 Old 03-06-2008, 08:30 PM   #41
Rican219's Avatar
Posts: 120   (View Stats)
Rican219 is the leader of the worldRican219 is the leader of the worldRican219 is the leader of the worldRican219 is the leader of the worldRican219 is the leader of the worldRican219 is the leader of the worldRican219 is the leader of the worldRican219 is the leader of the worldRican219 is the leader of the worldRican219 is the leader of the worldRican219 is the leader of the world
Originally Posted by sleeper3 View Post
plus more turbulent...
I really expected more out of corksport. now I'm doubting their other products...
I haven't had any issues with mine no CEL's. Have you called them with your issues? They are a great company they will work with you if you ask.
[SIGPIC][/SIGPIC]www.myspace.com/rican219
MODS:
TWM Short Shifter Stage 2, CPE downpipe Highflow Cat, Corksport 3 inch Catback, SU motor Mount, HKS BOV VTA, Spin on Oil filter conversion, Greddy Turbo timer, H&R Springs, Sport Max wheels, Corksport Strut Tower Brace, Corksport FMIC,Turbine Tech Front Engine Mount, Turbine Tech Rear Diff Bracket and Bushings, PROcede EMS, 2871r, Dash Hawk
Rican219 is offline   Reply With Quote
 Old 03-09-2008, 06:23 PM   #42
Laloosh's Avatar
Posts: 5,166   (View Stats)
Laloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the world
Groaned at 196 Times in 127 Posts
Ive called corksport and got nothing but welll umm yea umm other cars arnt throwing the code. I told them that i am not the only one with this problem and i even suggest that the reason this code is being thrown and the car is running like shit is becuase the maf housing is too big. The only asnwer i got is that they have a speed 3 with the same problem that his been to their shop multiple times. They are aware of it but frankly arnt doing much about it. All they gotta do is create a smaller maf housing pipe. Instead of 2.8 in diamter make it 2.6 PROBLEM SOLVED CORKSPORT!
On to my private ghetto testing. I siliconed a coupler into the maf housing to reduce the size to rougly 2.5x. Car runs WONDERFUL, cel went away, dead spots went away every single problem went away.
However there is a 'downfall' to this. My car use to hold 17psi and not the boost is holding like stock...hold 15.x drops downt oe 14.x. I dont mind this one bit because Im on the stock boost control system. Ill just wait till for cobb and call it a day!
Laloosh is offline   Reply With Quote
 Old 03-09-2008, 06:36 PM   #43
Can you have a new MAF housing made from pipe instead of a coupler now that you know it works? Probably get a batch made and sell them off.
 Old 03-09-2008, 06:43 PM   #44
Laloosh's Avatar
I dont know where to go to get that kind of stuff done.
 Old 03-09-2008, 06:55 PM   #45
Go right to a machine shop, they will be able to pull that off for you in a heartbeat.
 Old 03-09-2008, 07:01 PM   #46
Laloosh's Avatar
i gotta talk to some poeple around me...ill see what i can do about this. I mean it dont see it costing more than 100 bucks. Cut the maf housing out, weld a new smaller one in.
 Old 03-09-2008, 07:07 PM   #47
Yea, its not a big job at all to cut it and weld it.
What i was implying is you could also have these manf'd yourself and sell them off as well. Im sure people would buy them to do their own IC's and SRIs.
 Old 03-09-2008, 07:09 PM   #48
Laloosh's Avatar
This would be a corksport specefic piece. The way the cs kit is set up is that the maf housing attaches tot he airbox which is where the tmic use to sit. It wouldnt work with anythign else besides the CS kit
 Old 03-11-2008, 07:52 AM   #49
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
Did you email CS and ask/let them know about their MAF housing being too big?
 Old 03-11-2008, 08:31 AM   #50
ptperformance's Avatar
Posts: 4,123   (View Stats)
Laloosh hit me up, I will post some pictures of our kit when I get it on the car.
