![]() | | #401 | ![]() |
| Fux Wit It ![]() ![]() Join Date: Mar 2008 Location: Li
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,795
Groans: 175
__________________ ![]() Carry on citizens.... [CENTER]Pump Gas Champ 10.9 @ 12810.6 @ 129 E85 (IC coupler popped) 10.7 @ 133 auto 1G DSM 2013 C6 GS FBO and alotta Nitrous |
![]() | | #402 | ![]() |
![]() Join Date: May 2008 Location: NOVA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 122
Groaned at 47 Times in 40 Posts
| Not Ranked : 0 score but chuck norris would have been able to do it because NOTHING is impossible for him. You know science is bullshit the only element he recognizes is the element of surprise....
__________________ a built motor is not a built motor without being sleeved |
![]() | | #403 | ![]() |
| Banned ![]() Join Date: Jun 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 283
Groans: 213
Groaned at 274 Times in 187 Posts
| Not Ranked : 0 score i want a jet powered car like darksun.. its just not fair.. fuck my life |
![]() | | #404 | ![]() |
| Not Ranked : 0 score With the bigger EWG you should be abke to run a much stiffer spring without fear of big spikes a small IWG would get. The best way to set boost on any turbo car is to let the WG do most of the work and only fine tune with a boost controler. I would get like a 10psi spring personally. |
![]() | | #405 | ![]() |
| Thermonuclear Skeet ![]() Join Date: Jul 2008 Location: Triad N.C.
Rep Power: 3875 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,765
Groans: 188
Groaned at 333 Times in 222 Posts
![]() | | #406 | ![]() |
![]() Join Date: Mar 2008 Location: NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 89
| Not Ranked : 0 score What is different about the army green SteedSpeed manifold? Who is doing the install? My driveway is free Saturday. Edit: Wheel of Fortune the boost knob...LOL you are still my hero.
__________________ If anyone needs install help in my area (Bergen County NJ) let me know. I have all the tools and work for cheap. |
![]() | | #407 | ![]() |
Groans: 175
(Thread Starter) | Not Ranked : 0 score I'm trying man just a couple more spins
| The Following 4 Users Say Thank You to Darksun280 For This Useful Post: |
![]() | | #408 | ![]() |
Groans: 175
Chris is coming over to dyno on sat so I have to be back to hang with him.
__________________ ![]() Carry on citizens.... [CENTER]Pump Gas Champ 10.9 @ 12810.6 @ 129 E85 (IC coupler popped) 10.7 @ 133 auto 1G DSM 2013 C6 GS FBO and alotta Nitrous | ||
![]() | | #409 | ![]() |
![]() Join Date: Mar 2009 Location: West Hartford, CT
Groaned at 6 Times in 3 Posts
| Not Ranked : 0 score I disagree! One of my boys has a 947whrp evo and it's all grab and go on that thing! 30mph on street tires vs. Hayabusa was a joke 230mph busa was 10 lengths back then we almost died their was a turn coming! Stoptech keeeps getting thank u letters LOL |
![]() | | #410 | ![]() |
Groans: 60
| Not Ranked : 0 score You need to set the wastegate near your average boost you want to run. I would go at least 1.2 bar..
![]() | | #411 | ![]() |
| Not Ranked : 0 score Thats way too high ! 1.2 bar is like 17.5psi !! If that is the actuators crack pressure you would get HUGE spikes ! You want your spring pressure to be about 70% of your boost target. That will land a mild spike just about dead on your target. Then yoir boost controller will do the job to maintain it. |
![]() | | #412 | ![]() |
Groans: 188
| Not Ranked : 0 score You can eat up a Busa with 650 if your geared right. I agree with fbpem1 1000 hp on anything with street tires is worthless. I beleive your boys evo was making more in the neighborhood of 500-600 |
![]() | | #413 | ![]() |
Groans: 60
I think I have mine set at 1.3 bar, with a 44mm wastage and the EBCS there should be little to no spike at all...Should sit right around 17~18psi for daily driving, and I can turn it up at the track..
__________________ Fully Built : Arias Pistons: Pauter Rods : ARP bolts: Ported Head: Cosworth BSD : Spec 3+ Clutch : Fidanza Flywheel : AWR Engine mounts 90duro : Custom TIP/Intake : Custom Blow Through 3.5" MAF : Custom FMIC : HKS SSQV VTA : Ported IM : Custom DP : Custom Exhaust : CPBoost Top Mount EM : Garrett GT3582R : PTP Turbo Blanket: Tial V44 EWG : Perrin EBCS : MrLilGuy/PTP HPFP : Ported fuel line : Ported Fuel Rail : Custom Ported Fuel Injectors : Kenny Bell Boost-a-Pump : HKS Twin Power DLI II : HKS M-Series Plugs : Cobb AP : AEM 3.5bar MAP :Koni Sport shocks : RPM Kspec Springs : TWM STS : TT Front Diff Mount : CPE Upper Diff Mount : Whiteline RSB : AWR Endlinks | |
![]() | | #414 | ![]() |
![]() Join Date: Mar 2008 Location: PA
Rep Power: 1819 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,082
Groaned at 39 Times in 23 Posts
never spiked once with the 35r as a matter of fact even with the stock turbo, the MBC I was using could tune out the spike due to having both a bleed and ball/spring feature the TurboXS MBC has this disconnecting the boost solenoid was the best thing I did for how my car ran some will disagree and that's OK the more you dumb down the Mazda ECU, the happier you'll be
__________________ 2006 Mazdaspeed 6 / 386awhp/376awtq (Aug 2008) 2008 Caliber SRT4 / 11.8 @ 120 | |
| The Following User Says Thank You to whoosh@Realtune For This Useful Post: | Crossbow (04-01-2009) |
![]() | | #415 | ![]() |
![]() Join Date: Mar 2008 Location: Fort Hood, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9
lol J/k don't shoot me.
