Like Tree12Likes
 Old 05-06-2013, 03:13 PM   #81
UnknownSuperhero's Avatar
Posts: 2,462   (View Stats)
@Caligula;
You had this problem no?
 Old 05-06-2013, 03:21 PM   #82
5000lbs of voiceless fury
Caligula's Avatar
Posts: 3,140   (View Stats)
Caligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the world
Groans: 185
Groaned at 124 Times in 81 Posts
Originally Posted by UnknownSuperhero View Post
@Caligula;
Sure did! Ill get to this in a minute or two.
2015 Telsa Model S 85D - Delivered 10/21/2015 FYEN!
SOLD!!! 2007 Mazda MS6 - //AWD//BNR S3//cp-e TMIC//cp-e CDFP//Cobb AP//Cobb TIH//Cobb EBCS//Bosch 845 3 Bar//MS-CAI//Custom DP//TS Kompact BPV//Magnaflow CBE//AWR RMM//JBR Stage 3 SSP Kit//JBR EGR Delete//H&R Springs//
Caligula is offline   Reply With Quote
The Following User Says Thank You to Caligula For This Useful Post:
UnknownSuperhero (05-06-2013)
 Old 05-06-2013, 04:14 PM   #83
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
@Caligula;
Who hasn't?
Pickles Tune in progress
 Old 05-06-2013, 09:14 PM   #84
Bryan@BNR's Avatar
Posts: 28   (View Stats)
Bryan@BNR is the leader of the worldBryan@BNR is the leader of the worldBryan@BNR is the leader of the worldBryan@BNR is the leader of the worldBryan@BNR is the leader of the worldBryan@BNR is the leader of the worldBryan@BNR is the leader of the worldBryan@BNR is the leader of the worldBryan@BNR is the leader of the worldBryan@BNR is the leader of the worldBryan@BNR is the leader of the world
If I don't hear about potential problems, I don't know how to fix them. I have been in business for 12 years doing nothing but custom turbos. I have never had issues with bolts in compressor housings stripping out. I am not saying there won't be a first .
When people do boost leak test and they see some air bubbles coming from around the bolts on the compressor side, what they think is to tighten the bolt. So they tighten, and tighten and ofcourse it strips out the threads. There aren't O rings or sealant on the bolts to prevent some seapage.
Now I can put longer bolts in the compressor housing to give it more bite into the housing, but the bolt end goes into the volute of the compressor housing causing a disturbance in air flow.
If you have a stripped out thread on the compressor housing, you can either:
A) tap the hole with M8 by 1.25 tap and use a M8 by 1.25 12mm-14mm Length bolt.
B) drill out the housing for a M8 by 1.25 Heli coil
C) If you don't have the knowledge or skill, I would love to help you fix the problem
So if you guys have problems, call me. This type of feedback is needed to update and improve my future products.
Bryan@BNR
Bryan@BNR is offline   Reply With Quote
The Following 15 Users Say Thank You to Bryan@BNR For This Useful Post:
08cosmic3 (07-18-2013), Caligula (05-07-2013), Code Monkey (05-07-2013), cshunter (05-07-2013), cymen (05-07-2013), Dmurray06 (05-06-2013), faeker (05-06-2013), IMASA (05-06-2013), jdmage_mx5 (05-06-2013), memin (06-07-2014), MPS_Fan (05-07-2013), mzr0818 (05-07-2013), Nliiitend1 (05-07-2013), Wilksy (06-12-2013), YABBAMZR (05-06-2013)
 Old 05-07-2013, 06:40 AM   #85
MPS_Fan's Avatar
Posts: 436   (View Stats)
MPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the world
Bryan@BNR
Do you also have a solution for stripped threads on the exhaust housing (Ex housing to CHRA Bolts)? There is no space for bigger holes or helicoils
MPS_Fan is offline   Reply With Quote
 Old 05-07-2013, 08:15 AM   #86
Caligula's Avatar
Groans: 185
Okay my 2 cents... sorry for the late reply.
I bought one of the earlier units which didn't have the retaining tabs (is this the correct term?) installed by BNR @ the shop. After putting on a few thousand miles everything seemed to be going okay until I noticed a slight noise from the engine bay that sounded like a small exhaust leak. Long story short, I was unable to find the source of said leak until one day the CHRA bolt completely backed out. At that point my car sounded like an air-cooled VW under boost. It also made the leak rather easy to pinpoint, lol.
