 Old 02-15-2015, 01:45 PM   #1
leka's Avatar
Posts: 144   (View Stats)
leka is a splendid one to beholdleka is a splendid one to beholdleka is a splendid one to beholdleka is a splendid one to beholdleka is a splendid one to beholdleka is a splendid one to beholdleka is a splendid one to beholdleka is a splendid one to behold
Default catless question
Hey guys!
I'm looking for some answers here.
Right now I have Cp-e downpipe and running catless. I've never driving the car with the catless downpipe in the summer so I don't know much about this.
Is it normal to have a lot of smoke while in wot? I'm talking about the end of the exhaust, Because I see the smoke from the mirrors, and the smell is horrible
I'ts about 32F here in Sweden so..
Mazdaspeed 6 2006
Sp63 Longblock with Mahle and manly, ported head, keyed crank and cams, stiffer springs, GTX2867R IWG, Freaks intake 4 inch,Autotech Internals, Stratified Ebc + GA, CP-E injector seals, CS Custom pipes FMIC, Snow performance stage2 100% meth, Cp-E decatted downpipe, Custom Catback with VareX mufflers, EGR Delete, SURE TMM+PMM+RMM, South Bend Clutch Stage3 Daily, CS rear diff mount, TurbineTech Front diff mount, CS rear swaybar, Racingbeat rear Endlinks, Matt Damond PS cooler, JBR OCC Stage 2, Bosch 3 bar MAP w/ PNP Harness, BC coilovers, Tenzo R Type M 19" 235/35, Sure Shortshift, Xcarlink, Speed performance Aux fan control, Synchronic DV BOV, DBA front rotor, Ebc yellow stuff(FR), EBC greenstuff (R), Stoptech brakelines and Finally, Tuned By Lex @ Stratified
Current INFO : tuning is paused due the winter.
Waiting to be installed: Cp-e exhaust manifold stock flange with MVR 44 external wastegate and dump tube.
leka is offline   Reply With Quote
 Old 02-15-2015, 02:46 PM   #2
Agent_Orange's Avatar
Posts: 3,575   (View Stats)
Groans: 665
What color is the smoke?
 Old 02-15-2015, 02:54 PM   #3
leka's Avatar
White. I had blue smoke the other day due to the catch can was full of sludge and I think the hole system was cloged , and now it's white. After the cleaning
Mazdaspeed 6 2006
 Old 02-15-2015, 05:20 PM   #4
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
No. Black smoke is normal. Not white.
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 02-15-2015, 06:36 PM   #5
sheston's Avatar
Posts: 1,847   (View Stats)
Have you checked your coolant levels? White smoke generally means water....
 Old 02-15-2015, 06:46 PM   #6
leka's Avatar
I'll check that tomorrow then, it could also be the meth that is mixed with water?
Mazdaspeed 6 2006
 Old 02-26-2015, 10:03 AM   #7
MSMS3's Avatar
Posts: 2,826   (View Stats)
Getting on it hard with catless exhaust should produce black smoke, like a diesel. Your AFR should be going rich under heavy load. Can you post logs made during WOT conditions?
Is your engine oil the proper color or milky? Is your coolant at normal level or does it have any oil in it? White smoke at startup in cold weather is just normal condensation. If on a warm engine it suggests a blown head gasket or a crack in a water jacket in the cylinder head or block. Has it ever been run hot or low on coolant?
 Old 02-26-2015, 10:30 AM   #8
leka's Avatar
Milky is my OCC, the engine oil is very normal, no strange smell. Pure engine oil.
I will post a log this coming days, will need to send a log either way to my tuner
I also changed my pcv Valve, seemed to helped a little.
My OCC setup is pcv to catch can, intake side plugged.
Valve cover to catch can. And catch can to TIP for vacuum
Mazdaspeed 6 2006
Catless DP question deekspeed 2010 MS3 - Engine, Transmission & Driveline 30 06-04-2013 08:43 PM
FMIC and Catless Exhaust Question johnspeed3 Gen2 MS3 General Discussion 12 05-03-2013 06:53 AM
Quick question abt CNT Catless DP xtasy MazdaSpeed 3 - Engine, Transmission & Driveline 11 01-22-2012 04:02 PM
Page generated in 0.28769 seconds with 24 queries