__________________ 07 TrueRed Mazdaspeed3>> SOLD 03 BlueByYou Evolution VIII Autronic PNP StandAlone, 264 BC Cams, Unorthodox Cam Gears, 720cc Injectors, AEM short intake, GReddy IC, HKS IC pipes, HKS Boost controller, TB exhaust, DNP DP, DNP 02 pipe, Megan exhaust manifold, Ported Turbo, Light Flywheel, Triple Carbon clutch, TorqueSoutions engine mounts. [SIGPIC][/SIGPIC] | |
![]() | | #416 | ![]() |
![]() Join Date: Mar 2008 Location: Victoria TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 405
Groans: 70
| Not Ranked : 0 score So am i fucked?i have a 1.2bar spring in mine (17psi) that im about to install with my stock turbo in a few weeks? 17psi was the amount i wanted to run too.
__________________ Black 2003 Evo VIII-3in TBE,HKS 280's,ETS Intake,Halman pro MBC,Forge BOV,Precision 6262,4" Intercooler,AEM Meth injection,Manely S&R's.4G63 FTW! |
![]() | | #417 | ![]() |
Groans: 175
(Thread Starter) | Not Ranked : 0 score guess your just going to have to turn up the boost more. lolololol
![]() | | #418 | ![]() |
Groans: 188
| Not Ranked : 0 score Next thing your going to say is that he rides around on 947whp everyday right? I'm not doubting he made 947hp on a dyno or even if he beat the busa or not, but even if he was driving around on octopus tentacle tires and 15 inch wide wheels, your not sticking 1000 to the ground at any normal speed no matter how many wheels you spin on street tires and damn sure not at 30mph. Maybe in vietnam but not in America. Just sayin |
![]() | | #419 | ![]() |
Groans: 70
| Not Ranked : 0 score lol i only want to run 17lbs
![]() | | #420 | ![]() |
Groans: 175
| The Following User Says Thank You to Darksun280 For This Useful Post: | Grim (04-12-2009) |
| The Following User Says NO Thank You to Darksun280 For This Un-useful Post: |
![]() | | #421 | ![]() |
Groans: 70
| Not Ranked : 0 score lol im not as hardcore as you.But just for you ill run 20.
![]() | | #422 | ![]() |
Groans: 175
(Thread Starter) | Not Ranked : 0 score Meowbert approves. Groan rescinded
![]() | | #423 | ![]() |
Actually I was making fun of xxspeed3 typing WHRP instead WHP or RWHP, but .....whatever.
![]() | | #424 | ![]() |
Groans: 188
![]() | | #425 | ![]() |
![]() Join Date: Apr 2009 Location: Cincinnati
Rep Power: 2046 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,096
Evo -> AWD = grip at higher power levels, but not 900+ on street tires
A full 1000hp on street tires may be worthless at lower speeds, but most cars with that much power (if done right) will have a programmable boost controller so you don't see anywhere near that in the first few gears and you can still grip. | ||
![]() | | #426 | ![]() |
![]() | | #427 | ![]() |
| Not Ranked : 0 score I'm retarded. I searched for 'Darrell Cox Racing' and started reading this thread. After reading all 11 pages, I completely failed to realize that nobody has posted here in like 20 days. |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/cars-done-20819/ | ||||
| UebiMiau Webmail © 2003 - Skin by Beauvoir.net - Hey Info on Mazdaspeedforumgs.org | This thread | Refback | 02-11-2009 11:09 AM | |
| Chrysler begins Employee Pricing Plus Plus to move cars, cars | Haltech | Automotive News | 0 | 01-23-2009 07:50 AM |
| Best AFR for our cars? | gsrtype1 | MazdaSpeed 3/6 - ECU Computer Tuning | 23 | 11-27-2008 12:36 PM |
| best cai for our cars? | blackmsp3 487 | MazdaSpeed 3 - Engine, Transmission & Driveline | 6 | 10-18-2008 01:21 PM |
| Tricked Out Cars | Haltech | Automotive News | 0 | 06-27-2008 06:20 PM |