I hit up Bryan@BNR via AIM the next day, and informed him of the issue. He promptly send out a package with 6 CHRA bolts, as well as those retaining tabs to keep them from backing out again.
On that note, installing said replacement bolts/retaining tabs is a major PITA if you are trying to not remove the turbo. I had to loosen/unbolt my DP, V-band adapter, oil return line, and turbo mani to get to the bottom two bolts (FML)... and this was with the aid of a lift. Of course I also have an MS6 which doesn't help at all.
I've easily doubled the number of miles on my BNR (at much higher boost levels) since first noticing the issue, and I've yet to see any additional problems, so it would appear that the "fix" is legitimate.
@Bryan@BNR;
A. Why no lock washers on these bolts?
B. Will there be any deals for customers that want to trade in an older S3 unit for the new version once it comes out?
 Old 05-07-2013, 03:01 PM   #87
mczimer's Avatar
Posts: 1,249   (View Stats)
mczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the world
Anything we can do as preventative maintenance on this issue?
mczimer is offline   Reply With Quote
 Old 05-07-2013, 03:04 PM   #88
Caligula's Avatar
Groans: 185
Install said retaining tabs and/or tighten the bolts.
 Old 05-21-2013, 12:23 PM   #89
Karmat's Avatar
Posts: 1,179   (View Stats)
As someone installing a brand new BNR what should I be doing?
I'm slightly thick so can someone point me to a link with the kind of bolts/washers I should be using?
2002 Corvette Z06 (Black)
 Old 05-28-2013, 02:37 PM   #90
kish89's Avatar
Posts: 292   (View Stats)
kish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the world
It seems that after 8+ months of using my BNR, one(or more) bolts holding the exhaust housing have backed out.
I can hear exhaust leak from around the turbo and I'm 99% sure that bolt near coolant line is missing (more on this tomorrow).
Which bolt is ok to use?
M10x1.5 but what length?
06 MS6, Versatuner, Stratified Tuned
BNR Stage 3 turbo, Eagle con. rods, HTP Full 3" intake + AEM DryFlow filter
Autotech HPFP internals, Forge V1 BPV
Custom 3" cat-back with stock mufflers, M2 3" catless Downpipe
Grimmspeed EBCS + Stratified Boost Dial, 3BAR BOSCH MAP
NGK Iridium IX one step colder plugs, CPE SafeSeals & studs
Custom FMIC with 2.5" piping and Treadstone TR8 IC
SnowPerfomance WMI, Stratified Guardian Angel
Eibach pro kit lowering springs
kish89 is offline   Reply With Quote
 Old 05-28-2013, 02:42 PM   #91
MPS_Fan's Avatar
Bolts are M6!! And length is 10mm!Write Bryan an email, he will send you a fix!
I'm still waiting for my fix package, because it was sent to wrong country
The Following 3 Users Say Thank You to MPS_Fan For This Useful Post:
Caligula (05-28-2013), cymen (05-28-2013), kish89 (05-28-2013)
 Old 05-28-2013, 03:02 PM   #92
kish89's Avatar
It's my daily driver and I need some quick fix, so I'll try to find matching bolt in local hardware store as temporary fix, because car is farting like crazy
What thread pitch do I need, is 1.0mm ok?
So M6 x 10mm length x 1mm pitch ?
 Old 05-28-2013, 03:04 PM   #93
MPS_Fan's Avatar
Sorry I took a look again, bolts are M5 NOT M6!!!!
Pitch is 0.8mm and thread length is 10mm!!
And don't drive with that leak. It could fry your coolant hose!!
The Following 2 Users Say Thank You to MPS_Fan For This Useful Post:
 Old 05-28-2013, 03:07 PM   #94
kish89's Avatar
I have stock coolant hose (hard line) so I think I should be ok.
Hopefully local hardware store is carrying that kind of bolts.
 Old 05-29-2013, 03:29 AM   #95
kish89's Avatar
@Lex; here is my report
Username: kish89
Mileage on BNRS3 turbo: ~15k miles
What was the failure (which bolts backed out, broken, other?):
Bolt which is holding exhaust housing (nearest to the coolant line) backed out completely.
