 Old 03-02-2012, 08:28 PM   #1
Kydizzle's Avatar
Posts: 505   (View Stats)
Kydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the world
Default BNR GTX Swap Possible?
Ok so I am looking into geting a used BNR stage 2 turbo, and i noticed garrett has gtx 28r wheels available now, my question is if they are using the inside guts of the 2871 would this gtx wheel fit in the bnr housing? or am i on drugs lol.. let me know guys
2008 Silver MS3 GT - BNR S2, CP-E HPFP, CP-E Nano, Cobb FMIC, Cobb AP(E-85 Mix [FREEKTUNE]), GrimmSpeed EBCS, CNT Exhaust, Corksport DP, SU Test Pipe W/ Magnaflow HFC, Forge BPV v1, EGR Delete, AWR RMM, SU Shifter Bushing, CP-E Towplate, BC Coilovers, Cobb RSB, Motegi SP-10 HyperBlack(19lbs)
Kydizzle is offline   Reply With Quote
 Old 03-04-2012, 02:25 AM   #2
ms6forthewin's Avatar
Posts: 525   (View Stats)
ms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the world
i thought the stg 3 is like the 2871, might as well get that
-2014 Evo X GSR
-2007 MAZDASPEED 6 (SOLD)
BNR S3// ALL-SUPPORTING MODS
ms6forthewin is offline   Reply With Quote
 Old 03-04-2012, 02:55 AM   #3
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
Doubtful since it seems that the compressor housing are different on the GTX series. It might be possible to have a machine shop take off the exta material...but that would negate any cost savings going with a used BNR turbo.
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
 Old 03-27-2012, 01:10 PM   #4
Voltwings's Avatar
Posts: 3,713   (View Stats)
i believe the BNR as is uses journal bearings but the GTX turbos use ball bearings so theres issues with the swap, someone has already addressed this issue with BNR and there is a reason they are not already running GTX wheels.
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
86AmishMs3 (03-27-2012)
 Old 03-27-2012, 01:37 PM   #5
bnr are also ball bearing. They have to be if they replace our turbos which are both oil and water cooled
 Old 03-27-2012, 01:40 PM   #6
Broxer's Avatar
Posts: 875   (View Stats)
Broxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the world
Groans: 90
From BNR's website
  • GT2871 compressor wheel
  • New GT28 non ball bearing CHRA
  • 360 degree thrust assembly
  • upgraded wastegate actuator assembly
  • balanced to or under .5 gram/in2
  • upgraded compressor housing with custom outlet for the factory intercooler piping/couplers
  • 1 year warranty!
2012 Triumph Street Triple
SOLD -- 2010 Velocity Mica Red MS3
ATP GTX3071r - Cobb AP(Freek Permed) - CNT Catted DP - UR CBE - DO Stage 2 WMI(80/20) - cp-e TMIC - cp-e xcelXL - cp-e invicid inlet - Grimmspeed MBC - KMD v2.2 hpfp internals - Bosch 3bar MAP - H&R Springs - DDM 6k Raptor Kit - ITV22's - Forge v2 BPV - 225/40/18 Nitto Neogens - SURE RMM
Broxer is offline   Reply With Quote
The Following 3 Users Say Thank You to Broxer For This Useful Post:
86AmishMs3 (03-27-2012), Chimmike (03-28-2012), EdgeAutosport.com (03-27-2012)
 Old 03-27-2012, 01:42 PM   #7
Originally Posted by Broxer View Post
From BNR's website
  • 1 year warranty!
hmmm interesting. esssplains the prices now.
86AmishMs3 (03-27-2012), Alpha (03-27-2012), thehead (03-28-2012)
 Old 03-27-2012, 10:57 PM   #8
86AmishMs3's Avatar
Groans: 338
Eric don't make me come slap you with my cock. Neither bnr, discopotato, or k04 is bb.
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
The Following 2 Users Say Thank You to 86AmishMs3 For This Useful Post:
EdgeAutosport.com (03-28-2012), thehead (03-28-2012)
 Old 03-28-2012, 08:13 AM   #9
I was hoping for the....
86AmishMs3 (03-28-2012), thehead (03-28-2012)
 Old 03-28-2012, 08:18 AM   #10
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
dude, the disco potato, what used to be the GT28RS, and is now known as the GT2860RS, is most certainly ball-bearing.
I owned a b15 sentra when that turbo first came out and remember the car the turbo was named after:
Don't make ME slap YOU!
07 MS3
The original Genpoo Hater
The Following 3 Users Say Thank You to Chimmike For This Useful Post:
86AmishMs3 (03-28-2012), EdgeAutosport.com (03-28-2012), theschrum (03-28-2012)
 Old 03-28-2012, 08:27 AM   #11
theschrum's Avatar
Posts: 1,031   (View Stats)
You cannot buy a GTX compressor wheel from Garrett, but you can buy a billet copy from Snail Turbo snail-turbo - Billet compressor wheel | Facebook. It is p/n SNX3071 and was about $250 last time I checked. (The GT3071 ans GT2871 share the same compressor wheel FWIW).
Still if it is BB, might not be possible.
08 Speed 3|SOLD
 Old 03-28-2012, 12:23 PM   #12
86AmishMs3's Avatar
Groans: 338
Yeah I was wrong...come slap me...with your cock bwhaha
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
 Old 03-28-2012, 12:24 PM   #13
Nice fail cory get me off the hook
BNR S3 Swap How To Ziggo MazdaSpeed 3/6 - Big Turbo Builds 244 12-13-2016 09:07 PM
LSD Swap out Tomas MazdaSpeed 3 - How-To's 81 10-08-2012 09:16 PM
HID swap TXspeed3 MazdaSpeed 3/6 - Appearance 19 06-28-2009 05:04 PM
Page generated in 0.34864 seconds with 27 queries
