 Old 03-31-2009, 08:29 AM   #1
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
Default Boost Gauge Flutter
Ok so I've tried 2 mechanical boost gauges now (prosport and stri) and both have needle flutter/vibrate/buzz, whatever you want to call it, when i hit peak boost which is about 19.5-20psi. some say that it could be a leak somewhere causing this or i just need to add a restrictor on the line. i am using 1/8" nylon tube that came with my stri x-line gauge and the problem is still there. anyone have this issue with the mechanical gauges?
looks like this
 Old 03-31-2009, 09:15 AM   #2
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
mine flutters, but its like 10x worse than in that video.
'08 CWP MS3 w/ T3 3071r
 Old 03-31-2009, 09:19 AM   #3
clos561's Avatar
Posts: 1,172   (View Stats)
clos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the world
mines flutters if i stay under vacuum for week or so only because the plastic tubing gets squished together. Try checking your lines for any kinks because the heat messes mine up. I dont have mechanical tho. And i also have a little filter installed on mine that came with the prosport premium, its to keep dust or anything out of the reciever for the psi
7-Inch Jensen Flip Out Touch Screen, HKS SSQ, MS CAI, Prosport Premium Amber/White Boost Gauge,2nd Cat Gutted, Delrin TRZ MM,16 inch FD rims,TWM shifter Bushings,COBB Turbo Inlet, 28psi, rebuilt stock block, custom rods and piston heads/gaskets, underdrive pulleys, big cams, big oil filter, stage4 clutch, stage4 DISI injectors, Fuel Pump, 4inch Catless TBE with screamer pipe, external wastegate spring modification,Methanol direct twin port duty cycle injection. Tuned by Nator Performance
clos561 is offline   Reply With Quote
 Old 03-31-2009, 09:19 AM   #4
bova's Avatar
Groans: 45
i dont think mine is that bad but it flutters.
as for the hose, mine is like hard nylon so it can't really kink or anything.
 Old 03-31-2009, 11:13 AM   #5
egbertnr's Avatar
Posts: 186   (View Stats)
egbertnr is a name known to allegbertnr is a name known to allegbertnr is a name known to allegbertnr is a name known to allegbertnr is a name known to allegbertnr is a name known to all
I have an autometer on my Focus and it flutters like mad, drives me nuts, i have looked time and time again for leaks and kinks but nothing. tempted to try another boost controller...
2011 FX4 TT'd V6 SuperCREW F150 Blue Flame Metallic
egbertnr is offline   Reply With Quote
 Old 03-31-2009, 12:04 PM   #6
bova's Avatar
Groans: 45
i have been looking on line and found this pressure gauge stabalizer. third product down only $3.95
DieselManor - Accessories
there is also this from http://www.boostcontroller.com/index.php?item=256
http://www.boostcontroller.com/index.php?item=161
The Following User Says Thank You to bova For This Useful Post:
802MS3 (03-31-2009)
 Old 03-31-2009, 06:01 PM   #7
Docnox's Avatar
Posts: 1,435   (View Stats)
Docnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the world
Groans: 35
My autometer flutters quickly when I hit peak, but only for a second, then it is fine. Mine is nowhere near as bad as the video.
'06 Speed 6
Black Mica
Mazdaspeed SRI, Medieval inlet, Eibach Springs, Magnaflow cbe,
3 ebay catless dp, SU rmm, HKS ssqv, JBR stage 2 ssp
Altered Customs fmic, Autotech fp internals
Cobb AP, Stage 2+ 93 tweaked
Centric blanks, EBC red pads
Lotek center gauge pod: AEM wideband, Autometer boost and volts
Tints, blacked emblems, spec-v front lip, Shark fin
Redline MT-90, ITV-22s, Matt Damond OCC
13.66@102 Lebanon Valley 4/10/11 (sri, tp, rmm, ap)
DO Meth kit waiting on install
Docnox is offline   Reply With Quote
 Old 03-31-2009, 06:01 PM   #8
Docnox's Avatar
Groans: 35
And I like your avator Bova. Nice wheels.