Boost level you are running:
20-22PSI
Are you using the bottom supporting bracket bolted to the block?:
Yes
How is the car driven (street, hard, tracked, etc):
Street, Daily Driver
Did you retorque the exhaust bolts at any time prior to failure?:
No
Does your turbo have any locking washers on these bolts?:
No
How did you fix it?:
As temporary fix, I bought M5x0.8x10mm bolt at local hardware store
 Old 06-09-2013, 09:48 PM   #96
dawgincustoms's Avatar
Posts: 243   (View Stats)
dawgincustoms is the leader of the worlddawgincustoms is the leader of the worlddawgincustoms is the leader of the worlddawgincustoms is the leader of the worlddawgincustoms is the leader of the worlddawgincustoms is the leader of the worlddawgincustoms is the leader of the worlddawgincustoms is the leader of the worlddawgincustoms is the leader of the worlddawgincustoms is the leader of the worlddawgincustoms is the leader of the world
Dawgincustoms
6000
all bolts backed out and 2 fell out. The top firewall one and front middle engine one.
23-24lbs
NO
Car is drivin extremly hard
Yes at 500 miles for heat cycle and again at 2000 miles
No
Trying to figure that out now. Motor is coming out now.
dawgincustoms is offline   Reply With Quote
 Old 07-17-2013, 10:23 PM   #97
Bryan@BNR's Avatar
Remember, just give me a call or an email if you need some plates and bolts. Also need to know your bolts size. I changed from 6mm to 5mm a while ago and didn't document when the changeover was. The 5mm thread pitch as an 8mm head. The 6mm thread has a 10mm head.
Bryan@BNR
205 640 1193
BNRsupercars@aol.com
The Following 3 Users Say Thank You to Bryan@BNR For This Useful Post:
breakfstincluded (07-17-2013), Micha (07-19-2013), speed_freak91 (07-20-2013)
 Old 07-17-2013, 10:39 PM   #98
Bryan@BNR
205 640 1193
@Bryan@BNR; I noticed you have new compressor housings on the BNRs. Can you please give us some details on the changes?
 Old 07-17-2013, 11:59 PM   #99
himurax13's Avatar
Groans: 255
I have pictures. I didn't notice any difference except for the vacuum line nipples.
Sent via blown passenger side speakers.
 Old 07-18-2013, 10:47 AM   #100
DSIT995's Avatar
Posts: 1,768   (View Stats)
New housing and wastegate.. will upload more pics later
tapa tap tap
99 Miata NB - Stock for now
The Following User Says Thank You to DSIT995 For This Useful Post:
Micha (07-19-2013)
 Old 07-18-2013, 01:09 PM   #101
MPS_Fan's Avatar
More pictures please. Exhaust housing is still the old one? Could you measure the compressor inlet size?
looks like Bryan prefers now 2 port boost contro model, since wastegate has now 2 nipples.
 Old 07-18-2013, 05:48 PM   #102
DSIT995's Avatar
ImageUploadedByTapatalk1374191155.671298.jpgImageUploadedByTapatalk1374191170.176807.jpgImageUploadedByTapatalk1374191182.096982.jpg
Some more shots of the updated s3... Question for everyone with the newer version.. How did you plumb the wastegate to ebcs in 3 port mode? Does one of the ports need to be plugged?
Lex (07-18-2013)
 Old 07-18-2013, 05:58 PM   #103
himurax13's Avatar
Groans: 255
Wow, that housing is different than the one my buddy bought in May.
 Old 07-18-2013, 06:07 PM   #104
meelo88's Avatar
Posts: 557   (View Stats)
meelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the world
Humm here is mine from April...
Very interesting...
"If I can't fix it, it was meant to be broken"
[SIGPIC][/SIGPIC] 2007 MazdaSPEED 6 Titanium Grey
TUNED BY NISHAN
POWER
SpeedPerformanc3 Wiseco Pistons (88mm)::Manley Forged H-Beams::BNR S3::Bosch 3Bar Map Sensor::CP-E Ex Mani::SBC Stg 2 Clutch::JBR RMM 80a::JBR STG II SRI::JBR Boost Tubes::JBR BPV Return::JBR SSP::CS TMIC::CS DP::Stratified 3 Port EBCS::Stratified Guardian Angel::TurboXS RP::Custom 3" Catback Exhaust::KMD 2.1::Flex Innovations Ground Kit::Turbosmart BPV::MD OCC::TWM Stage 1::BC Coilovers::Hawks HPS::EGR Delete::SURE Dreadnaught::SURE Juggernaut::SURE TIG
COSMETIC AND AUDIO
Mori H1 Proj Retrofit::DDM 3k HID Fogs::RPM Rear LED Reflectors::RPM Side LED Reflectors::Morel Elate 6 2W 6.5" Components::Morel Maximo 5C 5.25" Coaxial::Arc Audio KS300.4::Arc Audio KS1000.1::Audison BitOne.1::Zapco ST4
meelo88 is offline   Reply With Quote
 Old 07-18-2013, 06:59 PM   #105
DSIT995's Avatar
I gotta check for a restrictor pill in one of these ports... I'm a lil lost on how this would set up with a 3 port ebcs
 Old 07-18-2013, 07:28 PM   #106
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
Same way you do it on a K04... Cap off the bottom port on the WGA.
