 Old 06-04-2010, 02:32 AM   #1
Jasper_3MPS's Avatar
Posts: 143   (View Stats)
Jasper_3MPS has a reputation beyond reputeJasper_3MPS has a reputation beyond reputeJasper_3MPS has a reputation beyond reputeJasper_3MPS has a reputation beyond reputeJasper_3MPS has a reputation beyond reputeJasper_3MPS has a reputation beyond reputeJasper_3MPS has a reputation beyond reputeJasper_3MPS has a reputation beyond reputeJasper_3MPS has a reputation beyond reputeJasper_3MPS has a reputation beyond reputeJasper_3MPS has a reputation beyond repute
Groaned at 3 Times in 1 Post
Default BNR stage2
so iam looking to get a BNR stage2 turbo but Bryan told me that i would have to remove my stock boost solenoid.
who has the stage 2 BNR and what solenoid do you guys use. i really want a bigger turbo that spools better but dont want to go whit ATP-2871
so the BNR is just what i need.
Any advice on this mater...
Dutch Mazda 3 MPS Mica Black.
MODS
- COBB FMIC - COBB SF Intake - COBB TurboInlet - TurboSmart BOV - NGK LTR7IX - BNR Stage2 Turbo - PG Turbo Manifold - COBB Downpipe - COBB AP V3 - COBB Swaybars - TRZ RRM - TRZ TMM - NRG Torque damper - 2x Greddy OCC - PCV Mod -
Homebrew tune in the making
Jasper_3MPS is offline   Reply With Quote
 Old 06-04-2010, 02:36 AM   #2
jracer's Avatar
Posts: 1,706   (View Stats)
Groans: 89
You only have to move it to the firewall I think.. Just move the location ...
H&R springs/H&R 15mm spacers
MAP catless testpipe
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
TWM Desert Eagle shift knob
AEM wideband gauge
Prosport boost gauge
EvoX piller pod
30%Tint
Slowpoke Tuned 339hp/336tq
**** SOLD *****
2006 speed6
 Old 06-04-2010, 03:42 AM   #3
think or know for sure cause the stage 2 actuator looks really different from the stage 1 actuator...
from what i understand from bryan is that i have to replace it...
MODS
 Old 06-08-2010, 03:44 PM   #4
Just ordered the Stage2 BNR from bryan it will have to the stock actuator on it so i can still use the stock boost solenoid so 1st and 2nd gear will still have less boost. so i will not be burning my tyres to smoke that much in 1st and 2nd
i will make a complete "How to" on the install of the turbo!
will still take a month for ill have the turbo in my hands cause the freaking customs waits so freaking long!
ill keep you guys updated
MODS
The Following 4 Users Say Thank You to Jasper_3MPS For This Useful Post:
cld12pk2go (06-08-2010), Docnox (06-08-2010), MS3 Ventura (06-08-2010), speed23 (07-09-2010)
 Old 06-09-2010, 09:48 AM   #5
CyA Sp33d's Avatar
Posts: 29   (View Stats)
CyA Sp33d will become famous soon enoughCyA Sp33d will become famous soon enough
Keep us updated! I'm looking to either upgrade to the BNR Stage 1 or the Stage 2 turbo. However I am not completely positive.
2007 True Red Mazdaspeed 3
Mods: TRZ RMM, COBB SRI, CX Racing FMIC, Corksport DP, HKS SSQV V2 BOV, Pro-sport Boost Gauge-Vent Pod, 2 Resonators Removed, Yellow Fog Overlays, HD Front Lip
..... BNR STAGE 2 bought!!
CyA Sp33d is offline   Reply With Quote
 Old 06-09-2010, 09:57 AM   #6
shadesofgray19's Avatar
Posts: 794   (View Stats)
What was the issue with not getting a new boost controller? You could get the grimspeed that is plug and play or even a perrin. You are going to need a tune anyways so might was well get rid of the crappy stocker and get better turbo response.
 Old 06-09-2010, 10:08 AM   #7
Alpha's Avatar
Posts: 3,711   (View Stats)
I know a lot of guys are having issues tuning wth the Grimspeed Mazda EBC. I have a brand new one still in the box.
 Old 06-09-2010, 10:16 AM   #8
ILL3ST
xcoldricex's Avatar
Posts: 2,777   (View Stats)
why didn't you get the upgraded actuator? what's the point of upgrading a turbo if you don't want it to hold boost up top? the stock actuator has difficulty holding consistent boost above 15psi @ 5.5k and above...
there are many people running upgraded actuators with the stock solenoid... myself included.
