  • 1 Post By Jake5713
  • 1 Post By atvfreek
 Old 02-03-2012, 01:16 PM   #1
speed6pilot's Avatar
Posts: 23   (View Stats)
speed6pilot is a jewel in the roughspeed6pilot is a jewel in the roughspeed6pilot is a jewel in the rough
Default BIGGER TURBO MBC OR EBC ?
I Have Question about my turbo and external waste gate set up.. currently i have a 06 ms6 and i did a t3/t4 turbonetics turbo with a external waste gate. my question is should i run MBC or use the oem EBC with a Cobb ap. im pondered because most of my evo and mr2 buddies say run MBC but others from the mazdaspeed forums say dont. The car runs fine as of right now but i have boost set at 5 lbs. HELP !!!!!
speed6pilot is offline   Reply With Quote
 Old 02-03-2012, 01:18 PM   #2
trf5000's Avatar
Posts: 2,290   (View Stats)
Wait, are you trying to run this on the stock tune?
2010 MS3 - Sold
2015 CX-5 GT AWD - Current
 Old 02-03-2012, 01:23 PM   #3
no its gonna be tuned i just want to make sure i have it set up right before i take it to get tuned.
 Old 02-03-2012, 01:24 PM   #4
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
I use a grimmspeed ebcs because I just like the detail I'm able to tune with it.
You've got me concerned, OP, because if you're not taking the car to a shop with experience tuning the MZR DISI, you're likely in for a shitty tune.
MBC is fine if you want to go that route.
07 MS3
The original Genpoo Hater
 Old 02-03-2012, 01:25 PM   #5
trf5000's Avatar
I would run a MBC with an AP. There are some load cap issues that the big turbo guys are facing right now. With a MBC, you will be able to avoid some of the complexities of tuning with EBCS.
If you want to go EBCS, I would suggest upgrading to the grimmspeed.
Edit* beat me to it
2010 MS3 - Sold
 Old 02-03-2012, 01:27 PM   #6
Will fuck up ur day
Chimmike's Avatar
Groans: 433
Edit* beat me to it
I'm not hitting any load cap issues..........i'm boost tuned.
07 MS3
ak_spray (02-03-2012), trf5000 (02-03-2012)
 Old 02-03-2012, 01:29 PM   #7
trf5000's Avatar
Load cap is only with guys running load tuning correct?
2010 MS3 - Sold
The Following User Says Thank You to trf5000 For This Useful Post:
Chimmike (02-03-2012)
 Old 02-03-2012, 01:33 PM   #8
Will fuck up ur day
Chimmike's Avatar
Groans: 433
Yup.
dude, what turbo manifold is that?????
07 MS3
Last edited by Chimmike; 02-03-2012 at 01:33 PM. Reason: MSF Database - Automerged Doublepost
 Old 02-03-2012, 01:43 PM   #9
Yup.
its a jdmsport manifold i had to do a little opening of like three holes but its good i like it.
MBC because its easy. And if you are taking your car to a shop without much MZR experience, you will want to minimize the points of possible failure. MBC = set and forget.
By the way, where did you get that exhaust manifold?
edit: chimmy beat me to ^^ that question... lol
ebay ill put the link in a sec.
Doesn't look like something the ms3's can use.......top mount
yea you can use it!!! i found out that nobody really makes stuff for our cars. so i did some research and the ford focus 2.0 is the same motor and those guys run top mount manifolds wen the up the power on there svts.
Last edited by speed6pilot; 02-03-2012 at 01:43 PM. Reason: MSF Database - Automerged Doublepost
 Old 02-03-2012, 01:35 PM   #10
JacksonMS30's Avatar
Posts: 2,242   (View Stats)
2008 MGM MS3 GT
- HTA3586-
- P.E.R.M Twisted Top Mount -
- P.E.R.M.Tuning -
 Old 02-03-2012, 01:38 PM   #11
Will fuck up ur day
Chimmike's Avatar
Groans: 433
07 MS3
i8urgti (02-06-2012), JacksonMS30 (02-03-2012)
 Old 02-03-2012, 01:50 PM   #12
IDK, the turbo sits pretty low in there but it might come down to the distance between the head and firewall that would give the 3 a problem.
edit: It might could work if the manifold to turbo flange was clocked forward to where the turbo was almost touching the valve cover. It would be a very tight fit though and you would def have to have some stiff mounts to keep motor from rocking turbo into the fire wall... lol!