DSIT995 (07-18-2013), rfinkle2 (05-27-2014)
 Old 07-18-2013, 09:09 PM   #107
bstover17's Avatar
Posts: 586   (View Stats)
Groans: 228
Damn that new housing looks nice. Hopefully this issue will be fixed before I order mine.
2010 MAZDASPEED 3
 Old 07-18-2013, 09:28 PM   #108
What about the top port of the WG? Take a look in all the ports carefully to find the restrictor because only then I can tell you how to best plumb it.
 Old 07-18-2013, 11:38 PM   #109
faeker's Avatar
Posts: 5,091   (View Stats)
Groans: 731
Edit: nevermind saw it in second look
sent with smiles and mouth hugs
Mods: stock
 Old 07-19-2013, 02:11 AM   #110
ledfootrob's Avatar
Posts: 195   (View Stats)
ledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the world
Yeah I just received mine today and got the new housing. Interested to see how to hook 3 port up with this before install next week.
2012 Black Mazda 3 MPS
CP-E Stage 2 Pistons - Manley Rods - BNR S3 - HTP 3" TIP + 3" BTM - Corksport Airbox - Cobb FMIC
2XS Exhaust Manifold - Snow Performance Meth Kit - HKS SSQIV - HPFP Internals - CPE Catted Downpipe - Perm PCV Plate
OBX Catback - CPE Stage 2 RMM - JBR Side Mounts - SURE AGS Shiftknob + Shortcut + Anchors
Cobb Accessport V3 - Saikou Michi OCC - Damond OCC - Corksport Springs - Bilstein B8 Shocks
Versus Eurolace 19 x 8 +45 - Hankook RS3
Built & Tuned by Rob
Track Setup - 18 x 8.5 Lenso Spec E - Nitto NT-01 245/40/18
DBA T3 Rotors - Carbotech XP10 Brake Pads
ledfootrob is offline   Reply With Quote
 Old 07-19-2013, 11:05 AM   #111
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
Here's another pic- I'm not aware of any restrictor in line, it would still have to be added if using the stock EBCS
Bryan's just set it up to mimic the OEM configuration and use the stock EBCS !as long as a restrictor is used between the source and the WGA!.
For those doing that the path becomes
source>restrictor>WGA lower>WGA>WGA upper>Stock EBCS>TIP
For using an aftermarket 3 port EBCS, like Cobb's or any of the similar units, the easiest thing to do is to block the lower WGA port, then plumb it following the instructions included with the EBCS, which are, generically,
Port 1 - vent - connect to TIP/TIH
Port 2 - action - connect to WGA
Port 3 - source - connect to full pressure boost source
340hp / 371tq
The Following 4 Users Say Thank You to TiGraySpeed6 For This Useful Post:
DSIT995 (07-19-2013), Lex (07-22-2013), manselainen (11-17-2013), mczimer (07-19-2013)
 Old 07-22-2013, 06:39 AM   #112
To have confirmation direct from the source I emailed Bryan and asked about resitrctors and plans regarding the 2 port WGA.
He replied that there is not currently a restrictor in place, but that there will be "in the next batch"
Take from that what you will...
My next batch will have the restrictor...
Bryan Nickell
Owner of BNR Supercars LLC
(205)640-1193
bnrsupercars.com
To: BNRsupercars@yahoo.com
Sent: Friday, July 19, 2013 12:25 PM
Subject: Mazdaspeed question about new 2 port WGA
Hey Bryan,
Just wanted to know if you've added any restrictor pill or anything to go along with the new style 2 port WGA for the Mazdaspeed BNRs3?
Eric-
340hp / 371tq
 Old 07-22-2013, 11:13 AM   #113
It will be tricky with an added 1 size fits all restrictor - hope he does a good amount of testing. This is why I came up with the Boost Dial since different intake and exhaust setups can benefit from a tunable restrictor.
