 Old 10-03-2013, 06:00 PM   #1
tokoam's Avatar
Posts: 199   (View Stats)
tokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant future
Groaned at 17 Times in 4 Posts
Default BNR S3 return line leak
shortly after maybe a few weeks later my car started to smell of burning oil and exhaust gases after shutting off the car and exiting the vehicle. So putting it on the lift I saw the issue the return line started to leak.So I used silicon gasket sealer along with a new gasket and that was the end of the leak this is just a post to keep those informed of this happening as I am still using the turbo brace I guess it happened with the rocking of the motor ? I dunno But it was properly torqued and did not leak after install this started to happen over time .
tokoam is offline   Reply With Quote
The Following User Says Thank You to tokoam For This Useful Post:
breakfstincluded (10-03-2013)
 Old 10-03-2013, 07:45 PM   #2
2012FailWheelDrive's Avatar
Posts: 327   (View Stats)
Mine leaked a little after my turbo went in. I just bought a new gasket for like $3 and it fixed it. The stock one really sucked.
"under construction"
 Old 10-03-2013, 08:11 PM   #3
Always replace these crush metal gaskets when they are disturbed/removed. This goes for intake, exhaust, etc.
 Old 10-03-2013, 08:16 PM   #4
tokoam's Avatar
Lex I will get those logs to you ASAP Florida rain has been killing us . seems I still get over boost though not as much in 4th but 5th and 6th its there access port says 22.5 also I calibrate my pro sport Guage so it reads correctly now.
 Old 10-03-2013, 09:10 PM   #5
breakfstincluded's Avatar
Posts: 3,588   (View Stats)
Yay I'm not the only one who's hard line is rusted all over
 Old 11-04-2013, 08:00 PM   #6
tokoam's Avatar
looks like this bloody return line started leaking again do you happen to know the part# for both crush washers along with gaskets ? gonna have to fix this once and for all dose apt or anyone else make a more sturdy aftermarket one ?
 Old 11-04-2013, 08:10 PM   #7
2008 Mazda 3/M Parts - Online Mazda Parts
taf0422 (11-04-2013)
 Old 11-05-2013, 04:36 PM   #8
tokoam's Avatar
in the link you sent item #9 and #10 ? dose this include the metal gaskets as well ?
 Old 11-05-2013, 04:39 PM   #9
those ARE the metal gaskets unless I'm incorrect?
 Old 11-05-2013, 05:17 PM   #10
tokoam's Avatar
problem is there is no real description or OEM part# to verify plus i also need the carbon/non metallic based gasket as well.
 Old 11-05-2013, 05:22 PM   #11
alphasaur's Avatar
Posts: 2,847   (View Stats)
Groans: 235
lolwut, there's only 9 and 10. What ceramic/nonmetallic gasket?
/Turbo ep3 BWAAAAA PSH
/speed 3- bye
/lol nator.
 Old 11-05-2013, 06:00 PM   #12
tokoam's Avatar
yes this lol whats the part number for ceramic/nonmetallic gasket or dose it come with the metallic one .
 Old 11-05-2013, 06:13 PM   #13
where did you hear this from?
just get 9 and 10
Oil return line options? btstarcher MazdaSpeed 3/6 - Turbo Induction 15 10-31-2016 08:52 PM
Page generated in 0.32619 seconds with 25 queries