But something tells me it isn't that simple...
2008 MGM MS3 GT
- HTA3586-
- P.E.R.M.Tuning -
The Following User Says Thank You to JacksonMS30 For This Useful Post:
 Old 02-03-2012, 02:11 PM   #13
i believe our distance from the fire wall is the same. if so you will be fine as long as you dont do a gt4071r or something of that size.
04 05 06 MAZDA3 2.0L 2.3L CAST TURBO MANIFOLD MAZDA 3 | eBay
For all that work too, plus you need EWG and a custom downpipe.
i have a custom dp and its only two issues not long enough at the bottom bend off by like 1 1/2 inch and the elbow from the v-band needs to be cut down for clearance of the a/c line and relocating the buds other then that im running ok for now.
Last edited by speed6pilot; 02-03-2012 at 02:11 PM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to speed6pilot For This Useful Post:
Chimmike (02-05-2012)
 Old 02-05-2012, 05:39 AM   #14
Will fuck up ur day
Chimmike's Avatar
Groans: 433
@JacksonMS30. @Realgib3
Who wants to see if the gtx's have clearance to use this on ms3? Lol
07 MS3
 Old 02-06-2012, 06:23 AM   #15
Lol!! Me thinks me will wait for a better option...
2008 MGM MS3 GT
- HTA3586-
- P.E.R.M.Tuning -
 Old 02-03-2012, 01:38 PM   #16
Jake5713's Avatar
Posts: 1,775   (View Stats)
I recommend the grimmspeed ebcs
Then get an e-tune and win
I am here: http://maps.google.com/maps?ll=44.739783,-93.107845
-Jake
G Sp33dy likes this.
 Old 02-03-2012, 01:57 PM   #17
Will fuck up ur day
Chimmike's Avatar
Groans: 433
07 MS3
 Old 02-03-2012, 02:29 PM   #18
So, my next question would be which is safer to do beside a good shop to take it to the MBC or the grimmspeed EBC?
 Old 02-03-2012, 02:36 PM   #19
LiEast's Avatar
Posts: 582   (View Stats)
LiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the world
MBC just easier to change on the fly if needed
jump on the perm tune list and you wont have any tuning problems... they are the shit
2008 RED MS3 GT>>>T3 GT35R .82 A/R>>>Tial 44 EWG dumping>>>SteedSpeed T3 Mani>>>Built Motor
PERM!
LiEast is offline   Reply With Quote
The Following User Says Thank You to LiEast For This Useful Post:
 Old 02-03-2012, 03:19 PM   #20
crazyp's Avatar
Posts: 1,093   (View Stats)
Groans: 68
Get a good MBC like the grimspeed and youll be set. I think the hallman pro is good also. If you get a cheap one youll have boost spike issues like I did. Nice top mount turbo man. glad more people are doing it and that mani is way cheap compared to my steedspeed jeeze
 Old 02-05-2012, 05:59 AM   #21
atvfreek's Avatar
Posts: 7,787   (View Stats)
I personally like the ebcs over mbc. The only guys that are having load cap issues are tuning with the boost toggle off in atr and the are running e85 mixes which scales the maf and have higher calc load readings. Some of us have been load tuning with the toggle on and having good luck. EBCS gives a lot more options of what you can do for your tune. You can run a a tune that inceases boost with rpm, which will I like on a BT setup, so you can control wheel spin and tq in lower rpms. You have a speed6 so wheelspin is not as big of an issue.
