Like Tree7Likes
  • 1 Post By dale_gribble
  • 1 Post By someguy
  • 2 Post By RalliartRsX
  • 1 Post By speedfreak44
  • 1 Post By Dat8687
 Old 06-11-2014, 01:35 AM   #1
dale_gribble's Avatar
Posts: 4,720   (View Stats)
Default 6 MS6s have bad choke point in TMIC cold tube
This is probably common knowledge but I literally had no idea after years of ownership. I have been investigating opening up my OEM intercooler cold pipe because the taper down from the intercooler flange visually looks like a choke point. I attached some pics I found of the neck inlet compared to the outlet.
I was getting ready to have my cold pipe cut and welded out to open that neck up like this guy in the pic I posted below. Then my buddy brought me an 07+ cold pipe and the thing was WAY more opened up in the neck area. You can see that here.
I found some measurements online of the 06 pipe vs. the 07 pipe.
The 06 pipe is 5.28 sq inch at the intercooler gasket area and drops to 2.51 sq inch at the pinch area and 4.91 sq inch at the throttle body end of the pipe.
The 07 pipe is 5.28 sq inch at the intercooler gasket area and drops to 3.11 sq inch at the pinch area and 4.91 sq inch at the throttle body end of the pipe.
The 07 pipe has 20% larger area in that pinch area and the pipe is generally opened up quite a bit more throughout. I am guessing that Mazda knew the 06 cold pipe flowed like crap but didn't have time to revise it before early shipments and revised it as soon as possible. It's one thing to have the aftermarket fix a problem, but you know its a big deal when the OEM revised a part bigger. This tells me I'm onto something.
I don't know how this extra flow will impact performance on a k04, but I am willing to bet it's going to make a good difference on my bnr, especially considering how opened up everything else is on my intake/exhaust. Wouldn't it be crazy if this stupid cold pipe has been holding my car back all along?
I am using my buddies 07 cold pipe, I ordered some JBR cold tubes and a Snow meth tap for the silicone tube so I can swap the setup in place of my 06 cold pipe. I will definitely post up before/afters, but my gut says there will be gains above the noise floor.
I don't know how many others with older 6 speed 6's knew this. I sure as shit didn't.
ItsNox likes this.
MINI H1 6.0 - CAR LED TAILS
The Following 10 Users Say Thank You to dale_gribble For This Useful Post:
blackmicamps6 (06-11-2014), Cheapspeed (10-03-2015), Chicagospeed6 (06-11-2014), Code Monkey (06-11-2014), Easter Bunny (06-16-2014), ItsNox (06-15-2014), speed23 (06-16-2014), Vader (06-11-2014), Vansquish (06-11-2014), WetzMS3 (06-11-2014)
 Old 06-11-2014, 01:53 AM   #2
Hargarbl's Avatar
Posts: 642   (View Stats)
Groans: 51
That's a good find. I wonder how hard it would be to get rid on the stock cast outlet and for someone to make an aluminum mandrel bent peice instead. I think that would help improve the flow coming out of the intercooler and would also eliminate that bottle neck.
 Old 06-11-2014, 01:59 AM   #3
Its not that easy with the stock intercooler flange, I.e. welding flange to mandrel pipe. The pipe hugs right up against the intake runners on the back side. There is room towards the front of the engine though to expand out.
Corksport did experiment with a big cold pipe years ago but insisted their tmic was the bottleneck and that the pipe didn't matter; they didn't build it. I didn't think that spoke much for their tmic.
There is room for something creative, I'm just not sure you can do tubing right off the flange without clearance issues. .
 Old 06-11-2014, 02:06 AM   #4
Hargarbl's Avatar
Groans: 51
I did some searching and found out trz made a tmic, looks like they had the right idea for the cold side
The Following 3 Users Say Thank You to Hargarbl For This Useful Post:
aviator79 (09-25-2015), Cheapspeed (10-03-2015), dale_gribble (06-13-2014)
 Old 06-11-2014, 02:11 AM   #5
Fully6mps's Avatar
Posts: 10   (View Stats)
Fully6mps is a splendid one to beholdFully6mps is a splendid one to beholdFully6mps is a splendid one to beholdFully6mps is a splendid one to beholdFully6mps is a splendid one to beholdFully6mps is a splendid one to beholdFully6mps is a splendid one to behold
Never knew that Mazda themselves revised the part, but think autoexe had an aftermarket version? Called it an air charger or similar. Keen to see what changes the switch will make, have a 2005 mps here in Aus so assume have the same bottleneck.
Fully6mps is offline   Reply With Quote
 Old 06-11-2014, 02:16 AM   #6
Hargarbl's Avatar
Groans: 51
I think I found what you are talking about, this is the best picture I could find right now.
