Like Tree21Likes
 Old 07-08-2013, 07:11 AM   #81
Realgib3's Avatar
Posts: 2,443   (View Stats)
That is a lot of power for so little timing. Looking nice.
Yeah, I looove his turbo. I had a feeling it would be just about perfect, after seeing how my 6466 was reacting.
He was knock limited on 93 at ~12*, so that's where we started with the 3gal blend. We'll work up to the ~15* range at 6500, get the tq as flat/low as possible, then see where we are. The car really moves out though already.
Keepin tq low and still making good peak numbers is the toughest thing on these cars, partly because of our lack of rpm. I'd love peak numbers to be at 7500, rather than 6500, but since I've already kissed pistons from valve float on a very similar setup, we'll stick with the low rl for now.
Etipp98 (07-08-2013)
 Old 09-15-2013, 09:46 PM   #82
Jeff23spl's Avatar
Posts: 2,237   (View Stats)
GT2871R in progress
Actually running 21-22 psi at 12-13 deg RL
330cc W/m with 50/50 blend
Waiting for next maf housing to increase boost a little more and install 3bar map sensor also...
I'm surprise to see your high boost and timing level on stock internals i will probably remain more conservative...
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 09-15-2013, 10:08 PM   #83
Voltron's Avatar
Posts: 4,556   (View Stats)
Groans: 77
T3 3076r .82 hotside
28psi
93 octane w 100% meth single d10
Tapered timing to 19.5*
Bt since 22k.
49xxx now.
The Following 4 Users Say Thank You to Voltron For This Useful Post:
atvfreek (09-23-2013), Koke382 (09-16-2013), ms3blackmica (09-16-2013), NJSPEED3 (09-16-2013)
 Old 06-07-2015, 08:28 PM   #84
Etipp98's Avatar
Posts: 1,947   (View Stats)
Groaned at 7 Times in 4 Posts
Originally Posted by Etipp98 View Post
6266 w/6th port
3 gal e85/ 9 gal 93 mix
26 psi at redline with only 12* advance at 6500. (tune in progress by @Realgib3 )
99k on motor, great compression still. Was running a gt30 before this for about 10k miles on 390whp.
Have about 5k on this setup.
Anddddd 2 years later she is still going strong.
Now with a gen2 6266, JMF IM and a few other things.
Ill probably try to get to the dyno soon to confirm im roughly in the ballpark of this VD.
The Following 15 Users Say Thank You to Etipp98 For This Useful Post:
09TrueRedGTX (06-08-2015), Boost_creep (07-27-2015), cld12pk2go (06-08-2015), Code Monkey (06-08-2015), Easter Bunny (06-08-2015), ItsNox (06-08-2015), joeyspeed3 (06-08-2015), Mauro_Penguin (06-07-2015), Mazdazilla6 (10-19-2015), sho (06-08-2015), Snyeed (06-08-2015), SpeedRebirth (06-08-2015), speed_freak91 (06-09-2015), TRBLSM (06-23-2015), WetzMS3 (02-08-2016)
 Old 06-08-2015, 03:22 AM   #85
nas711's Avatar
Posts: 71   (View Stats)
nas711 is just really nicenas711 is just really nicenas711 is just really nicenas711 is just really nice
Groaned at 30 Times in 8 Posts
Still on stock block? Putting in Corksport turbo tomorrow on stock block, how do you recommend it be tuned? I see your torque delivery is a nice smooth up and then flat rather than the k04's jump to maximum at low rpms.
2010 Gen 2 - "SPOOOL" (VIC/AU) - Fully bolted
COBB AP3 | CORKSPORT TURBO | COBB DOWNPIPE | COBB REM | AUTOTECH HPFP | CORKSPORT TRUE 3" BIG MAF INTAKE | CPE TMIC | CUSTOM HEADERS | COBB 3 PORT EBCS | 3 BAR MAP| PEDDERS COILOVERS | DBA T4 SLOTTED ROTORS | CORKSPORT EYELIDS| FORGE V1 BPV| | MAGNAFLOW | VELOCITY RED | PEARL WHITE 2PAC STOCK RIMS | TUNED BY HP-F
nas711 is offline   Reply With Quote
 Old 06-08-2015, 06:39 AM   #86
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
That is roughly 60whp more than I have ever seen on my stock block...
Reverse taper FTW!
Etipp98 likes this.
The Following 3 Users Say Thank You to cld12pk2go For This Useful Post:
Easter Bunny (06-08-2015), Realgib3 (06-08-2015), Voltwings (06-08-2015)
 Old 06-08-2015, 06:46 AM   #87
Voltwings's Avatar
Posts: 3,713   (View Stats)
Knowing what i put my stock block through and seeing what you guys are doing, it really is a wonder how people manage to blow these things up...
Etipp98 likes this.
