 Old 02-16-2010, 01:07 PM   #1
banditscout's Avatar
Posts: 783   (View Stats)
banditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the world
Groans: 50
Default Cobb Tuning Plano
So today I was off work and decided to take a drive over to Cobb Tuning Plano, I left with these two items. IMG00050-20100216-1351-1.jpg
EDIT: I'll let everyone know how this Cobb BPV works out. Neil at Cobb was pretty adamant about the fact that they're not going to be making a whole lot of them, so I'm going to post a vid, and let everyone know how it is. If anyone's interested, probably wouldn't hurt to order one!
banditscout is offline   Reply With Quote
 Old 02-16-2010, 01:53 PM   #2
Groans: 50
Ok, so here it is installed. Very nice piece, fits perfectly and is very light weight. I did a quick drive with it, and thus far it seems very responsive. I'm going to remove the back plate and give 50/50 a try here shortly.
I'm a little upset that I can't use ATR or download maps for the APIMG00051-20100216-1429-1.jpg because I have a Mac...ghey.
Update.
Just drove around for a while in 50/50. No issues, no problems. Thus far seems to be a very nice valve, sounds great as well.
The Following User Says Thank You to banditscout For This Useful Post:
bioevolve (02-16-2010)
 Old 02-16-2010, 02:32 PM   #3
Frosty's Avatar
Posts: 82   (View Stats)
Frosty is the leader of the worldFrosty is the leader of the worldFrosty is the leader of the worldFrosty is the leader of the worldFrosty is the leader of the worldFrosty is the leader of the worldFrosty is the leader of the worldFrosty is the leader of the worldFrosty is the leader of the worldFrosty is the leader of the worldFrosty is the leader of the world
Looks good. Looking forward to the video.
MSCAI, M3M Inlet, CP-E DP, Turbosmart BOV, Denso 22's, SU motor mount, Cosworth BSD, PTP baffle kit, PG Manifold v1, & OCC. HID's for low beams and fogs. AEM Wideband & Apexi TT.
Hotchkis rear sway bar, Racing Beat front sway bar, stock springs, AWR front end links, Koni FSD's, FCM bump stops, & stock springs.
Frosty is offline   Reply With Quote
 Old 02-16-2010, 03:53 PM   #4
senor blanco ms3's Avatar
Posts: 1,353   (View Stats)
senor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the world
you should come out to the meets again. talk to sumo, he works at a pc leasing company and has a lot of good laptops for sale for like 250. small enough to use in the car with ATR.
2008.5 Crystal White Pearl MS3
A lot of mods
Check out my big turbo build!
senor blanco ms3 is offline   Reply With Quote
The Following User Says Thank You to senor blanco ms3 For This Useful Post:
banditscout (02-16-2010)
 Old 02-16-2010, 04:45 PM   #5
bombdotcom's Avatar
Posts: 816   (View Stats)
bombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the world
Groaned at 40 Times in 20 Posts
isnt there a program on here for macs? im pretty sure someone did soemthing to make it compatible. oi have a mac and am getin an AP in like a month so that would suck
(RIP) 08' MS3---MODS:COBB AP- COBB SRI AND TIP- COBB RSB- COBB KNOB- CP-E TMIC- LIMITED EDITION HKS BOV- CORKSPORT DP AND TP- TRZ REARMOUNT- MD OCC- PTP IM COOLER KIT- COSWORTH BSD- EIBACH PROKIT- TWM SHIFTER BUSHINGS- JBR SHORT SHIFT KIT-
13' CWP MS3
bombdotcom is offline   Reply With Quote
 Old 02-16-2010, 05:02 PM   #6
0187
esr010's Avatar
Posts: 486   (View Stats)
esr010 is the leader of the worldesr010 is the leader of the worldesr010 is the leader of the worldesr010 is the leader of the worldesr010 is the leader of the worldesr010 is the leader of the worldesr010 is the leader of the worldesr010 is the leader of the worldesr010 is the leader of the worldesr010 is the leader of the worldesr010 is the leader of the world
Groaned at 9 Times in 5 Posts
Default Re: Cobb Tuning Plano
I had a mac version of the ap manager and updated. It constantly crashed and occasionally worked great. I'm not aware of atr on a mac. I patirioned 10gb of my harddrive and installed vista. Works great. Only time I use it is to tune etc. Too bad macs can't boot from an external hard drive. I'd have bought a small one and ran all windows stuff that way.
To op: did the bpv feel the same in 50/50 as it was in recirc or a little rougher?
esr010 is offline   Reply With Quote
The Following User Says Thank You to esr010 For This Useful Post:
 Old 02-16-2010, 05:06 PM   #7
Run boot camp on your mac and use the windows version. I think you will be much happier.
banditscout (02-16-2010), SpeedSixxx (02-16-2010)
 Old 02-16-2010, 05:10 PM   #8
Groans: 50
I'll look into it. I've gotta buy windows and partition the HD. Thanks gents.