Edit: found it
http://www.nengun.com/autoexe/turbo-suction-kit
 Old 06-11-2014, 07:04 AM   #7
scubasteve711's Avatar
Posts: 1,238   (View Stats)
scubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the world
Groans: 70
Will be interested to see what kind of difference it makes! I remember working on one of the NATOR guys cars here in CT and at the time didn't realize there was a difference there!
07' Speed6 Velocity Red Mica
Go Faster: CorkSport SRI/TIP, SU Test Pipe, SU TMIC, Autotech Internals, ITV22's, Cobb AP
Anti break stuff: Upper Rear Diff Brace, RMM
Appearence: STRI DSD Boost Guage/Blockhead 60mm Guage Pod
scubasteve711 is offline   Reply With Quote
 Old 06-11-2014, 07:16 AM   #8
meth nozzle hole pre-drilled is a nice touch too.
 Old 06-11-2014, 08:34 AM   #9
Spec's Avatar
Posts: 4,472   (View Stats)
@SparkySparks;
 Old 06-11-2014, 08:53 AM   #10
SparkySparks's Avatar
Posts: 1,314   (View Stats)
I was actually working on opening up a 06 MS6 coldpipe that came with the TMIC I just picked up and noticed it was slightly smaller as I was having a hard time getting it all smoothed out. I also noticed that the opening in the flange both on the TMIC and the coldpipe are smaller then the gasket's opening so I ported the openings to match the gasket and smoothed out as much as I could. Not sure if this is going to help much if any but figured it shouldn't hurt either and it is a free mod.
Guess I will be selling the MS6 cold pipe and using my Gen2 pipe.
On Order:
Coming Soon:
DIY Projects:
 Old 06-11-2014, 09:21 AM   #11
Oh and just encase anyone was wondering, the choke point on both versions is still smaller then 2.5"(4.9088"^2) piping used for most FMICs, even 2"(3.1416"^2) piping is slightly better then the revised cold pipe.
On Order:
Coming Soon:
DIY Projects:
 Old 06-11-2014, 09:25 AM   #12
someguy's Avatar
Posts: 914   (View Stats)
I did the same on the my cpe TMIC. The actual cold pipe was pretty close to gasket size though.
CorkSport likes this.
 Old 06-11-2014, 09:35 AM   #13
5LOWMS6's Avatar
Posts: 1,088   (View Stats)
5LOWMS6 is the leader of the world5LOWMS6 is the leader of the world5LOWMS6 is the leader of the world5LOWMS6 is the leader of the world5LOWMS6 is the leader of the world5LOWMS6 is the leader of the world5LOWMS6 is the leader of the world5LOWMS6 is the leader of the world5LOWMS6 is the leader of the world5LOWMS6 is the leader of the world5LOWMS6 is the leader of the world
Groans: 46
Groaned at 37 Times in 19 Posts
is that still available? I would've definitely bought that instead of the cpe.
fuck the 06 cold pipe. I knew it was a restriction just like that pos stock tip, but the cold end flange itself on all of the aftermarket tmic's would be the next issue as mentioned above if you only upgrade the cold pipe to ones like the autoexe. so what's the point?
I don't think the cold pipe itself will make any difference unless on a BT, and the gains will still be negligible.
06 Liquid Platinum GT
COBB AP // 3" ID MAF // 3" HTP TIP // Ebay catless DP // Autotech FPI // DO DVC-30 w/D07 // Grimmspeed EBCS // FORGE V1 BPV // DM OCC // JBR SSP|TIGs|EGR- // SURE RMM|Juggernaught // CP-E TMIC|Rear Diff Mount // Whiteline RSB // ISC N1 Coilovers // 18x8 +45 TSW Nurburgring
MisterSix Tuned..
vdyno: 287hp/335tq Uncorrected (2400ft ASL) 303hp/355tq Corrected
5LOWMS6 is offline   Reply With Quote
 Old 06-11-2014, 09:39 AM   #14
Yes, the cold pipe was only off by about a sharpie width while the CP-E TMIC was off by a bit more. The casting was also not all that great (smooth) on the inside of either end tank.
On Order:
Coming Soon:
DIY Projects:
 Old 06-11-2014, 10:39 AM   #15
@kashbringer; I wonder if this was a possible limitation with how much you were pushing the K04.
On Order:
Coming Soon:
DIY Projects:
 Old 06-16-2014, 08:51 AM   #16
Guys, just an update, this went nowhere after comparing before/after tests of 06 cold pipe vs. 07 cold pipe. No gains were had with the 07 cold tube FML. Kind of shocked, but it is what it is. It is a choke point, but as @CorkSport; previously reported on their cold tube research, the intercooler is a greater choke point so the cold tube isn't an issue. Definitely a case of mind/physics playing tricks on me.
