Like Tree103Likes
 Old 11-19-2014, 04:33 PM   #361
leka's Avatar
Posts: 144   (View Stats)
leka is a splendid one to beholdleka is a splendid one to beholdleka is a splendid one to beholdleka is a splendid one to beholdleka is a splendid one to beholdleka is a splendid one to beholdleka is a splendid one to beholdleka is a splendid one to behold
I my self paid $990 with shipping for a new CHARA for my Gtx2867 with shipping back to Sweden, the oil feed to the turbo was blocked...
Atp did not take it under warranty..
Mazdaspeed 6 2006
Sp63 Longblock with Mahle and manly, ported head, keyed crank and cams, stiffer springs, GTX2867R IWG, Freaks intake 4 inch,Autotech Internals, Stratified Ebc + GA, CP-E injector seals, CS Custom pipes FMIC, Snow performance stage2 100% meth, Cp-E decatted downpipe, Custom Catback with VareX mufflers, EGR Delete, SURE TMM+PMM+RMM, South Bend Clutch Stage3 Daily, CS rear diff mount, TurbineTech Front diff mount, CS rear swaybar, Racingbeat rear Endlinks, Matt Damond PS cooler, JBR OCC Stage 2, Bosch 3 bar MAP w/ PNP Harness, BC coilovers, Tenzo R Type M 19" 235/35, Sure Shortshift, Xcarlink, Speed performance Aux fan control, Synchronic DV BOV, DBA front rotor, Ebc yellow stuff(FR), EBC greenstuff (R), Stoptech brakelines and Finally, Tuned By Lex @ Stratified
Current INFO : tuning is paused due the winter.
Waiting to be installed: Cp-e exhaust manifold stock flange with MVR 44 external wastegate and dump tube.
leka is offline   Reply With Quote
 Old 11-24-2014, 12:47 PM   #362
ShadowHunter117's Avatar
Posts: 55   (View Stats)
ShadowHunter117 is a splendid one to beholdShadowHunter117 is a splendid one to beholdShadowHunter117 is a splendid one to beholdShadowHunter117 is a splendid one to beholdShadowHunter117 is a splendid one to beholdShadowHunter117 is a splendid one to beholdShadowHunter117 is a splendid one to behold
Well I am glad I stumbled across this thread. I got a GTX2867R kit from Edge and have been having oil issues since I got it. At first one of the oil drain line gaskets was improperly aligned causing a slight blockage and external leak there, but even after fixing that there has been oil in the compressor housing and FMIC piping. I have cleaned it out several times and checked for shaft play and there is none, but I am still getting oil leakage. I am hoping a different restrictor bolt might help things. I also read in another thread that a shorter oil drain line than the one supplied might be needed.
2011 Black Mica MS3
Engine: HTP 3.5" Intake, HTP Small Battery Box, GTX2867R Turbo, TR6 Intercooler w/CX Racing Pipe, PNP Stock Intake Mani w/ VTC Delete, Steadspeed Exhaust Mani, CNT Catted DP, 3" Magnaflow Exhaust, Autotech HPFP Internals, JBR OCC, JBR EGR Delete, 3-bar MAP Sensor, Grimmspeed EBCS, Forge BPV V2, Stratified Tuned
Handling: CS Lowering Springs, JBR Rear Swaybar, JBR PMM/TMM(70 duro) RMM(88 duro), GTSPEC Chassis Braces(Except trunk), Front Strut Tower Bar, 17x9 TRMotorsports C3 Wheels w/ 245/40ZR17 Michelin Pilot Sport A/S 3
Waiting to Install: Stratified Guardian Angel, Snow Performance Stage 2 Meth Kit w/Failsafe and Trunk Mount Tank
ShadowHunter117 is offline   Reply With Quote
The Following 2 Users Say Thank You to ShadowHunter117 For This Useful Post:
Cheapspeed (11-24-2014), meicalnissyen (04-25-2015)
 Old 11-24-2014, 04:09 PM   #363
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
Are you sure the oil is coming from the turbo and not via the intake/PCV?
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
Turbo_Steve (11-24-2014)
 Old 11-25-2014, 05:34 AM   #364
El Beaner's Avatar
Posts: 4,262   (View Stats)
Now I have to go through the gtx2867r kit I bought and see what restrictor bolt it has if any. Wish there was a definitive answer on whether to run one or not.
