![]() | | #81 | ![]() |
| Not Ranked : 0 score Otherwise, the oil going into the turbo not only passes through the car's oil filter but it also passes through bearings. So that's a little odd to get large pieces at the feed. On the restriction comment, I am surprised no one has mentioned pressure. Oil pressure and therefore flow at the oil feed from the motor should determine the requirements and size of the restrictor if one is needed at all. All a restrictor does is drop pressure across it and regulate flow into the turbo. On the bottom side the turbo must freely be able to evacuate oil. The symptoms of too much oil are usually smoke and oil consumption. The symptoms of too little oil are fried bearings.
| The Following 12 Users Say Thank You to Lex For This Useful Post: | atvfreek (09-07-2012), Caligula (09-07-2012), Dano (09-07-2012), Easter Bunny (09-07-2012), easy (09-07-2012), helmetface (09-07-2012), kritz (09-07-2012), Nliiitend1 (09-10-2012), rfinkle2 (09-07-2012), SLOWHATCH (09-07-2012), speed14 (09-07-2012), Zbrit00x (09-07-2012) |
![]() | | #82 | ![]() |
![]() Join Date: Mar 2010 Location: New Eagle, PA
Rep Power: 2281 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,142
Groans: 324
| Not Ranked : 0 score My vote is that the oil line degraded, fell apart, fucked the turbo and ATP is playing stupid. |
| The Following 4 Users Say Thank You to Mizzle For This Useful Post: |
![]() | | #83 | ![]() |
![]() Join Date: Apr 2009 Location: VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 677
Groans: 320
![]() | | #84 | ![]() |
@chimmike, I realize this may not be part of your issue, although I do feel this is a question that needs to be addressed (restrictor, need for filter etc). Again, I would definitely help you and RayRay in any way possible. I'm down for whatever direction this thread goes. (boycott atp / small claims donation... whatever) @Dano, understood that the history of the gt turbos is that they are reliable, but it seems that the gtx may have brought a new issue to the table based on recent events. @Ziggo, @cld12pk2go @Lex ... does it make sense from an engineering standpoint that using the same CHRA in a GTX vs a GT may require different oil demands OR stress the bearings in a different way? I don't know enough about intertia or metalurgy to make an educated statement, but my gut makes me think that using the same chra on a compressor that spins faster / accelerates quicker would be under different demands bearing wise. I'd let it go if it weren't for members like Bluestreak, Chimmike, RayRay etc suddenly having an issue. ^^^^****No offense to any members, but if guys with what are probably well maintained, well installed turbos are having issues, what chance do some of the other members have with either less mechanical skill or whom practice less frequent routine maintenance. | |
| The Following 9 Users Say Thank You to rfinkle2 For This Useful Post: | ASHMS3 (10-12-2012), atvfreek (09-07-2012), BlueStreak (09-07-2012), Easter Bunny (09-07-2012), exentix (09-07-2012), kritz (09-07-2012), Monotonous ONE (09-07-2012), Rokusek (09-10-2012), SLOWHATCH (09-07-2012) |
![]() | | #85 | ![]() |
Groans: 433
(Thread Starter) | Not Ranked : 0 score That's the thing. I totally agree that I cannot explain how the 'debris' clogged the inlet. ATP's best explanation was that it could've been there since I installed the turbo and just wedged itself in at some point or another, who knows. Using Rotella this change, used Total before, and I use good oil filters. I don't think an oil prefilter would harm flow enough to cause a starvation issue. I had a conversation with the guy at ATP on basically how I could prevent this from happening again, and he's like "I don't want you to feel like you have to go overboard with this, this was not a common failure, more like a one in a million deal", and I reiterated, then why won't garrett choke it and cover it? And he just repeated, the best they'll do is the core exchange.
| The Following User Says Thank You to Chimmike For This Useful Post: | rfinkle2 (09-07-2012) |
![]() | | #86 | ![]() |
![]() Join Date: May 2011 Location: bo$ton, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,199
Groans: 219
But I'm assuming they've cut open the line to find this so-called "clog" Can you simply call up and ask for a picture of said clog?