ItsNox (06-16-2014), Spectrix (06-17-2014)
 Old 06-16-2014, 09:23 AM   #17
5LOWMS6's Avatar
Groans: 46
I wonder if the width of a tmic will make a difference in the case of it being less of a choke point since the air will go through less space. The problem is there isn't a way to test that.
MisterSix Tuned..
 Old 06-16-2014, 10:32 AM   #18
is the 07 MS6 the same as the cold pipe used on all the MS3's could the later PU's also have a revision?
 Old 06-16-2014, 10:38 AM   #19
When you are pressurizing air choke points such as these have less of an effect. If you go too big on the piping you actually lose response.
Good find and testing.
On that TRZ TMIC, I would not get something that doesn't seal to the OEM shroud. The MS6 already has the hardest time (compared to an MS3) channelling air to the TMIC and cooling it.
 Old 09-25-2015, 11:19 AM   #20
SNOW_QN's Avatar
Posts: 384   (View Stats)
SNOW_QN is the leader of the worldSNOW_QN is the leader of the worldSNOW_QN is the leader of the worldSNOW_QN is the leader of the worldSNOW_QN is the leader of the worldSNOW_QN is the leader of the worldSNOW_QN is the leader of the worldSNOW_QN is the leader of the worldSNOW_QN is the leader of the worldSNOW_QN is the leader of the worldSNOW_QN is the leader of the world
Edit: found it
Thread revival!
Was thinking about this today since it seems to be a major restrictive point. Has any tried this aftermarket elbow?
I know that you @dale_gribble; have done the 06 vs 07 comparison but they seem too similar to possibly have any significant differences. It seems like the autoexe would be much smoother, and have a noticeable difference.
Anyone have any data on this?
Sent from my SCH-I545 using Tapatalk
06 MS6: Stocked out and trying to find her a new family.
SNOW_QN is offline   Reply With Quote
 Old 09-25-2015, 11:39 AM   #21
Omega's Avatar
Posts: 441   (View Stats)
Subbed for interest, I really doubt there will be any gains, if the 06 cold pipe with the smallest surface area wasn't choking going to an even bigger flange still wouldn't make an impact (there's no choke to "fix").
Maybe if you're on a turbo that's quite a bit bigger but unless it's a GTX30xx I don't think it would make any difference and the difference would probably be negligible.
2006 Super Clean BCM MS6
 Old 09-25-2015, 11:46 AM   #22
SNOW_QN's Avatar
I agree that a larger turbo would magnify any flow enhancement from the autoexe unit, but it seems like it should do something even on a smaller turbo setup. The design is much different than the difference between an oem elbow.
 Old 09-25-2015, 01:28 PM   #23
SNOW_QN's Avatar
@Dat8687; do you still have this piece?
 Old 09-25-2015, 01:39 PM   #24
speedfreak44's Avatar
Posts: 1,391   (View Stats)
Corksport designed a bigger one that had no impact on flow. The intercooler was more of a restriction even upgraded
The line up:
The Following 2 Users Say Thank You to speedfreak44 For This Useful Post:
Easter Bunny (09-25-2015), SNOW_QN (09-25-2015)
 Old 09-25-2015, 01:55 PM   #25
SNOW_QN's Avatar
You're crushing my dreams man. I'm hoping to find a way to avoid going fmic in the future, and was hoping this might help a little.
 Old 09-25-2015, 02:06 PM   #26
No dreams crushed. Let me break this down simple and sweet;
Tr6 or 8: Rpm sale comes to about $210
Underoute piping (bnr does it) on sale $470
Tmic cpe $360
Boost tubes $60
Hood scoop for better cooling $250
They break down to being almost exactly the same cost and fmic is way more efficient
The line up:
 Old 09-25-2015, 02:16 PM   #27
RalliartRsX's Avatar
Posts: 366   (View Stats)
RalliartRsX is the leader of the worldRalliartRsX is the leader of the worldRalliartRsX is the leader of the worldRalliartRsX is the leader of the worldRalliartRsX is the leader of the worldRalliartRsX is the leader of the worldRalliartRsX is the leader of the worldRalliartRsX is the leader of the worldRalliartRsX is the leader of the worldRalliartRsX is the leader of the worldRalliartRsX is the leader of the world
The pressurized, "high" velocity air (as being pumped from the compressor) that is flowing at or below Mach 0.3-0.4 is not entirely sensitive to minor increases/decreases in flow area as opposed to air flowing with at 1 atmosphere (standard atmospheric pressure).
Simply put, don't waste your money.
Source: I am an Aerospace Engineer.
MS3Shadow and SNOW_QN like this.