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
The Following 6 Users Say Thank You to Voltwings For This Useful Post:
cld12pk2go (06-08-2015), Easter Bunny (06-08-2015), ItsNox (06-08-2015), pmartz16 (06-08-2015), sho (06-08-2015), Vansquish (06-08-2015)
 Old 06-08-2015, 07:07 AM   #88
joeyspeed3's Avatar
Posts: 82   (View Stats)
joeyspeed3 has a brilliant futurejoeyspeed3 has a brilliant futurejoeyspeed3 has a brilliant futurejoeyspeed3 has a brilliant futurejoeyspeed3 has a brilliant futurejoeyspeed3 has a brilliant futurejoeyspeed3 has a brilliant futurejoeyspeed3 has a brilliant futurejoeyspeed3 has a brilliant futurejoeyspeed3 has a brilliant futurejoeyspeed3 has a brilliant future
@Etipp98; That's some serious power man, never knew that was even posible good stuff
Etipp98 likes this.
2013 CWP Mazdaspeed3
Bnr S3 v2//Cobb AP//Autotech internals//3 BAR MAP sensor//3 port EBCS//CNT catback//Ebay catless DP//Tr8 core with cxracing piping kit//Hks bpv//Jbr True 3.5" intake//Jbr ssp//Jbr shift knob//Jbr Trilogy//XXR 527 habanero 18x8.75 +35//H&R springs//385/370 AWD mustang dyno
joeyspeed3 is offline   Reply With Quote
The Following User Says Thank You to joeyspeed3 For This Useful Post:
ItsNox (06-08-2015)
 Old 06-08-2015, 07:23 AM   #89
Realgib3's Avatar
The CS turbo is going to give you a curve much more similar to a k04, but can definitely still be tuned to be safe on stock block.
Etipp98 likes this.
 Old 06-08-2015, 07:23 AM   #90
Etipp98's Avatar
Wouldn't be posting in here if it wasn't. Good luck with the turbo, you should hit up an e-tuner on here.
 Old 06-08-2015, 07:37 AM   #91
ItsNox's Avatar
Posts: 3,076   (View Stats)
Holy fuckballs thats beautiful. Thanks for sharing. Is this your daily? Do you drive the piss out of it or baby it?
@ms6mil; You see this bro? I thought your 470+ was pushing it. Time to turn that shit up yo. I should have gotten a bigger terbow.
'06 Mazdaspeed 6 GT
- Miltuned
Georgia Motherfucking Nator
 Old 06-08-2015, 07:41 AM   #92
Etipp98's Avatar
Not my daily, it comes out on the weekends and after work if it's nice out. I'm a pretty spirited driver so it gets the beans quite often.
The Following 4 Users Say Thank You to Etipp98 For This Useful Post:
ItsNox (06-08-2015), maisonvi (06-08-2015), Realgib3 (06-08-2015), sho (06-08-2015)
 Old 06-08-2015, 08:02 AM   #93
Realgib3's Avatar
"Spirited" 150+mph runs with the man transmission lol.
http://www.mazdaspeedforum.org/forum/foru...ti-e85-172531/
Etipp98 and sho like this.
ItsNox (06-08-2015)
 Old 06-09-2015, 01:53 PM   #94
coasttime's Avatar
Posts: 163   (View Stats)
coasttime has a reputation beyond reputecoasttime has a reputation beyond reputecoasttime has a reputation beyond reputecoasttime has a reputation beyond reputecoasttime has a reputation beyond reputecoasttime has a reputation beyond reputecoasttime has a reputation beyond reputecoasttime has a reputation beyond reputecoasttime has a reputation beyond reputecoasttime has a reputation beyond reputecoasttime has a reputation beyond repute
Groaned at 19 Times in 8 Posts
Right! That is what I was thinking.
coasttime is offline   Reply With Quote
The Following 2 Users Say Thank You to coasttime For This Useful Post:
ItsNox (06-09-2015), Voltwings (06-09-2015)
 Old 06-24-2015, 04:19 AM   #95
croanth's Avatar
Posts: 10   (View Stats)
croanth has a spectacular aura aboutcroanth has a spectacular aura about
6266 w/6th port
Hey mate, this is some awesome numbers !!!
croanth is offline   Reply With Quote
 Old 10-16-2015, 01:19 PM   #96
SPEEDO90's Avatar
Posts: 79   (View Stats)
SPEEDO90 is a jewel in the roughSPEEDO90 is a jewel in the roughSPEEDO90 is a jewel in the roughSPEEDO90 is a jewel in the rough
Groaned at 9 Times in 5 Posts
Neutral  :  -1 score
100% e85
21 psi
12* up top
stock k04 turbo
320ish HP
54k miles
and still tuning for more power I still have injector head room
MODS:
corksport race pipe
auto tech hpfp internal
cobb short ram intake
cobb inlet pipe
custom straight pipes no cats
access port v3
100% e85 pro tune
jbr 88 duro rmm
soon fmic
SPEEDO90 is offline   Reply With Quote
 Old 10-18-2015, 10:52 AM   #97
thehead's Avatar
Posts: 1,141   (View Stats)
thehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the world
Groans: 143
Originally Posted by SPEEDO90 View Post
100% e85
21 psi
12* up top
stock k04 turbo
320ish HP
54k miles
MODS:
corksport race pipe
cobb inlet pipe
access port v3
100% e85 pro tune
jbr 88 duro rmm
soon fmic
This thread is for big turbo stock block, not stock turbo stock block.
