 Old 09-10-2011, 05:39 PM   #1
Matrix311's Avatar
Posts: 2,133   (View Stats)
Default Boost leak at this sensor by oil cap??
I was doing a boost leak test on my car today and had a few small holes around some of the welds in my intake. I jb welded them and fixed the holes. After I fixed the holes a new leak occured and not sure if this is normal or not but there is a sensor next to the oil cap and connections to the first ignition coil and tons of air is coming through this when i charge my system up to about 15psi. Is this normal or not?
I've attached a picture of the sensor. It leaks air weather the sensor is plugged in or left unplugged. If this needs to be replaced what is the part number and what is this sensor called? No clue why it's leaking air because it wasn't leaking earlier today and now it is.
Is it safe to drive my car with this leak? There's a pretty significant amount of air coming through there.
Picture attached.
 Old 09-10-2011, 05:40 PM   #2
m4tic's Avatar
Posts: 4,928   (View Stats)
you are not supposed to fill the valve cover with pressurized air or am i missing something
2017 Daytona 392
STOLEN//2015 BMW S1000R
2007 MS6 w/ Cheez
The Following 2 Users Say Thank You to m4tic For This Useful Post:
Chimmike (09-10-2011), MS3Shadow (09-08-2015)
 Old 09-10-2011, 05:42 PM   #3
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
how did you manage to pressurize your crankcase?
07 MS3
The original Genpoo Hater
 Old 09-10-2011, 05:43 PM   #4
TWOptSL0W's Avatar
Posts: 3,289   (View Stats)
Groans: 125
**whether
 Old 09-10-2011, 05:46 PM   #5
Matrix311's Avatar
no clue why there is air in there. I hooked up the boost leak tester I made the end of my intake. I removed the filter and connected it there and pressurized the system. Ive been testing all morning and part of the afternoon repair a bunch of small hair pin holes all over my cp-e CAI around the MAF sensor. I had 2 clamps that were loose but majority were around the MAF sensor on my CAI.
If the crankcase is pressurized is that bad? Maybe i've done to many tests and it's entered that part of the engine, not exactly sure. How else would it get in there?
 Old 09-10-2011, 05:48 PM   #6
TWOptSL0W's Avatar
Groans: 125
its fine, mine does that too, not from that sensor, but you have the breather on the back of the cover for that specific reason. you may want to put a new gasket on that sensor if you can get one, but i wouldnt stress about it
 Old 09-10-2011, 05:50 PM   #7
Matrix311's Avatar
what about the crankcase getting air in it, is that a problem? Like I said this never started happening until after all of my other boost leaks were fixed.
 Old 09-10-2011, 05:53 PM   #8
TWOptSL0W's Avatar
Groans: 125
yea im not sure why it happens. sometimes i get it sometimes i dont. it could be through the pcv system
 Old 09-10-2011, 06:00 PM   #9
Matrix311's Avatar
ok cool
 Old 09-10-2011, 06:02 PM   #10
m4tic's Avatar
you should plug the bpv hose
2017 Daytona 392
2007 MS6 w/ Cheez
 Old 09-10-2011, 06:18 PM   #11
Matrix311's Avatar
Ya I did take it off the bpv but i didn't have anything laying around to plug it. I need to find something to plug it. I want to test my bpv to make sure it's not leaking as well. I have the HKS SSQV2 which are known to leak. I'll test that another time once I have something to plug the recirc hose.
 Old 09-10-2011, 06:24 PM   #12
kmac's Avatar
Posts: 1,792   (View Stats)
Cap the valve cover vent line while testing.
 Old 09-10-2011, 06:36 PM   #13
Matrix311's Avatar
Where is that at?
 Old 09-10-2011, 06:40 PM   #14
kmac's Avatar
On the intake, the hose that goes from the intake to the valve cover.
 Old 09-10-2011, 07:08 PM   #15
Will fuck up ur day
Chimmike's Avatar
Groans: 433
exactly. When you put the damn cap on the end of your intake, you were pressurizing the crankcase too via the breather from the intake to the vc.
Leak testers are best on the compressor inlet at least, but the best best is the beginning of the hot side piping at the compressor outlet.
07 MS3
kmac (09-10-2011)
 Old 09-10-2011, 07:23 PM   #16
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
lulz, start the car see wat happens
 Old 09-11-2011, 10:48 AM   #17
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
The valve cover PCV valve is designed to block air from being sucked back into the crankcase, it is not designed to block air from being blown into the crankcase from the intake because that area never sees boost.
You need to block off the valve cover breather hose, it is the big hose near the CDFP that goes to the intake.
If you are only leak testing the hot side and you pressureized the crankcase to the point that the oil control valve started leaking then I would say you have a bad crankcase PCV and a bad valve cover PCV.
2006 Mazdaspeed 6
 Old 08-12-2015, 10:21 AM   #18
Dahouse702's Avatar
Posts: 487   (View Stats)
Dahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the world
anyone know if there is a writeup on replacing that seal? also would like to know the part number...
2007 MS3 Black Mica-Totaled @98500 on 09/2014
Current Car...
2009 MS3 Black Mica GT JBR TRU 3.0 Widepath full intake, BNR S3 v1, GS EBCS, 3 BAR , Forge BPV V2, Autotech internals , Denso Itv22, CNT Downpipe, CX-Racing piping with Cobb v2 core, Cobb AP v2, JBR RMM, JBR PMM, JBR TMM, JBR Oil Catch Can, EGR Delete, JBR TIG, Toyota Seals, HTP battery tray, DashHAWK
Zoom Zoom
Dahouse702 is offline   Reply With Quote
 Old 08-12-2015, 11:38 AM   #19
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
L3K9-10-2D5A
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 09-08-2015, 07:26 AM   #20
toosavage86's Avatar
Posts: 9   (View Stats)
toosavage86 will become famous soon enough
I had the same issue with the same seal. It's nothing to worry about. Just cap off the vc when your testing for leaks. Even if you replace that seal it'll still leak.
If you still want to replace it you can buy a oem replacement seal from edge. I don't know the part number off hand.
Replacing the seal is pretty straightforward as well. Just take the valve cover off, pull the sensor out, then you can pop the old seal out and swap it with the new one.
toosavage86 is offline   Reply With Quote
 Old 09-08-2015, 11:35 AM   #21
mituc's Avatar
Groans: 111
Don't even bother replacing it. After a while it will stop leaking. But it takes a while before all that oil becomes like a gunky glue and seals the seal (!!).
Boost leak? mrQQ MazdaSpeed 3/6 - Turbo Induction 16 04-09-2011 02:09 AM
Vacuum leak, but no boost leak? vbt101 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 23 04-18-2010 01:06 PM
Boost Leak(need help phantomspeed3 MazdaSpeed 3/6 - Turbo Induction 30 05-21-2009 10:19 AM
Boost leak? or something else? GOT 2RBO MazdaSpeed 3/6 - Turbo Induction 11 05-01-2009 04:27 PM
Boost leak or what? TotallyNotAmused MazdaSpeed 3/6 - Turbo Induction 12 04-15-2008 05:33 AM
Page generated in 0.39250 seconds with 30 queries
