 Suzuki TL1000S Naked - LeoVince Slip-Ons, K&N Filter, PCII, fully custom naked setup
89 Kawasaki 650SX Stand-Up Jetski
SRTie4k is offline   Reply With Quote
 Old 01-28-2012, 06:30 PM   #19
Poohster's Avatar
Posts: 353   (View Stats)
Do you have an OCC? If so, that might be frozen. Or PCV frozen. Try putting parking in a warm garage. GL.
06 MS6, Blk Mica, MS wheels 18x7.5, Conti DWS P225/45-18, Magnaflow CB, Autometer Boost gauge, CS Strut bar, Bilstein shocks, Redline Tuning QuickLIFT, TT Diff Frt mount, SP slotted rotors, Hawk pads, Whiteline RSB, JBR Thermal Gaskets. Cobb AP, GTX2867r, Snow Stage2 WMI, Southbend Stage 3 Enduro clutch. HTP 3 in TIP
CP-e: HPFpump, Xcel CAI, DP, Tial w/ BOV Flange, gauge pod, TMIC, Safeseals, MZRevolved Stage 2 block, RMM, LTRmani, xFlex diff mount
Poohster is offline   Reply With Quote
 Old 01-28-2012, 07:00 PM   #20
MZDSPD's Avatar
Posts: 152   (View Stats)
MZDSPD has a reputation beyond reputeMZDSPD has a reputation beyond reputeMZDSPD has a reputation beyond reputeMZDSPD has a reputation beyond reputeMZDSPD has a reputation beyond reputeMZDSPD has a reputation beyond reputeMZDSPD has a reputation beyond reputeMZDSPD has a reputation beyond reputeMZDSPD has a reputation beyond reputeMZDSPD has a reputation beyond reputeMZDSPD has a reputation beyond repute
Sorry for the late reply guys.. Mine was the purge valve. It would start and then stall out and it would do this two or three times before running okay. Also the exhaust would pop when cold idling.
I ordered a new one from Mazda and no issues.
No CEL either.
TWM-AP-Sure-SU
MZDSPD is offline   Reply With Quote
 Old 01-28-2012, 11:13 PM   #21
madspd6's Avatar
Posts: 1,009   (View Stats)
madspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the world
Groans: 31
Humm, my speed6 has loved out cold weather. its the 20psi and a stock cdfp it hates.
madspd6 is offline   Reply With Quote
 Old 01-29-2012, 09:52 PM   #22
toeknee's Avatar
Posts: 20   (View Stats)
toeknee will become famous soon enough
im from alberta too, but own a ms3. that cold weeked sucked big time!
toeknee is offline   Reply With Quote
Q Tires testing Celsius retractable-stud snow tires Haltech Automotive News 0 04-01-2008 10:40 AM
Page generated in 0.38646 seconds with 36 queries