__________________ | |
![]() | | #87 | ![]() |
![]() Join Date: Nov 2010 Location: Lido Beach,NY
Rep Power: 8624 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,845
Groans: 95
| Not Ranked : 0 score Custom bent hard line?^
__________________ Nator is what it does. |
![]() | | #88 | ![]() |
Groans: 433
They're saying the clog is inside the oil feed in the turbo, that it's in some portion we can't see, and the way they know this is they plugged in an oil feed and no oil was able to pass through to the bearings.
__________________ 07 MS3 The original Genpoo Hater PTE 5862cea ball bearing, plus some built stuff. Turismo Vids - Store your car vids and pics here! Blog your builds too! Click here for great deals at The RPM Store! PM me for pricing! I hear that honkey at Protégé Garage is pretty decent too. | |
| The Following 2 Users Say Thank You to Chimmike For This Useful Post: | helmetface (09-07-2012), rfinkle2 (09-07-2012) |
![]() | | #89 | ![]() |
Groans: 111
| Not Ranked : 0 score I think the oil pressure and flow are high enough on that line to wash away any debris that may be in there and prevent any clog from building up. And if there was any clog/debris just after the install I think the turbo would have failed within the next few hundred miles. Also, we're talking about oil restrictors and stuff to lower the oil flow while the blown bearings are a result of poor oiling. Just think how damaging cooked/burnt oil can be for a turbo: guy comes home with a hot turbo, does not let the turbo cool down, oil cooks on the shaft and makes a solid film, guy starts car next cold morning and bam!, it smokes slightly already. Repeat the process a week in a row and you have a blown bearing and possibly seals on that turbo. While mike and others used these turbo's for a while before they let go.
![]() | | #90 | ![]() |
Groans: 219
I may have missed it, but did you push for proof?
| The Following User Says Thank You to helmetface For This Useful Post: | Rokusek (09-10-2012) |
![]() | | #91 | ![]() |
Groans: 433
Anyways. If anyone feels like shooting me some help, my paypal is chimmike at hotmail dot com.
| The Following 3 Users Say Thank You to Chimmike For This Useful Post: |
![]() | | #92 | ![]() |
![]() Join Date: Feb 2010 Location: Philadelphia, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 323
DROID RAZR tapatalking2
__________________ 2009 Metro Grey Numbers Fully Bolted. Nator Pa Dyno Day: 311HP 328TQ Pump 93 Nator Pa Dyno Day: 310HP 329TQ Pump 93 End of Drive 9/24/2013 2012 Liquid Silver Cobb AP | |
![]() | | #93 | ![]() |
| Not Ranked : 0 score Such B.S. and it certainly sounds like internal failure. Have you asked to escalate and speak to a manager? I know all this is time consuming, but seeing it's still in warranty, they don't have much to stand on.
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 |
| The Following 5 Users Say Thank You to atvfreek For This Useful Post: | Easter Bunny (09-07-2012), helmetface (09-07-2012), MSFer87 (09-07-2012), NJSPEED3 (09-07-2012), rfinkle2 (09-07-2012) |
![]() | | #94 | ![]() |
![]() Join Date: Jul 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19
| Not Ranked : 0 score FUCK ATP BABY! i like there downpipe though, just because there is no chance of them fucking me over
are they going to replace the turbo for you? its bs it went out on u. Last edited by greg08; 09-07-2012 at 07:05 AM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #95 | ![]() |
| Not Ranked : 0 score I believe they were also quick to tell @RayRay that his initial smoke issue was a PCV problem, then when they did further investigating, they found the bur in the turbo.
| The Following 3 Users Say Thank You to atvfreek For This Useful Post: |
![]() | | #96 | ![]() |
Groans: 433
(Thread Starter) | Not Ranked : 0 score @greg08, no they're not replacing it for me.