DSIT995 (07-22-2013), Nliiitend1 (07-23-2013)
 Old 07-22-2013, 12:05 PM   #114
I'm surprised he's adding one at all. I like Bryan, and the S3, but I doubt he's done much testing, at least not the way you think of it Lex.
340hp / 371tq
 Old 05-27-2014, 09:57 PM   #115
Ziggo's Avatar
Posts: 3,843   (View Stats)
@Lex;
Well mine finally backed out.
Mileage on BNRS3 turbo: 33 months - ~30k Mi
What was the failure (which bolts backed out, broken, other?): Bolt appears to be backed out.
Boost level you are running: tapering up to 25psi
Are you using the bottom supporting bracket bolted to the block?: Yes
How is the car driven (street, hard, tracked, etc): Tracked in the first year, but not since. Some drag usage
Did you retorque the exhaust bolts at any time prior to failure?: I sent out my hotside for coating and then reinstalled it and retorqued all bolts prior to installation. Torqued by feel, don't have a box end torque wrench.
Does your turbo have any locking washers on these bolts?: No (lockwashers don't do shit anyway, see NASA RP-1228)
How did you fix it?: Not fixed yet. Intend on pulling the turbo and then safety wiring bolts
Confirmed my bolts have the 10mm head. Going to order replacements and safety wire them in with nickel\chromium wire. No more messing with it.
Ask Me About My:
The Following 4 Users Say Thank You to Ziggo For This Useful Post:
Lex (05-27-2014), Nliiitend1 (05-31-2014), rfinkle2 (05-27-2014), WetzMS3 (05-28-2014)
 Old 05-27-2014, 10:42 PM   #116
JgamB's Avatar
Posts: 2,566   (View Stats)
I don't see the crimped brackets on yours Zig that would only allow for 1/16 of a turn at most before metal on metal. Am I missing something?
 Old 05-27-2014, 10:43 PM   #117
Looks like eventually all the BNRs without the locking washers or safety wire will see the bolts backing out. This is something that someone installing a used BNR should do before putting it in.
ItsNox (05-30-2014), MD1032 (01-28-2015), Ziggo (05-28-2014)
 Old 05-28-2014, 06:47 AM   #118
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
Just skimmed through that - sweet reference manual.
-06 MS6
-Corn fed 07 MS3 - Sold
 Old 05-28-2014, 07:57 AM   #119
Ziggo's Avatar
I was a very early adopter, no crimped brackets for me.
I am not a huge fan of the crimped bracket solution. It works so the bolt can't back out completely, but I consider any rotation of the bolt a joint failure due to the loss of preload. At the end of the day, if it's a critical joint you safety wire it. The only reason not to is the time it takes, but it will take less time than if I have to pull the turbo again to fix this. Should have done it the first time round.
Ask Me About My:
JgamB (05-28-2014)
 Old 05-28-2014, 08:09 AM   #120
Ziggo's Avatar
Its the best publicly available guide, but keep in mind it's nearly 25 years old. The plating and materials section is pretty dated. Some of the plating has been discontinued due to health concerns (mostly containing chromium or cadmium) and there are a ton of new fancy thread lubricants and bolt materials on the market now.
If you can learn everything else in there though you will be better than almost every engineering student coming out.
Ask Me About My:
The Following 6 Users Say Thank You to Ziggo For This Useful Post:
Crarrs (05-28-2014), ItsNox (05-30-2014), phate (05-28-2014), rfinkle2 (05-28-2014), theurgy (05-28-2014), WetzMS3 (05-28-2014)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/bnr-s3-exhaust-housing-bolts-backing-out-144177/
Beaner time! - Page 20 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 06-07-2013 04:58 PM
exhaust spring bolts slashsnake 2010 MS3 - Engine, Transmission & Driveline 10 12-17-2012 11:27 AM
Leaking exhaust gases mps-passion MazdaSpeed 3 - Engine, Transmission & Driveline 3 06-18-2012 10:57 PM
exhaust gaskets, bolts, etc. needed greenespeed Mazdaspeed3/6 General Discussion 3 10-05-2011 12:49 PM
WG right off the exhaust housing -cj- MazdaSpeed 3/6 - Big Turbo Builds 4 07-15-2010 09:22 PM
Page generated in 0.62290 seconds with 40 queries