2016 BMW M235i
[Dead] 2006 MS6 #367 Liquid Platinum 73,000 miles
Engine - Killah built -L19 Headstuds - Steedspeed T3 Twin Scroll top mount goodness - Twin Scroll .83 A/R hotside GTX3071R - JMF V1 IM - Perm 6th Port - CP-E FMIC - SURE 3.25 MAF housing - customized EBay DP - Magnaflow CBE - Autotech HPFP internals
Electrical - GS EBC - Cobb AP Richtune in progress
Drive train - Techna-fit Stainless Steel clutch and brake lines - stoptech rotors - CorkSport RMM - Corksport Trans inserts - SURE Juggernaught & Dreadnaught - E4 heavy knob & Jbarone's Short Shift plate - Tenzo DC-5 Bronze +45 wrapped in ExtremeContact DWS 235/40-18's
Fluids Transmission - Motorcraft synthetic. PTO and Rear diff - Conklin Gold Guard Plus synthetic 75W-90. Engine Oil - Rotella T6 5W-40.
thehead is offline   Reply With Quote
The Following 2 Users Say Thank You to thehead For This Useful Post:
ItsNox (10-18-2015), Swinger13 (10-18-2015)
 Old 02-08-2016, 10:03 AM   #98
alexwlwsn's Avatar
Posts: 47   (View Stats)
alexwlwsn has a brilliant futurealexwlwsn has a brilliant futurealexwlwsn has a brilliant futurealexwlwsn has a brilliant futurealexwlwsn has a brilliant futurealexwlwsn has a brilliant futurealexwlwsn has a brilliant futurealexwlwsn has a brilliant futurealexwlwsn has a brilliant futurealexwlwsn has a brilliant futurealexwlwsn has a brilliant future
10GPH Methanol above 12psi
15.5deg timing @ 7000
25psi at around 6000
Vdyno from before upgraded exhaust manifold
Oh and 141XXX miles and climbing daily. I have a dyno appt later this month so we will see how vdyno compares.
2008.5 CWP MazdaSpeed3
Purple Drank Tuned
ATP GT3076R @ 26 psi
369.5whp & 348wtq.. yawn
alexwlwsn is offline   Reply With Quote
The Following User Says Thank You to alexwlwsn For This Useful Post:
Boost_creep (02-08-2016)
 Old 02-08-2016, 10:41 AM   #99
Boost_creep's Avatar
Posts: 829   (View Stats)
2009 MS3 with 92,xxx miles
Gtx3071r
Snow Performance 625ml/min nozzle
93 octane
Ported intake mani/cpe exhaust mani/catted downpipe
 Old 02-08-2016, 11:29 AM   #100
mrboostman's Avatar
Posts: 101   (View Stats)
mrboostman is a name known to allmrboostman is a name known to allmrboostman is a name known to allmrboostman is a name known to allmrboostman is a name known to allmrboostman is a name known to all
167K Freek Dynotuned
4 gal E85 / 91 OCT
379WHP/380TQ
GTX3076R
21LBS @ 6000RPM
2008 MS3 GT, Fully Bolted, Cobb AP V3, TR8 FMIC, JBR Piping, JBR 3.5 Wide Path, Autotech Internals, CPE Stage 2 Rear Motor Mount, CNT Catless DP, CNT Cat Back, 51R Battery Box, Cobb Short Shifter, Enkei RPF1's, Koni Yellows, GTX3076R, Freektuned.
mrboostman is offline   Reply With Quote
 Old 12-01-2016, 11:42 PM   #101
GabbyChaves's Avatar
Posts: 128   (View Stats)
GabbyChaves is the leader of the worldGabbyChaves is the leader of the worldGabbyChaves is the leader of the worldGabbyChaves is the leader of the worldGabbyChaves is the leader of the worldGabbyChaves is the leader of the worldGabbyChaves is the leader of the worldGabbyChaves is the leader of the worldGabbyChaves is the leader of the worldGabbyChaves is the leader of the worldGabbyChaves is the leader of the world
Gtx2867r .86 Tial ar.
25psi 15.5*@6k
400whp/ 370 wtq
100% meth do7 nozzle
GabbyChaves is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/big-turbo-stock-block-thread-108396/
? View topic - getting 300WHP out of a KO4 in JHB This thread Refback 05-13-2013 09:59 AM
HOW TO GET 400WHP FROM YOUR SPEED 3 (the practical way) This thread Pingback 04-19-2012 03:02 PM
stock block big turbo dyno kmac MazdaSpeed 3/6 - Dyno Sheets/Discussions 178 06-24-2012 08:35 PM
Bad Turbo Results in New Block batman MazdaSpeed 3 - Engine, Transmission & Driveline 31 02-22-2010 08:32 AM
So...Turbo/motor limits on stock block & internals? 94jedi MazdaSpeed 3/6 - Turbo Induction 26 05-31-2008 08:01 AM
Page generated in 0.40987 seconds with 37 queries