The Following User Says Thank You to xcoldricex For This Useful Post:
Alpha (06-09-2010)
 Old 06-09-2010, 11:26 PM   #9
for one it could hit the firewall because of the large compressor housing...
and second the stock one hooks up to the ECU and keeps the boost down in 1st and 2nd gear...
if you go whit an upgraded actuator you have to delete the solinoid and i just dont want to do that rather have the ECU help me to save my car and.
i dont have any upgrade internals on my engine so whit this turbo i can run lower boost and get more HP iam only looking for around 350HP at the crank and just a really smooth tune. not going for a top HP tune just a really good smooth ride that will keep my car zoomzoomPSHHHHHHH.
maybe this is more like a stage 1.5 and not a stage2
but the larger compresor house and the larger compressor intake will mean less heat from compresion at lower boost levels and more flow... and ofcourse NO SMOKE. Oil burn will also offset your O2 sensors in the exhaust so keeping oil out of your O2 sensor is also a nice thing when tuning the car no KR and strange AFR. the 3 MPS ECU does work different than the US Speed3.
but we will see what the car will do on the dyno iam getting a befor dyno and afterdyno
so... lets hope i can be the fastest 3 MPS in the netherlands and maybe even faster than the German 3 MPS
MODS
 Old 06-10-2010, 02:22 PM   #10
ILL3ST
xcoldricex's Avatar
i just told you that i was running an upgraded actuator with the stock boost solenoid. there are plenty of others that are as well. you DO NOT have to delete the solenoid. but you will have to tune your car. if you're going through the trouble of upgrading the turbo, you should get the upgraded actuator for reasons i stated above. if you're concerned about using the stock solenoid, then just pay the $100 or whatever it is for the perrin.
also, if you're tuning with the AP( not sure if it's supported over there) you can control boost in 1-2 with your tune. also i think the 1-2 boost cut is more for traction than saving your car from blowing up...
 Old 06-10-2010, 04:51 PM   #11
DSIT995's Avatar
Posts: 1,768   (View Stats)
I think what bryan was saying was its easier to just disconnect the EBCS and run off the WG pressure b/c the actuator has a 17lbs spring in it. Kinda like the "BT" guys running just spring pressure off there EWG
Also I have to install mine (BNR 2) very soon, since my K04 has started smoking like a banshee. Definantly a seals prob
99 Miata NB - Stock for now
The Following User Says Thank You to DSIT995 For This Useful Post:
xcoldricex (06-11-2010)
 Old 06-10-2010, 05:24 PM   #12
GrimmSpeed's Avatar
Posts: 49   (View Stats)
GrimmSpeed has a reputation beyond reputeGrimmSpeed has a reputation beyond reputeGrimmSpeed has a reputation beyond reputeGrimmSpeed has a reputation beyond reputeGrimmSpeed has a reputation beyond reputeGrimmSpeed has a reputation beyond reputeGrimmSpeed has a reputation beyond reputeGrimmSpeed has a reputation beyond reputeGrimmSpeed has a reputation beyond reputeGrimmSpeed has a reputation beyond reputeGrimmSpeed has a reputation beyond repute
This is news to us. I know we've had a bunch of good feedback from our bcs and tuning. I know a couple guys that didnt have it hooked correct had some issues but once it was hooked up correctly the issues were solved.
Justin
GrimmSpeed is offline   Reply With Quote
 Old 06-10-2010, 05:37 PM   #13
idaners7's Avatar
Posts: 55   (View Stats)
idaners7 has a spectacular aura aboutidaners7 has a spectacular aura about
Groaned at 24 Times in 3 Posts
2008 sunlight sliver Mazdaspeed 3
Mods: cold air intake by injen,rally armor mud flaps red logo
Last edited by idaners7; 06-10-2010 at 05:37 PM. Reason: MSF Database - Automerged Doublepost
idaners7 is offline   Reply With Quote
 Old 06-10-2010, 08:59 PM   #14
mexicant's Avatar
Posts: 867   (View Stats)
mexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the world
Groans: 147
Groaned at 34 Times in 29 Posts
beaner stage 2. Nah, thats my car
"08, I hate to break it to you, but if it gives kevin a boner, its porn"
NATOR PERFORMANCE
Nylon washer sponsered
mexicant is offline   Reply With Quote
 Old 06-11-2010, 12:09 AM   #15
ILL3ST
xcoldricex's Avatar
i think the beaner stage 3 is the only worthwhile turbo to upgrade to.
