 Old 04-02-2011, 02:59 PM   #1
02stang951's Avatar
Posts: 250   (View Stats)
02stang951 has a brilliant future02stang951 has a brilliant future02stang951 has a brilliant future02stang951 has a brilliant future02stang951 has a brilliant future02stang951 has a brilliant future02stang951 has a brilliant future02stang951 has a brilliant future02stang951 has a brilliant future02stang951 has a brilliant future02stang951 has a brilliant future
Default cobb intake/broken mount?
so today i saw that the black mount that holds the intake in place broke off so the intake is really just held in by the inlet tube has anyone ever had this problem with this intake and is there anything i can do to fix it? l looked on here but couldn't find anything about it
08.5 true red gt, 35/20% tint, resonators deleted, Tenzo R type M's,Cobb SRI, Hypertech tuned, MSD Dashhawk, SU test pipe, AWR RMM, BC coilovers, Turbosmart duel port bov
02stang951 is offline   Reply With Quote
 Old 04-02-2011, 07:37 PM   #2
patrick failman
karl-hungus's Avatar
Posts: 4,635   (View Stats)
Groans: 74
that old chesnut. need both cobb sri and tip to run the sri mount. our engine moves a bit on stock engine mounts.
 Old 04-02-2011, 07:45 PM   #3
oh10speed3's Avatar
Posts: 1,119   (View Stats)
oh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the world
Groaned at 74 Times in 30 Posts
I asked this question in the gen2 intake sticky. I was curious if I could install it without the mount because I've heard others say it could break due to engine movement. Maybe you can buy just that piece from cobb
oh10speed3 is offline   Reply With Quote
 Old 04-02-2011, 08:29 PM   #4
02stang951's Avatar
thanks for the responses
 Old 04-03-2011, 05:32 PM   #5
abiezerf's Avatar
Posts: 725   (View Stats)
abiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the world
Groans: 46
I am running mine with a custom tip and it is loose. I don't notice and problems. Is there any long term effect or performance impact?
Sent from my HTC EVO 4G.
Current Build:
Liquid Silver Metallic Pu - JBR Shifter Bushings, Cobb AP, JBR Chome Molly
JBR SSP, ProSport Premium Boost Gauge, 25% e85 Tune
PTP HPFP Internals, CorkSport Intake/TIP, Cobb Sport Springs
Sold:
2008.5 Black Mica GenWon - Fully Bolted
abiezerf is offline   Reply With Quote
 Old 04-03-2011, 05:49 PM   #6
patrick failman
Groans: 74
^^^ i wouldn't install the cobb sri mount with a stock tip (connected to engine) and stock engine mounts. that being said, your safe as kittens since you upgraded both.
 Old 04-03-2011, 05:54 PM   #7
Meder's Avatar
Posts: 1,065   (View Stats)
Meder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the world
This has been going on since day one. I would personally sell that pos cobb sri and get something better. There is no reason why you should have to run without the mount or buy the tip which is most likely bullshit also.
Really, cobb refuses to do anything about this and several other hard part issues they've had.
Ive ran a cobb sri without the mount for I dont even know how many miles, and between cracked housings and bent air fins ive had several replacment sris from cobb. The mount will always break but did not cause any other issues.
Meder is offline   Reply With Quote
 Old 04-03-2011, 06:01 PM   #8
8.5MS3's Avatar
Posts: 4,636   (View Stats)
Groans: 326
they did adjust the sri after its initial release...
rubber spacers now separate the actual intake from the bracket, allowing some movement
i just took the sri bolts off and used some zipties to allow some movement but keep it relatively stationary
Drag strip = broken motor mount LuczOr MazdaSpeed 3 - Engine, Transmission & Driveline 29 07-17-2011 07:26 PM
Signs of Broken Tranny Mount? Alpha MazdaSpeed 6 - Engine, Transmission & Driveline 14 03-18-2010 02:27 PM
Broken Motor Mount? Jujiro_Prodigy_31 MazdaSpeed 3 - Engine, Transmission & Driveline 17 03-08-2010 09:14 PM
Broken passenger mount...it took a dump literally..... Betelgeuse MazdaSpeed 3 - Engine, Transmission & Driveline 31 10-24-2008 06:33 PM
Page generated in 0.29485 seconds with 25 queries