I would be cautious of which shop tunes your car. Make sure they are familiar with the mazdaspeed platform. I've found few shops that tune these cars fluently.
Tappin
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
The Following 3 Users Say Thank You to atvfreek For This Useful Post:
Chimmike (02-06-2012), rfinkle2 (02-05-2012), trf5000 (02-05-2012)
 Old 02-05-2012, 09:28 AM   #22
Tappin
our fuel systems can handle e85?
Turbonetics t3/t4 turbo 60.a/r-JGSPEC 38mm external waste gate-Custom EGR DELETE -Custom butterfly delete -turbosmart MBC-Fidanza 11lb flywheel-OEM clutch-Custom turbo-inlet pipe-Custom FMIC-2.0 oil filter conversion-Custom Balance shaft delete -AWR MOTOR MOUNTS 70mm-Custom downpipe -Custom cat-less 3' full exhaust straight pipe-TEIN TYPE_S SPRINGS -Custom 40% shorter throws short shifter plate-prospot oil temp/oil pressure gauges-Glowshift boost gauge-Rear deck wing -Window visors-Custom SIR intake-Stop tech cross drilled and slotted rotors-Single din head unit-Single 12" Kicker cvr-Apeix Turbo Timer
atvfreek (02-06-2012)
 Old 02-05-2012, 09:43 AM   #23
TRSpeed's Avatar
Posts: 1,537   (View Stats)
TRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the world
Ooo no you din'nt lol^^^^
Told you MSF was better than MOCC for these type of things. =)
Sent from my DROID2 GLOBAL using Tapatalk
2008.05 True Red Mazdaspeed3
Lex Tuned
GTX3071r | 38mm Tial WG | Hallman MBC
Cobb AP E85 30% |CPE Big MAF | CPE Big TIP | CPE FMIC | SS Ex Mani | CPE Catted DP | CNT CBE | CPE Triple Gauge Pod |
Autotech HPFP Internals | Denso ITV22 | TS BPV | TWM ShortShifter | JBR Shifter Bushings | JBR 88 RMM |
Razo Heavy Shift Knob | 20% Tint | DDM 55W HID | Hankook Ventus V12 | H&R Springs
TRSpeed is offline   Reply With Quote
The Following User Says Thank You to TRSpeed For This Useful Post:
 Old 02-09-2012, 06:54 AM   #24
zpele's Avatar
Posts: 1,654   (View Stats)
zpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the world
Groans: 354
Groaned at 213 Times in 109 Posts
Hmmmmmm I might get this mani. How much louder does it make the car?
2012 Shelby GT500 - Roush Axleback ~ JLT Oil Separator ~ JLT 123mm intake ~ Ngauge ~ Lund Tuned ~ smaller pulley ~ xpipe (loud as fuck now)
2007 Mazdaspeed6 (SOLD) - COBB SRI ~ Gutted Stock Midpipe ~ HKS BPV ~ JBR RMM ~ AWR PMM ~ AWR TMM ~ Juggernaught Rear Diff Mount ~ Dreadnaught Rear Diff Mount ~ ACT Stage 2 Clutch ~ ITV22s ~ AP(self fucking tuned in a week fuckers) ~ Autotech Internals ~ eBay Downpipe ~ Poke Sub thingy
zpele is offline   Reply With Quote
Video: Fórmula Truck - The bigger they race, the bigger they crash Haltech Automotive News 0 08-02-2010 09:50 AM
Bigger is better! Hectik1 MazdaSpeed 3/6 - Suspension & Brakes 13 07-01-2010 07:35 PM
Bigger turbo on stock internals.... SPDZRCR6 MazdaSpeed 3/6 - Turbo Induction 77 09-25-2009 01:41 PM
tuning for a bigger turbo 18psiWhiteMS3
Cobb ATR Support
7 08-27-2009 04:17 PM
New Porsche 911 Turbo gets a bigger 500 hp engine Haltech Automotive News 0 08-07-2009 09:10 AM
Page generated in 0.43897 seconds with 29 queries