 Old 06-11-2010, 09:10 AM   #16
Alpha's Avatar
Justin
I hope you're right as I'd love to use it (Since I've already bought it) lol
 Old 06-11-2010, 12:10 PM   #17
ILL3ST
xcoldricex's Avatar
Justin
i thought a bunch of people in the GB thread had troubles with it. maybe it was just because they weren't hooked up correctly though. i know fobio had a lot of issues getting it to work with the upgraded wga, but i think he got it sorted out.
 Old 07-09-2010, 08:44 AM   #18
i got my BNR Stage2 turbo in! will wright a how to install when its installed. and what you need.
this is a stage2 BNR whit the standart wastedgate actuator. i wanted to keep the car to stock as much as possible so running of the stock boost solenoid.
MODS
The Following 6 Users Say Thank You to Jasper_3MPS For This Useful Post:
Alpha (07-10-2010), cld12pk2go (07-09-2010), Doc (07-09-2010), Frequentflyer (07-09-2010), jayspeed3 (07-10-2010), xcoldricex (07-09-2010)
 Old 07-09-2010, 10:03 PM   #19
ILL3ST
xcoldricex's Avatar
i still think it's stupid to run the stock wga. why upgrade the turbo in the first place if you're going to have trouble running 18-19psi with that shitty wga?
 Old 07-09-2010, 11:16 PM   #20
cause i dont want to run over 18PSI cause this turbo flows more air so dont need that much boost and than i can always upgrade it later if it doesn't work that good but ill stick whit this setup for now...
MODS
 Old 07-10-2010, 04:05 AM   #21
b00b00's Avatar
Posts: 192   (View Stats)
b00b00 has a reputation beyond reputeb00b00 has a reputation beyond reputeb00b00 has a reputation beyond reputeb00b00 has a reputation beyond reputeb00b00 has a reputation beyond reputeb00b00 has a reputation beyond reputeb00b00 has a reputation beyond reputeb00b00 has a reputation beyond reputeb00b00 has a reputation beyond reputeb00b00 has a reputation beyond reputeb00b00 has a reputation beyond repute
I can put that on my key chain
b00b00 is offline   Reply With Quote
 Old 07-10-2010, 10:06 AM   #22
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
What makes you think the stock wga cannot hold over 18-19 PSI? It is holding 21-22 PSI for me with more backpressure than a BNR stage II will have.
 Old 07-10-2010, 10:10 AM   #23
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
im out the game at this point but Im curious to see what these will do!
 Old 07-10-2010, 11:05 AM   #24
ILL3ST
xcoldricex's Avatar
many people including myself cannot hold 18psi to redline with the stock wga, which is one reason why forge/ptp sell wga upgrades.
 Old 07-10-2010, 11:16 AM   #25
Ms3speed's Avatar
Posts: 172   (View Stats)
Ms3speed has much to be proud ofMs3speed has much to be proud ofMs3speed has much to be proud ofMs3speed has much to be proud ofMs3speed has much to be proud ofMs3speed has much to be proud ofMs3speed has much to be proud ofMs3speed has much to be proud ofMs3speed has much to be proud ofMs3speed has much to be proud of
So how would I hook this up? would I still run my Grimmspeed or not and I am running it in 2port mode now just like stock, would I have to switch it to 3 port or just take it out?
2009 MS3 Sport (Crystal White) Hks catback, Turbosmart bpv, Ets 3.25" Tmic, dnp manifold, turbo Xs downpipe/racepipe, Su recirc line/vac lines, Su boost tubes, Injen cai, Hypertech flash, Trz tranz & rear mm, weapon r torq damper, Rpmc tip, Methnol, H&R springs, Fcmi bump stops, Grimmspeed ebc, Jb short shift plate, Su solid shifter bushings, Msd dash hawk, laminix yellow fog films, Mtec bulbs, Motegi sp10 18x8 40Et wheels with Nitto neogen 225/40tires, Muteki lugs, debadged rear emblem/removed side moldings, 15% window tint, Su black out M logos, nextmod rear spoiler lip.
