Like Tree5Likes
 Old 07-17-2015, 01:43 PM   #41
Police
InkedInspector's Avatar
Groans: 312
Don't be hating on the Sword clang!
 Old 07-17-2015, 04:29 PM   #42
AwAfrican's Avatar
Posts: 1,038   (View Stats)
I have forge v2 and almost want to trade it for a v1 just so I can have ninajs fighting under my hood
sent via tapafail!
2013 Black MS3
 Old 07-17-2015, 04:40 PM   #43
BlackFlag's Avatar
Posts: 596   (View Stats)
I like my ricey v1. It literally scares asshole pedestrians that walk towards my car while im driving. Drive through the ghetto one time and see what I mean.
Slow for now...
Freek Tuning Meow
 Old 07-17-2015, 08:21 PM   #44
speed6_5127's Avatar
Posts: 21   (View Stats)
speed6_5127 is a jewel in the roughspeed6_5127 is a jewel in the roughspeed6_5127 is a jewel in the roughspeed6_5127 is a jewel in the rough
Groaned at 17 Times in 6 Posts
Intake is next. Cobb SF sounds like the way to go so that is what I am going to go for. And I was given the Forge so wasn't my exact choice but I wasn't gonna say no...
speed6_5127 is offline   Reply With Quote
 Old 07-17-2015, 08:27 PM   #45
AwAfrican's Avatar
Get 3-3.5" intake either JBR or htp...upgrade once if you ever want to upgrade your turbo at all
sent via tapafail!
2013 Black MS3
 Old 07-17-2015, 09:08 PM   #46
I'll check them out. 170 for the stage 1, not bad at all. Only 20 more than the cobb sf
 Old 07-18-2015, 04:24 AM   #47
HaXiR's Avatar
Posts: 315   (View Stats)
HaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud of
BOV/BPV Thread
All you need to know about BOV's.
On the subject of intakes, HTP 3" is a good intake, but how do these companies get away with the highway robbery of charging almost twice as much for a 3.5 in intake compared to a 3 in intake? It blows my mind, nothing changed other than the size lol. I went cheap and got 3 in.
2008 Ms3 Black Mica R.I.P. March 2008 - March 2016. MODS: HTP 3" intake, CX Racing FMIC with TR8 core, BNR S3, AP V3, Kozmic EGR delete, Matt Damond OCC, JBR short shift plate with bushings, HIDS, CP-E injector seals, TIG, 1 step colder plugs, Grimspeed EBCS, CS RMM, JBR passenger MM, motor craft tranny fluid, Autotech Internals
Current:
08.5 Ms3 cwp GT: Built block (sp63 4032 pistons, eagle h beams, CA625+ rod bolts/head studs, arp main studs, key'd crank, supertech 55lb valve springs, bsd delete, Block/pistons/rings/bearings WPC treated), HTP 4" intake, bnr S5 turbo (when it comes out), HTP hotside under route pipes, TR8 core, custom made cold pipes, ST intake mani, TIG, CP-E downpipe, CNT CBE, autotech hpfp, AP V3, grimmspeed ebcs, GA v3, TWM short shift assembly, JBR short shift plate, HFS-4 Meth kit, HTP front mount custom meth tank, damond motor mount trilogy, damond 3 port pcv plate, dual damond catch cans (one vented), step colder plugs, corksport injector seals, GFB bov, 51r battery, Bilstein B8 shocks, OZ ultralegga rims, custom oem clutch with Kevlar, Gen 2 trans.
2003 Mazdaspeed protégé (spicy orange); pope E manifold and DP, injen cai, PoS fmic kit, Twisted motion gt2871 turbo, aem fic-6.
HaXiR is offline   Reply With Quote
BNR S3 V2 pre-install questions Addikted To Boost MazdaSpeed 3/6 - Big Turbo Builds 5 05-22-2015 10:14 PM
JBR 80a RMM post install questions. csmaan12 2010 MS3 - Engine, Transmission & Driveline 13 08-18-2014 11:50 AM
Coilover Install Questions innotech MazdaSpeed 3/6 - Suspension & Brakes 1 07-09-2010 04:53 PM
Cobb STS install - Questions KayWhy MazdaSpeed 3 - Engine, Transmission & Driveline 6 04-18-2010 02:28 PM
Page generated in 0.26538 seconds with 25 queries