SOLD 2012 LSM Tech - 11/17/17
 Old 11-25-2014, 05:41 AM   #365
leka's Avatar
They have a restrictor bolt
Mazdaspeed 6 2006
 Old 11-25-2014, 08:46 AM   #366
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
I believe the fact of the matter is that ATP does NOT use a restrictor in our kits as evidenced in the posts above. Start at #350 .
 Old 11-25-2014, 10:08 AM   #367
Cheapspeed's Avatar
Posts: 4,481   (View Stats)
Ziggo posted a response to this question in the NOND thread.
 Old 01-30-2015, 11:04 AM   #368
hnda etr's Avatar
Posts: 4,173   (View Stats)
Groans: 90
Sorry, what's the NOND thread?
 Old 01-30-2015, 11:22 AM   #369
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
@Chimmike; likes littleboi peen.
dat is all...
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
Easter Bunny (01-30-2015)
 Old 01-30-2015, 12:36 PM   #370
El Beaner's Avatar
North of North Dallas - it is the local NATOR thread we have.
http://www.mazdaspeedforum.org/forum/foru...3/index71.html
hnda etr (01-30-2015)
 Old 01-30-2015, 08:06 PM   #371
hnda etr's Avatar
Groans: 90
I believe the fact of the matter is that ATP does NOT use a restrictor in our kits as evidenced in the posts above. Start at #35 0 .
Here's a wrench for you...
Check out this thread: Turbo oil restrictor needed? Pics.. - Page 3 - Dodge SRT Forum
Post #33 says:
Originally Posted by Ben@AGP
Every Garrett GT ball bearing turbocharger has a restrictor built into the cage pin. I'll take a picture of one when I get to work later this morning.
Post #35 has pics that show this "built-in restrictor"
 Old 02-01-2015, 10:29 AM   #372
Trail of Fail
Dano's Avatar
not a wrench per se, actually supports the fact that ATP does not restrict their kits...because according to your information Garrett does it at the factory. Still most, if not all, subbie guys add one in-line on the feed.
I still do not run one (on my GTX) and never did on my GT28 which has probably 20k miles on it.
 Old 02-01-2015, 11:03 AM   #373
mituc's Avatar
Groans: 111
I already have 40k mile son my GTX3071 and I don't think it has any visible issue. I installed it almost 3 years ago and never touched the lines since.
 Old 04-22-2015, 07:16 AM   #374
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
Random thought I had when replacing my oil feed (kind of regretting I even did it). There is a banjo on the block side AND the turbo side on the OEM feed line. Could that supply the proper pressure that would make ATP not include any restrictor with their bolt-on kits?
'08 CWP MS3 w/ T3 3071r
Easter Bunny (04-22-2015)
 Old 04-22-2015, 10:57 AM   #375
Trail of Fail
Dano's Avatar
I have pics in a thread somewhere, maybe this one, that has both the banjo bolts for the OE line and IIRC they are both wide open. Since you were just there you can confirm. The block bolt is longer/larger with a hollow middle and the turbo end is smaller but still hollow. The 2 holes on the sides are of course smaller but I'm not sure they qualify as a restriction of sorts. At least when you buy "Garrett restrictor banjos" they are restricted in the core of the bolt. (Also pictured somewhere on here)
I am still running wide open with my GTX with no smoking issues so I am staying that way.
 Old 04-22-2015, 10:59 AM   #376
NCspecV81's Avatar
Posts: 2,867   (View Stats)
Send those cores to Forced Performance and don't look back.
2013 CWP and Stock
jdmage_mx5 (04-22-2015)
 Old 04-22-2015, 04:25 PM   #377
rabble rabble
802MS3's Avatar
Groans: 221
I'm seeing some more smoke than before at cold start up, but it goes away after the oil warms up. My oil pressure gauge reads close to 100psi during cold starts. Not saying its super accurate, but its probably up there.
 Old 04-22-2015, 05:16 PM   #378
broda's Avatar
Posts: 375   (View Stats)
Forced Performance sent me a .030" restrictor with my turbo. Now I'm somewhat worried after reading this.
LakeSpeed6 GTX3076 Build Lakespeed6 MazdaSpeed 3/6 - Big Turbo Builds 60 04-12-2013 08:09 AM
Realgib3 - GTX3076 - 400whp Realgib3 MazdaSpeed 3/6 - Dyno Sheets/Discussions 63 10-13-2011 02:57 PM
Finally let my balls drop! - GTX3076 Realgib3 MazdaSpeed 3/6 - Big Turbo Builds 109 10-04-2011 01:51 PM
Page generated in 0.41945 seconds with 31 queries