'06 Speed 6
Black Mica
 Old 03-31-2009, 06:09 PM   #9
Alittle Faster
bioevolve's Avatar
Posts: 3,522   (View Stats)
I have a Prosport Mechanical boost gauge and it doesn't flutter like that. What's up with that?
bioevolve is offline   Reply With Quote
 Old 03-31-2009, 06:32 PM   #10
Boost Whore
Unoriginalusername's Avatar
Posts: 1,757   (View Stats)
Unoriginalusername is the leader of the worldUnoriginalusername is the leader of the worldUnoriginalusername is the leader of the worldUnoriginalusername is the leader of the worldUnoriginalusername is the leader of the worldUnoriginalusername is the leader of the worldUnoriginalusername is the leader of the worldUnoriginalusername is the leader of the worldUnoriginalusername is the leader of the worldUnoriginalusername is the leader of the worldUnoriginalusername is the leader of the world
Groans: 223
wow thats why i didn't go with cheap gauges... madad ftw
"God created turbo lag to give v8's a chance"
Unoriginalusername is offline   Reply With Quote
 Old 03-31-2009, 06:45 PM   #11
bova's Avatar
Groans: 45
is your madad gauge mechanical?
 Old 03-31-2009, 06:45 PM   #12
m4tic's Avatar
Posts: 4,928   (View Stats)
you need a restrictor pill going to the gauge.
my prosport works perfect...
sorry the vid is sideways, from my phone
2017 Daytona 392
STOLEN//2015 BMW S1000R
2007 MS6 w/ Cheez
 Old 03-31-2009, 06:55 PM   #13
Boost Whore
Groans: 223
you bet
 Old 03-31-2009, 07:07 PM   #14
bova's Avatar
Groans: 45
well i fixed the problem. i just moved the filter i have on the hose for the hks ssqv to before the T so now it filters for both the ssqv and my boost gauge. no more flutter.
 Old 03-31-2009, 07:13 PM   #15
bova's Avatar
Groans: 45
 Old 03-31-2009, 08:54 PM   #16
egbertnr's Avatar
you moved the filter...do you have a pic or something I would like to see that.
 Old 03-31-2009, 08:57 PM   #17
bova's Avatar
Groans: 45
not til tomorrow but i'll explain
it goes from intake manifold to the filter to the t fitting then the t goes to hks ssqv and boost gauge.
 Old 03-31-2009, 08:59 PM   #18
egbertnr's Avatar
filter...are we talking orifice here actual filter...I will wait for pics....a little cloudy here.
Thanks again for the explanation
 Old 03-31-2009, 10:22 PM   #19
skeeter149's Avatar
Posts: 3,742   (View Stats)
Groans: 91
the hks comes with a little round fitler for the vac line
HKS MINI VACUUM FILTER: 6MM-Options Auto Salon
bad pic lol.
The Following User Says Thank You to skeeter149 For This Useful Post:
egbertnr (04-01-2009)
 Old 04-01-2009, 04:58 AM   #20
bova's Avatar
Groans: 45
exactly, its like a fuel line filter but its the one skeeter pictured. basically it helps keep pulse waves down, which creates that flutter in gauges. thats not it's main purpose obviously, but it helps.
 Old 04-01-2009, 06:33 AM   #21
egbertnr's Avatar
I might have to try one of those, to see if it helps my car.
Thanks guys
 Old 04-13-2009, 11:00 AM   #22
2k6speed6's Avatar
Posts: 86   (View Stats)
2k6speed6 will become famous soon enough
As described above. Had a mechanical autometer boost gauge. Did the same thing.
2k6speed6 is offline   Reply With Quote
Boost gauge vs. AP boost reading.. which is correct? Unoriginalusername MazdaSpeed 3/6 - Turbo Induction 13 05-23-2011 05:41 PM
Why does my boost gauge flutter like crazy at WOT? 802MS3 MazdaSpeed 3/6 - Turbo Induction 14 02-06-2009 05:47 AM
Help with boost gauge! Mazdagoat324 Mazdaspeed3/6 General Discussion 21 01-25-2009 06:49 PM
Boost Gauge + MBC badams118 MazdaSpeed 3/6 - Car Audio & Electronics 1 10-30-2008 09:45 AM
Page generated in 0.41233 seconds with 29 queries
