 Old 09-12-2018, 10:12 AM   #1
Jeff23spl's Avatar
Posts: 2,233   (View Stats)
a leak at the wastegate vacuum line would increase boost. look for something not flowing thru when looking there. A BPV could easily leak enough to drop boost too without making a leaking noise while driving...
For reference, my K04 on spring pressure was about 10-11psi.
interesting, mine made a bit more but it was early this summer and i had a DP on stock catback. I bypassed the ebcs vac hose to check something and was like 11-12 with peak at 14...
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
Last edited by Jeff23spl; 09-12-2018 at 10:13 AM. Reason: MSF Database - Automerged Doublepost
Low boost 13psi jtimms6 MazdaSpeed 6 - Engine, Transmission & Driveline 3 09-09-2018 11:12 AM
Not hitting boost targets, not boost leak ADHDAdditiv MazdaSpeed 3/6 - Troubleshoot/Diagnostics 28 07-18-2014 02:18 PM
boost tuning, not hitting easy boost targets? Caldazar MazdaSpeed 3/6 - ECU Computer Tuning 11 05-18-2012 06:09 PM
Not hitting Stage 2 boost targets (boost leak?) Bubba Ho-Tep 2010 MS3 - ECU Computer Tuning 15 04-26-2012 08:25 PM
Not Hitting Boost? KrishyC Gen2 MS3 General Discussion 8 03-28-2012 09:06 PM
Page generated in 0.23310 seconds with 22 queries