 Old 02-16-2010, 05:53 PM   #9
bombdotcom's Avatar
whats bootcamp? where can i get it?
13' CWP MS3
 Old 02-16-2010, 05:58 PM   #10
0187
esr010's Avatar
Originally Posted by Haltech
Run boot camp on your mac and use the windowsillversion. I think you will be much happier.
Completely agree. I had to partition mine quick. Bootcamp is a good call. I was going to do this as well
 Old 02-16-2010, 08:39 PM   #11
bombdotcom's Avatar
whats this boot camp deal!? lol
13' CWP MS3
 Old 02-16-2010, 08:49 PM   #12
Cheveyboy's Avatar
Posts: 328   (View Stats)
Cheveyboy has a reputation beyond reputeCheveyboy has a reputation beyond reputeCheveyboy has a reputation beyond reputeCheveyboy has a reputation beyond reputeCheveyboy has a reputation beyond reputeCheveyboy has a reputation beyond reputeCheveyboy has a reputation beyond reputeCheveyboy has a reputation beyond reputeCheveyboy has a reputation beyond reputeCheveyboy has a reputation beyond reputeCheveyboy has a reputation beyond repute
Bootcamp allows you to dual boot your laptop. Meaning you can have both OS X and a Windows variant installed. At boot up you can chose to run OS X or Windows. Of course as long as your laptop is running a Intel Processor.
Cheveyboy is offline   Reply With Quote
 Old 02-16-2010, 08:49 PM   #13
214mazdaspeeder's Avatar
Posts: 39   (View Stats)
214mazdaspeeder is a splendid one to behold214mazdaspeeder is a splendid one to behold214mazdaspeeder is a splendid one to behold214mazdaspeeder is a splendid one to behold214mazdaspeeder is a splendid one to behold214mazdaspeeder is a splendid one to behold
Where are the meets I'm in dallas and have always wanted to go to mazda meets. I went to one on macarthur and 635 nobody knew about my MS6 its was mainly rx7's.
DAMN COWBOYS!!!!!
214mazdaspeeder is offline   Reply With Quote
 Old 02-16-2010, 11:58 PM   #14
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
Vids of the bov or ban
That thing costs a ass load of money and I wanna know if its worth it.
2006 Mazdaspeed 6
 Old 02-17-2010, 05:59 AM   #15
Groans: 50
I'll post the vids when I get home from work today. This thing IS pricey, but it's definitely legit. I've been running the 50/50, and so far no issues, not running rich between shifts either
06Speed6 (02-17-2010)
 Old 02-18-2010, 10:56 PM   #16
Groans: 50
Ok, so got some decent vids shot with the valve in 50/50. So far, still love it. The best part about this thing is how friggin QUICKLY it vents! It's like "whooooa" fast. Posting the vids soon as I get done at work tomorrow. The video's a lot of me gibba-gabbering, but it gets to the point. BTW, I'm back to running full recirc due to some errant muffled pops between shifts... VTA just wasn't meant to be for the MS3, says Cobb....at this point I'm beginning to agree.
 Old 02-18-2010, 11:09 PM   #17
flyrevs2's Avatar
Posts: 1,235   (View Stats)
stop gibba-gabbering and post vid
2013 Mazdaspeed3 Gen2
flyrevs2 is offline   Reply With Quote
The Following User Says Thank You to flyrevs2 For This Useful Post:
psychophyr (02-19-2010)
 Old 02-20-2010, 11:17 AM   #18
Groans: 50
Shitty vid posted! Bear with it...
EDIT: Fast forward to around 1:20 if you don't want to hear me bullshitting whilst ferrying myself out of my apartment complex.
ms3077 (02-20-2010)
 Old 02-20-2010, 04:04 PM   #19
Hypnotized's Avatar
Posts: 184   (View Stats)
Hypnotized is a splendid one to beholdHypnotized is a splendid one to beholdHypnotized is a splendid one to beholdHypnotized is a splendid one to beholdHypnotized is a splendid one to beholdHypnotized is a splendid one to behold
Can you post a sound clip or vid wtih the windows down?
Hypnotized is offline   Reply With Quote
 Old 02-20-2010, 10:45 PM   #20
Groans: 50
Yeah, going to try to get some more footage tomorrow. I need a camera mount or something. Holding camera, shifting and steering is difficult.
Cobb Tuning XLE BOV now available smakdown61 MazdaSpeed 3 - Engine, Transmission & Driveline 62 03-10-2010 05:35 AM
Cobb Tuning will be completing custom tunes at their Plano, TX facility. Christian. MazdaSpeed 3/6 - ECU Computer Tuning 94 01-27-2009 06:47 PM
Page generated in 0.39661 seconds with 31 queries