RalliartRsX is offline   Reply With Quote
The Following 4 Users Say Thank You to RalliartRsX For This Useful Post:
Cheapspeed (10-03-2015), Easter Bunny (09-25-2015), redneck4Christ (10-02-2015), SNOW_QN (09-25-2015)
 Old 09-25-2015, 02:23 PM   #28
SNOW_QN's Avatar
Tmic cpe $360
Boost tubes $60
I really don't want to go through the hassle of hacking up my crash bar to accommodate a fmic. I'm sure the tr6 could be fit without cutting the bar, but is that any better than the having the cpe tmic that I already have?
Lol thanks @RalliartRsX; I'm convinced now that beating the dead horse is going to continue resulting in the same thing.
 Old 09-25-2015, 03:57 PM   #29
Did not see the cpe in your sig. I would stay with it and get the Cs hood scoop.
The line up:
 Old 09-25-2015, 04:02 PM   #30
But @SNOW_QN; has a MS6..
sent from my HTC One M9
 Old 09-25-2015, 04:04 PM   #31
Gah stop throwing me curve balls! Yea that's kinda hard to install on an ms6 lol. Fmic ftw
The line up:
 Old 09-25-2015, 04:09 PM   #32
Unless you can make the Gen 2 hood fit on a MS6. It'll work awesome.
Hood scoop is awesome for the TMIC.
I also don't want to cut up my crash bar either.
 Old 09-25-2015, 04:14 PM   #33
Tr6 flows 400whp. That's all our fueling does anyway and nobody really shoots past that anymore with supplemental fueling. I say go tr6 and call it a day. Treadstone shit is top notch
SNOW_QN likes this.
The line up:
 Old 09-25-2015, 04:51 PM   #34
SNOW_QN's Avatar
Hood scoop would certainly help, but it would be out of place on the subtle sedan.
I'll look more into the tr6. When the time comes to upgrade, maybe there will be another option or two out there. (Don't ruin my wishful thinking. I need something to hope for)
The Following User Says NO Thank You to SNOW_QN For This Un-useful Post:
mxlplx71 (09-25-2015)
 Old 10-01-2015, 11:34 PM   #35
Dat8687's Avatar
Posts: 257   (View Stats)
Dat8687 has a reputation beyond reputeDat8687 has a reputation beyond reputeDat8687 has a reputation beyond reputeDat8687 has a reputation beyond reputeDat8687 has a reputation beyond reputeDat8687 has a reputation beyond reputeDat8687 has a reputation beyond reputeDat8687 has a reputation beyond reputeDat8687 has a reputation beyond reputeDat8687 has a reputation beyond reputeDat8687 has a reputation beyond repute
Groaned at 60 Times in 22 Posts
I actually had 2.. One on my 6 and one on my speed 3 which Im selling on the car.
you can get it from around 375-450 from RHD japan
What it all comes with
This was it on my speed 6 several years ago
Fonsi likes this.
Dat8687 is offline   Reply With Quote
The Following 3 Users Say Thank You to Dat8687 For This Useful Post:
Boost_creep (10-03-2015), macdiesel (10-03-2015), Poohster (10-03-2015)
 Old 10-03-2015, 07:16 AM   #36
macdiesel's Avatar
Posts: 825   (View Stats)
That's one stout cold pipe. Notice any gains?
 Old 10-03-2015, 04:26 PM   #37
Dat8687's Avatar
I think its more about improving response and consistent pressure at the TB.. Meh maybe lol. The throttle did feel like it responded better
The Following User Says Thank You to Dat8687 For This Useful Post:
macdiesel (10-05-2015)
 Old 03-09-2019, 04:53 PM   #38
Federighi's Avatar
Posts: 53   (View Stats)
Federighi is a jewel in the roughFederighi is a jewel in the roughFederighi is a jewel in the roughFederighi is a jewel in the rough
Anyone know where to find the Autoexe TMIC cold charge pipe kit? Specifically looking for the elbow. New or used, any info is greatly appreciated. Thanks!
Federighi is offline   Reply With Quote
The Following User Says NO Thank You to Federighi For This Un-useful Post:
Vansquish (03-09-2019)
 Old 03-09-2019, 09:00 PM   #39
Police - Grammarhead
Vansquish's Avatar
Dude...5 years late to the party, and still can't use Google.
 Old 03-22-2019, 05:58 PM   #40
Federighi's Avatar
Better late than never!
If anyone has a used Autoexe turbo suction kit or knows where to find one, please let me know.
Thanks in advance!
Cold pipe tube - does it need heat wrap? mituc MazdaSpeed 3/6 - Turbo Induction 5 09-06-2011 07:15 AM
Page generated in 0.57688 seconds with 40 queries