![]() | | #97 | ![]() |
| Not Ranked : 0 score @chimmike ATP Turbo - Hayward, CA ATP Business Review in Hayward, CA - San Francisco, Oakland, San Mateo, and Northern Coastal California BBB Entity Name: ADVANCED TUNING PRODUCTS, INC. Entity Number: C2516744 Date Filed: 06/02/2003 Status: ACTIVE Jurisdiction: CALIFORNIA Entity Address: 28988 HOPKINS ST Entity City, State, Zip: HAYWARD CA 94545 Agent for Service of Process: QUI LE Agent Address: 38851 HELEN WAY Agent City, State, Zip: FREMONT CA 94536 Last edited by Raider; 09-07-2012 at 07:53 AM. |
| The Following User Says Thank You to Raider For This Useful Post: | Rokusek (09-10-2012) |
![]() | | #98 | ![]() |
![]() Join Date: Feb 2012 Location: King of Prussia, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 126
If you're sticking with the stock flange, which is pretty restrictive but I digress, then yes you're kind of screwed. It'd be nice if someone like Precision or Turbonetics offered stock Mazda flanged hot sides so you could ditch Garrett altogether if you wanted to. Both are cheaper than Garrett turbo's and you don't give up anything from a performance standpoint.
__________________ 2011 VMR Mazdaspeed 3 Cp-e | Cobb | JBR | Freektune | |
![]() | | #99 | ![]() |
![]() Join Date: Sep 2009 Location: State College, PA
Rep Power: 621 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,311
Groans: 27
Groaned at 9 Times in 7 Posts
| Not Ranked : 0 score mike, such a shitty thing to have to go through, "warranty" lol. anyhow, I threw you a few bucks to hopefully help easy the pain of paying the 750$ for the replacement. Curious to hear if anything further happens with ATP.
__________________ 2014 Mustang GT Premium 6MT - GT Track Pack/Leather Recaros/Glass roof in Sterling Grey Metallic | Barton SS/2 Post | J&M LCA | Steeda Street UCA | JBA 3" O/R X | GT500 ABs | JLT plastic CAI | SCT xcal with AED HP custom tune SOLD2011 Mazdaspeed3 Celestial Blue Mica |
![]() | | #100 | ![]() |
However, I certainly am not a turbo bearing guru by any stretch, and thus I could be off by a mile...
__________________ 08 MS3: ATP GTX3071 at 26PSI , AEM Dryflow 21-2147DK, CP-E 3.25'' MAF, CP-E Nviscid TIP, PG FMIC piping with Treadstone TR11 core, Cobb BPV, Ported IM, PG v1 manifold, CP-E catted DP, CNT CBE, KMD v2, Grimspeed EBCS, Alkycontrol Meth injection (M10 with 100% meth), E40 fuel, Cobb AP (ATR= WIN), ACT ZX4-HDSS, 3-Bar MAP, JBR RSB, and CP-E 60 Duro Engine Mount Set. (297.3WHP/366.9WTQ - on K04, 469.2WHP/420.7WTQ - on GTX3071) | |
![]() | | #101 | ![]() |
| Not Ranked : 0 score dude i fuckin hate when companies dont cover warranty's on their products. |
![]() | | #102 | ![]() |
| Not Ranked : 0 score You would need to know what the changes to the CHRA and bearings are. Oil passages on the inside of the CHRA make up the meat and potatoes of the situation and that determines what oil pressure and therefore flow you need through there. This should be covered in Garrett technical papers on the turbo and not by ATP. So just so I'm understanding this correctly. Are all the failures from poor oiling or is there something else? Metal burrs are just assembly/manufacturing issues.
![]() | | #103 | ![]() |
| Not Ranked : 0 score I'm pretty sure the CHRA is the same, it's only the blades that change. @jmhinkle should be putting his GTX3076 on soon and he will be running the same restrictor he was running on his normal GT3076 and the same one I run on my GT3582, neither of us have had problems. Sent from my flying tapadildo
__________________ Precision 6466, Golden Eagle Sleeves, Headgames Motorworks Head Fastest ET: 11.776 @ 123.161(35r setup, 7000ft DA, 450hp uncorrected) 3M Matte Blue Metallic Wrapped 860whp/677wtq 2016 Ford F150, XLT, 4x4 Supercrew 2.7 V6 Ecoboost |
![]() | | #104 | ![]() |
![]() Join Date: Apr 2011 Location: Boynton Beach FL/Flanders, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,007
Groaned at 64 Times in 49 Posts
| Not Ranked : 0 score Cool glad to know I have a ticking time bomb in my car @rfinkle2 since Im not having any problems YET, any suggestions? Im not running a restrictor. Simply the one line ATP provided and the other stock aluminum line. Maybe I should just abort my GTX and go with a custom set up?