SOLD!!! You will be missed
Ms3speed is offline   Reply With Quote
 Old 07-10-2010, 11:32 AM   #26
zx2man's Avatar
Posts: 1,356   (View Stats)
zx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the world
I hope you realize that the stage 2 doesnt really have much advantage over a stock turbo in the 15-18 psi range. I myself was leaning towards a stage 2 and emailed Bryan. I told him that Id like to make 320-340 whp...He told me I could certainly get there with stage2, but id be running 23-24 psi to do it. Theres quite few of us fully bolted running 16-18 psi stock turbo making 300 whp..and thats prabaly where your gonna be at with the stage2..maybe 5-10 more whp..but thats it..to make "more" power youll need to push that stage2 beyond the psi range you want, BUT it should run alittle cooler than the stocker, and not smoke on you, and honestly thats prabaly the main reason why you should buy it, Certainly not to make MORE power but not go over 18 psi..just not gonna happen.
True........and with my protune I still hold 16-17 psi to around 6300 or so..but ALOT of people do not hold boost very good the with stock wga, and I can totaly see where coldrice is coming from.
2009 MS3
COBB AP
COBB INTAKE
COBB/TURBOXS TBE
DNP TURBO MANIFOLD
CXRACING FMIC
TURBOSMART BPV
JBARONE RMM
TURBOSMART BPV
JBARONE SHIFTERPLATE
COBB RSB
KONIG WHEELS/HANKOOK TIRES
TIM BAILEY PROTUNE 291WHP/310WTQ *AWD MUSTANG DYNO*
zx2man is offline   Reply With Quote
 Old 07-10-2010, 12:46 PM   #27
ILL3ST
xcoldricex's Avatar
exactly, it's basically throwing $1200 at something that's built a bit better than the stock k04. this coupled with you not wanting to run the turbo over 16psi and not to redline... it seems like a total waste of time and money to me. i would've just bought a bunch of stock k04's - you could probably buy at least 6 used k04's for $1200.
jasper, are there any tuning solutions for your ecu?
 Old 07-10-2010, 02:22 PM   #28
well the EU ECU seems to work a bit different from the USDM ECU from the tuner that i talked to putting 300HP whit a stock turbo wouldent be a problem he has tuned around 20 Mazda 3 MPS.
he said runing 1.3bar boost wouldent be a problem but iam going to see what the car makes on the Dyno and than ill see what i want. cant say for sure now what the car would do.
iam not looking to make a tikking timebomb i want steady HP and no top HP and that is what the stage2 can do for me. just wait and see
@Ms3speed:
ill will be posting a complete Manual on how to install and what parts you would need and tools and stuff. cause you do need some new hoses to connect everthing up and you would need to move the stock boost solenoid but just wait for me to get it done and it will be just like putting a IKEA thing togheter
MODS
 Old 07-10-2010, 02:49 PM   #29
zx2man's Avatar
Yes you can make 300 whp on stock turbo...I just said that in my previous post. But you not gonna make much more power with the stage2 bnr below 20 psi!!!!.
Look I made 291 whp on a mustang dyno @ 17 psi. Since then I installed a DNP turbo mani,fmic and turboxs catback.
The car felt more responsive and pulled harder once I put the turbo mani on!..butt dyno felt nice....combine that with the fmic which makes my car run alittle cooler and my boost is now 19 instead of 17..I bet when my car gets retuned @surgeline I think ill be around 315-320 whp on that same dyno, and prabaly 330-340 whp on a dynojet. Thats pretty much it for me,fully bolted-stock turbo-properly tuned.
@ the same psi I seriously doubt your gonna make more power with the bnr stage 2....like I isaid before..its a better built turbo, but is that worth 1200 bucks? I dont know..for peace of mind..maybe for some people.....each thier own..and I can REPESCT that. But not for power purposes...not untill you push that stage2 past 20 psi will you see alittle more power. Look forward to your dyno..and also what kind of dyno-...I will do the same in the next few weeks
2009 MS3
COBB AP
COBB INTAKE
COBB/TURBOXS TBE
DNP TURBO MANIFOLD
CXRACING FMIC
TURBOSMART BPV
JBARONE RMM
TURBOSMART BPV
COBB RSB
The Following User Says Thank You to zx2man For This Useful Post:
xcoldricex (07-10-2010)
 Old 07-10-2010, 11:30 PM   #30
its a dynostar google for more information
from what i have heard of dutch chiptuner he said that hitting 350Hp should be possible whit the setup that i have so iam going at his words. and than again we will see
i think ill be happy when my car doenst smoke any more and the smoke plumes stop comeing from my exhaust
MODS
 Old 07-10-2010, 11:55 PM   #31
ILL3ST
xcoldricex's Avatar
@Ms3speed:
i don't think it's any more complicated than replacing the stock turbo.
