Like Tree3Likes
  • 1 Post By someguy
  • 1 Post By ABolewski
 Old 08-13-2014, 06:33 AM   #1
ttgeoff's Avatar
Posts: 25   (View Stats)
ttgeoff is a name known to allttgeoff is a name known to allttgeoff is a name known to allttgeoff is a name known to allttgeoff is a name known to allttgeoff is a name known to all
Default 4" intake and blow through maf
Need some opinions on my current plans. I am currently fabbing a fmic on my MS6 and i feel pretty strongly that i should convert to a blow through maf and then fab up a 4in intake and run my tial 50mm BOV thats just sitting on the shelf from a previous car. Will i run into issues with this maf combo. to help it is going to be a stock size maf housing with a straightner and about 10" of straigt pipe before the sensor. any help would be appreciated
ttgeoff is offline   Reply With Quote
 Old 08-13-2014, 06:48 AM   #2
chaser27's Avatar
Posts: 1,276   (View Stats)
Groans: 42
Just curious, why use a 4" intake assumingly on a K04? and then go to a stock 2.5" blow through MAF housing?
Coming at ya with all 297/359
ECU: self-tuned
RADAR: Passport Escort 9500ci
The Following 2 Users Say Thank You to chaser27 For This Useful Post:
anavrinIV (08-13-2014), Vansquish (08-26-2014)
 Old 08-13-2014, 06:57 AM   #3
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
The larger intake will flow more and the stock MAF sizing in a blow-through setup will work better with drivability than the 4".
That said it's a pointless exercise on the k04 IMO, I could flow enough through a stock size intake to max my k04 and made the same power and torque with a corksport intake as I did with a 3.5" JBR.
Blue Pu.
The Following 4 Users Say Thank You to anavrinIV For This Useful Post:
chaser27 (08-13-2014), Mauro_Penguin (08-13-2014), ttgeoff (08-13-2014), Vansquish (08-26-2014)
 Old 08-13-2014, 07:59 AM   #4
chaser27's Avatar
Groans: 42
That's what I was getting at. Was he getting ready for a bigger turbo? Even then I'd go 3" blow through instead of the 2.5". But honestly, I'm not sure it's worth it to go blow through vs blow by. Sounds like more trouble than it's worth to me.
ECU: self-tuned
 Old 08-13-2014, 07:25 AM   #5
ttgeoff's Avatar
thats good to know as i currently have a corksport but i still plan on running the blow through and eventually upgrading the size of the maf but as of now it will handle my power level just fine. i have very near plans on going to a gtx3076 and cpe manifold and im just doing work in preporation of those mods. im more concerned with tuning and or driveability on the blow through as i am fairly certain it will not hurt to free up the intake side even if not needed on the K04
 Old 08-13-2014, 08:31 AM   #6
someguy's Avatar
Posts: 914   (View Stats)
For no other reason other than blow through and BOV's are cool I say do it
ttgeoff likes this.
 Old 08-15-2014, 08:08 AM   #7
ttgeoff's Avatar
So is there going to be any driveability issue with the blow through set up? I have had great success with my twin turbo mustang converting to blow through but all cars are different.
 Old 08-15-2014, 08:38 AM   #8
ABolewski's Avatar
Posts: 1,279   (View Stats)
Many people are successful however most of those people use a honeycomb before the MAF in a blow through setup.
Also, I highly highly highly recommend going with a 3" MAF housing for your blow through. The 2.67" housing (or w/e the fuck it is) will max out your MAF voltage much much sooner, and you are already going to have to tune for a blow through setup so might as well up the housing size.
ttgeoff likes this.
(sold)
 Old 08-15-2014, 12:43 PM   #9
ttgeoff's Avatar
thats definately easy enough to acomplish and thanks for the input. im totally sold on the honeycomb and have foud very good maf housings on treadstone so im pulling the trigger and hope to post pics soon.
The Following User Says Thank You to ttgeoff For This Useful Post:
ABolewski (08-15-2014)
 Old 08-24-2014, 06:52 PM   #10
ABolewski's Avatar
My blow through housing is ready for instal next weekend. Pretty excited to see how well it works. I'm really hoping it will support ~450hp before maxing out the voltage but if it doesn't I'll make a 3.5" setup and swap it out.
ttgeoff likes this.
(sold)
The Following 3 Users Say Thank You to ABolewski For This Useful Post:
chaser27 (08-25-2014), Code Monkey (08-24-2014), torquemaniac (09-25-2014)
 Old 08-26-2014, 08:18 AM   #11
ttgeoff's Avatar
ive decided to go 3.5" from the start and will start working on the set up in a few weeks when my school/work schedule allow time to do some small fab work
 Old 09-25-2014, 01:54 PM   #12
ttgeoff's Avatar
I now have all the materials to start my build just waiting on time.
3.5" maf from treadstone $67.50
3.5" maf honeycomb $25
4" u-bend $24
3.5" and 4" couplers $30
4" filter 9" long $32
for more giggles i went ahead a bought
T3 GT30r .82 v band and a SS T3 manifold to help with needing a big maf and big intake. pics soon to come and will include modified M2 dp with recir MV-S and custom but easy intake fab
The Following 2 Users Say Thank You to ttgeoff For This Useful Post:
chaser27 (09-25-2014), torquemaniac (09-25-2014)
Teased: Lotus to "blow the roof off" Geneva with a convertible? Haltech Automotive News 0 02-15-2012 09:20 AM
quiet or quietest blow off valve, air intake, downpipe bldhndzgng MazdaSpeed 3 - Engine, Transmission & Driveline 15 07-06-2010 12:23 PM
Page generated in 0.34633 seconds with 25 queries