__________________ Badsnake 2003 Cobra: Ported Eaton, 2.93 upper, 4lb lower, Steeda intake, fuel system, LF Heat Excg, MGW Shifter, MM Coilovers, Billet Flow IRS Brace, Magnaflow O/R X Pipe/CBE, Fiore Clutch Quadrant/Adjuster, MT ET Street Radials 515rwhp/525rwtq. #HAR Hidden Agendas Racing |
![]() | | #105 | ![]() |
![]() Join Date: Jan 2011 Location: vancouver,WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 184
Most definitely not you.....what exactly could have caused the feed to plug? FYI the gtx uses the same exact bearing/shaft set-up as the gt series, the billet wheel distinguishes the 2 apart, being the case every bb garret tc I have used required a restrictor, they need/use minimal oil...........but this failure doesn't sound like it has anything to do with having too much......more like not enough. To the best of my knowledge the seals are exactly like a piston ring, they are designed to weep to relieve pressure beyond something like 40psi, but that doesn't mean they have failed, usually something like a pinched oil return line causes back pressure.
__________________ 425whp/395ftlbs - GTX3071R .82a/r- 20psi- 92 octane pump fuel | |
| The Following 5 Users Say Thank You to Tabasco69 For This Useful Post: | 802MS3 (09-07-2012), 86AmishMs3 (09-09-2012), Chimmike (09-07-2012), Easter Bunny (09-07-2012), rfinkle2 (09-07-2012) |
![]() | | #106 | ![]() |
Otherwise, there is no sense in worrying about it. | |
| The Following 2 Users Say Thank You to rfinkle2 For This Useful Post: | Easter Bunny (09-07-2012), Payne Racing 67 (09-07-2012) |
![]() | | #107 | ![]() |
| Not Ranked : 0 score holy shitstorm of conflicting information batman! Garratt says use a restrictor..but only if you are under 40PSI ATP says..do not use one. some guys use them some guys dont has anyone actually measured oil pressure at the feed line in the upper RPMs? edit: I see that Garrett wants pressure at least 40-45PSI if lower then the restrictor will increase said pressure in the CHRA. This may be the same source @rfinkle2 quoted
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 Last edited by Dano; 09-07-2012 at 11:50 AM. | |
| The Following 3 Users Say Thank You to Dano For This Useful Post: |
![]() | | #108 | ![]() |
Another note in here - if the oil feed is so large that pressure drops way low and the CHRA is not enough of a restriction, a restrictor may be needed since too much oil volume will pass through the turbo. Oil pressure at the relief valve is probably around 70-80psi on our cars and its riding the relief at 3500 RPM and above. Someone check this in the manual. When oil passes through any passage some of that pressure drops, eventually dropping to zero as it return to the oil pan. The main bearings are fed first, then oil works its way up the block and into the head. I suspect the turbo feed to be between the main bearings and head. I should add, more viscous oil increases pressure, and as the engine wears and bearings wear down/passages open up, pressure drops.
![]() | | #109 | ![]() |
| Not Ranked : 0 score O I C, I guess I was thinking a restrictor would INCREASE pressure/lower volume...place finger over garden hose pressure goes up. my head hurts....