 Old 07-11-2010, 05:13 AM   #32
Eth/Meth Junkie
cld12pk2go's Avatar
I tend to think it is more of a problem of flow limitations on the stock turbo (compressor running up against the choke line) instead of a mechanical limitation of the stock WGA.
One question though, are the people with this issue running an upgraded exhaust manifold? If not their pre-turbine pressure would likely be a good big higher than mine resulting in more pressure against the WGA for a similar massflow making them less capable of holding higher boost pressure.
I can get ~18PSI at redline and more earlier, but this is pretty much all the stock turbo has to offer above 5000 RPMs (WGDC at 100%):
I can easily run more boost below that by just targeting higher loads, and I am currently doing that. Moving closer to 22 PSI than to 21 PSI that was my target on that run.
 Old 07-11-2010, 07:06 AM   #33
ILL3ST
xcoldricex's Avatar
look at your log - you're maxing out your wastegate and you can't hold 19psi to redline. exactly like i said. if you want to hold 19psi+ to redline, you need to upgrade your wga. the stock turbo can do it if you upgrade your wastegate...
that's why i keep encouraging jasper to run the upgraded wastegate, he's going to have the exact same problem as you on his expensive new turbo that's supposed to give him gains.
no, most people are using stock manifolds i believe... but i can get 22 psi all throughout the powerband.
 Old 07-11-2010, 07:37 AM   #34
Eth/Meth Junkie
cld12pk2go's Avatar
Do you have logs of people holding more than 19PSI on the stock turbo with the upgraded WGA? Do they actually make more power?
I am already spinning the stock turbo well off the right side of the compressor map.
Spinning the compressor at a higher RPM might yield higher pressure (PSI) but it is unlikely to be the result of more mass flow, it will be probably be due to higher discharge temp (not good).
 Old 07-11-2010, 07:39 AM   #35
i know having a upgrade wastegate actuator would give more room to tune the crap out of it but thats not what iam looking for. this stage2 also has a bigger compressor house so whit the same boost you get more flow. but than again we will see.
and the wright up is just for people who think that it is a complex job and than again you do need some other parts so also handy if you dont need to look up all those parts
MODS
 Old 07-11-2010, 07:49 AM   #36
ILL3ST
xcoldricex's Avatar
considering you're basically maxing your wastegate starting at about 5k, you have 1.5k of consistent boost you're missing. yes, you make more power.
someone did dynos, i don't remember who. but there was no gain in power going from 20 to 22psi up top. going from 18 to 20, yes. search for it.
since you're running meth, i feel like you have a bit more power to squeeze out of the stock turbo...
jasper, well you'll see. i doubt you'll net much more power not turning up your boost and just relying on the compressor housing. i've already told you on numerous occassions so, you'll just have to see for yourself.
 Old 07-11-2010, 09:45 AM   #37
Eth/Meth Junkie
cld12pk2go's Avatar
No luck finding the dynos you speak of after 20min of searching...
 Old 07-11-2010, 10:16 AM   #38
ILL3ST
xcoldricex's Avatar
yeah me neither. it was someone doing multiple pulls and decided to go up to 22 to compare to 20.
 Old 07-11-2010, 11:00 AM   #39
Talk to Fobio - he was able to hold more boost up top.
 Old 07-11-2010, 11:15 AM   #40
ILL3ST
xcoldricex's Avatar
yeah, he is running an upgraded wga too...
Feedback on the Stage2+SF 93 map speedzilla MazdaSpeed 3/6 - ECU Computer Tuning 5 04-16-2010 12:11 PM
Stage2+SF 93 Octane manofhonor24 MazdaSpeed 3/6 - ECU Computer Tuning 13 10-05-2009 11:06 PM
Stage2+SF 93 v103 MAF Fix evidence MazdaSpeed 3/6 - ECU Computer Tuning 15 05-12-2009 02:13 PM
1.03 stage2+sr 91 -> 93 - logs evidence
Cobb Access Port/Maps
1 04-04-2009 06:53 AM
Stage2+SF 91 +TMIC prspect
7 02-21-2009 11:07 AM
Page generated in 0.58074 seconds with 36 queries