![]() | | #110 | ![]() |
| Not Ranked : 0 score WOT I had oil pressure in excess of 120psi, this is from a aem oil pressure gauge/sender, my tc oil feed is plumbed directly to the oil filter plate (non disi mzr), I absolutley have to run a restrictor. you got to remember the whole premises behind oil pressure/volume has to do with hydro suspension of the older journal bearing which ride in a suspension of oil film, ball bearing only require a small amount of oil in comparison for general lubrication. yeah restrictor decreases pressure, the hole is close to the diameter of a pencil lead
![]() | | #111 | ![]() |
![]() Join Date: May 2011 Location: knoxville, TN
Rep Power: 1703 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,468
| Not Ranked : 0 score @chimmike this may be totally off topic and irrelevant but here goes. ill start off by saying i think atp/garrett should be helping you out in this situation. i work in the construction equipment industry. recently we had a machine that had a turbo go down. installed a new turbo and boom...turbo down again with an hour. we removed all the oil feed/drain lines and cleaned them. once again boom another turbo down. after days of scratching our heads we decided to investigate more. did a compression test. on this 3 cylinder engine cylinder #2 was WAYYYY down on compression. turns out blow by was causing the oil to get nasty and sludge up the feed line causing the turbo to fail. not saying you have this problem, but if it was my money....id make 100% damn sure the turbo is getting sufficient oil. do any of the gurus know if it is possible to get a reading on what pressure the oil pump is putting out? i know on our particular engine we where able to hook a gauge to the oil sending unit and see the oil pressure. but even in doing this....we did not realize the problem until it was too late. maybe there is a way to throw a pressure gauge on the feed line and check it. i didnt read ALL of the post, but did you pull the feed line and inspect it? once again this may be un related....but figured i would throw this out to try to help. good luck with whatever you do.
__________________ Brent Mazda Dragon Camp - Event Coordinator -Built Block-5858-Meth Dragon Slayer Setup FreekTuned ![]() |
![]() | | #112 | ![]() |
| Not Ranked : 0 score yeas u have so many JBR parts on ur gen pu 865 :p Last edited by greg08; 09-07-2012 at 12:32 PM. Reason: MSF Database - Automerged Doublepost |
![]() | | #113 | ![]() |
Groans: 433
(Thread Starter) | Not Ranked : 0 score Oh, the motor is/was fine, as was the oil pump. If anything was wrong with the motor/oil supply, other shit would've failed too, or i'd have spun a bearing or something.
![]() | | #114 | ![]() |
| Not Ranked : 0 score I should add to my comment regarding the oil pressure discussion. The oil pressure in the motor is regulated by the oil pressure relief valve at the pump. The pump spins up and and starts flowing. At low engine speeds it can't flow enough volume to really increase pressure in the engine but at around 3000 RPM it should get to the maximum pressure allowed in the engine. At this point the relief valve is open and pressure is maintained in the system. Everywhere the oil flows, it will drop pressure from what the pressure is held at by the oil pump relief valve. The head thus has less oil pressure than the bottom end. The CHRA is a restriction to the flow of oil, so it will see X pressure at the top and basically zero pressure at the bottom. That X pressure at the top is maintained by the oil pressure relief valve at the oil pump and the many passages before the CHRA. If the oil feed is very large and the oiling system is not designed for a turbo, the oil pump may not be able to flow enough to hit the oil pump PRV. This will starve the motor of oil and it's very bad news. So this is when a restrictor is needed and it's usually in cars where you T off another oil passage such as from the head. If the oil pump can maintain X pressure at the CHRA, say 40psi and you add a flow restriction, then the oil pump relief valve will potentially bleed more oil since it now sees extra pressure in the system overall. So now the restrictor will see 40psi but the CHRA will see less. Dano, you're right that putting your finger over a hose will create a higher pressure coming out, but it also increases the pressure upstream. If that upstream pressure is regulated, it will drop, and you will see less flow from the nozzle. The key here is that the overall system pressure is regulated.
| The Following 10 Users Say Thank You to Lex For This Useful Post: | 865ms3 (09-07-2012), anavrinIV (09-09-2012), atvfreek (09-07-2012), Chimmike (09-07-2012), Dano (09-07-2012), doubleflusher (09-07-2012), Ezekiel81923 (09-07-2012), mituc (09-07-2012), rfinkle2 (09-07-2012), Rokusek (09-10-2012) |
![]() | | #115 | ![]() |
| You guys should all collaborate on a detailed paper, with pictures and everything else. I will publish it for you. True, Garrett is the resp party of the CHRA.. However, you have an ATP modified turbo.. Therefore, they are ultimately responsible for the turbo as the reseller. ATP should be accepting these turbos back under warranty provisions and providing you a replacement. Its ATP's responsibility an an OEM distributor to deal with garrett on getting the warranty done. None of this should be blown off. No one should be required to shell out another $750.. Its someones responsibility and thats ultimately Garrett.. I bet, if you collaborated with enough forums on the subject, you could easily get a class action lawsuit filed on Garrett.
| The Following 5 Users Say Thank You to Haltech For This Useful Post: | atvfreek (09-07-2012), helmetface (09-07-2012), rfinkle2 (09-07-2012), Rokusek (09-10-2012), SpeedSixxx (09-07-2012) |
![]() | | #116 | ![]() |
| Not Ranked : 0 score Has anyone tried contacting Garrett directly? If someone does get a hold of them, tell them one of their distributors (ATP) is jerking around a forum with members nearing 30,000 which has in the 100's of members with Garrett turbos. (drop in the bucket for Garrett, yeah, but worth a try) |
| The Following 2 Users Say Thank You to rfinkle2 For This Useful Post: | helmetface (09-07-2012), RayRay (09-07-2012) |
![]() | | #117 | ![]() |
| Not Ranked : 0 score I would think a little more investigation is needed regarding the failure mode and what actually failed as well as the numbers of failures. Danos resource thread is a good start. Then contact them and explain the situation and get some technical answers regarding the failure. Ie, are we doing something wrong or are the turbos bad?
| The Following 4 Users Say Thank You to Lex For This Useful Post: |
![]() | | #118 | ![]() |
![]() Join Date: Mar 2011 Location: Nor Cal- Pittsburg
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 74
| Not Ranked : 0 score I forwarded the thread to one of my racing buddies that works for ATP. Hopefully it will help. Jason
__________________ JRL Tuning 510-459-7229 www.full-race.com |
| The Following 6 Users Say Thank You to SFWD 1934 For This Useful Post: | atvfreek (09-07-2012), Chimmike (09-07-2012), forcedinduktion (09-07-2012), RayRay (09-07-2012), Rokusek (09-10-2012), SarcasticOne (09-08-2012) |
![]() | | #119 | ![]() |
Groans: 433
(Thread Starter) | Not Ranked : 0 score Let me know what happens!
| The Following User Says Thank You to Chimmike For This Useful Post: | atvfreek (09-07-2012) |
![]() | | #120 | ![]() |
| 5000lbs of voiceless fury ![]() Join Date: May 2012 Location: San Diego, CA
Rep Power: 2530 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,855
Groans: 185
Groaned at 124 Times in 81 Posts
| Not Ranked : 0 score In for win. Lets hope this gets sorted.
__________________ 2015 Telsa Model S 85D - Delivered 10/21/2015 FYEN! SOLD!!! 2007 Mazda MS6 - //AWD//BNR S3//cp-e TMIC//cp-e CDFP//Cobb AP//Cobb TIH//Cobb EBCS//Bosch 845 3 Bar//MS-CAI//Custom DP//TS Kompact BPV//Magnaflow CBE//AWR RMM//JBR Stage 3 SSP Kit//JBR EGR Delete//H&R Springs// |
| The Following User Says Thank You to Caligula For This Useful Post: | Rokusek (09-10-2012) |
| LakeSpeed6 GTX3076 Build | Lakespeed6 | MazdaSpeed 3/6 - Big Turbo Builds | 60 | 04-12-2013 08:09 AM |
| Realgib3 - GTX3076 - 400whp | Realgib3 | MazdaSpeed 3/6 - Dyno Sheets/Discussions | 63 | 10-13-2011 02:57 PM |
| Finally let my balls drop! - GTX3076 | Realgib3 | MazdaSpeed 3/6 - Big Turbo Builds | 109 | 10-04-2011 01:51 PM |