 Old 03-12-2008, 08:49 AM   #51
sleeper3's Avatar
Posts: 675   (View Stats)
sleeper3 has a brilliant futuresleeper3 has a brilliant futuresleeper3 has a brilliant futuresleeper3 has a brilliant futuresleeper3 has a brilliant futuresleeper3 has a brilliant futuresleeper3 has a brilliant futuresleeper3 has a brilliant futuresleeper3 has a brilliant futuresleeper3 has a brilliant futuresleeper3 has a brilliant future
I'd be interested in what you come up with too!
Ribs. I had ribs for lunch. That's why I'm doing this.
sleeper3 - 2.234, 8.742 @ 84.18, 13.365 @ 106.75 (I/IN/IC/MM)
sleeper3 is offline   Reply With Quote
 Old 03-12-2008, 10:08 AM   #52
mrlilguy157's Avatar
Posts: 606   (View Stats)
mrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the world
looks like i'm staying with my top mount which will be here next week.
Black Mica '07 Mazdaspeed3
Mods:CP-E FMIC - ProtegeGarage Tubular Exhaust Manifold - TurboXS Hybrid BOV, Downpipe, and Custom Catted Racepipe - mrlilguyCDFP - ATP 3" Turbo Inlet - ATP Boost Cut Killer Module - CP-E Rear MM - WelderWerkz Short Shifter - AEM UEGO Wideband - ProSport Blue Boost/EGT/Oil Pressure Gauges - GReddy Full Auto Turbo Timer - PimpWheels Black/Red Edition - Falken Azenis RT-615 - Yakima Roof Rack w/ Fairing
Reppin' ProtegeGarage for life!
mrlilguy157 is offline   Reply With Quote
The Following User Says Thank You to mrlilguy157 For This Useful Post:
occschemguy (03-12-2008)
 Old 03-12-2008, 10:23 AM   #53
Laloosh's Avatar
After fixing the maf housing in a ghetto way im really happy with this kit. Boost temps are WAY down compared to the ets top mount. Ets top mount going from 1-5th i would see 200 degree post intercooler temps. Right now im seeing low 160s once i hit 5th. Then again the top mount was tested at 18 psi and right now im only seeing 15.
Another cool thing about this set up is the air intake temps, im only about 4-5 degree above amb once i get rolling
The Following User Says Thank You to Laloosh For This Useful Post:
occschemguy (03-13-2008)
 Old 03-12-2008, 11:53 PM   #54
occschemguy's Avatar
Posts: 1,149   (View Stats)
occschemguy is the leader of the worldoccschemguy is the leader of the worldoccschemguy is the leader of the worldoccschemguy is the leader of the worldoccschemguy is the leader of the worldoccschemguy is the leader of the worldoccschemguy is the leader of the worldoccschemguy is the leader of the worldoccschemguy is the leader of the worldoccschemguy is the leader of the worldoccschemguy is the leader of the world
im with you on this i think!
You can see more on mymyspace
occschemguy is offline   Reply With Quote
 Old 03-13-2008, 12:04 AM   #55
driver311's Avatar
Posts: 1,769   (View Stats)
I say fmic! What do I know though?
Mazdaspeed
 Old 03-13-2008, 12:37 AM   #56
did u see any psi loss when u mouned it?
 Old 03-13-2008, 05:40 AM   #57
sleeper3's Avatar
I'd say about 3 lbs?
I mean 18-15 is three...
 Old 03-13-2008, 06:29 PM   #58
ZoomMS3's Avatar
Posts: 94   (View Stats)
ZoomMS3 has a spectacular aura aboutZoomMS3 has a spectacular aura about
hey laloosh, can you send me some info on exactly what you did with the MAF housing? I just picked one up today.. killer deal and am going to get the whole MAF housing thing over and done with before the car is even back to me.
thanks
On motor #3
Turbo #2
Now have a SSM 08 STi!!
ZoomMS3 is offline   Reply With Quote
 Old 03-13-2008, 07:31 PM   #59
Death-From-A-Mile's Avatar
Posts: 1,371   (View Stats)
Death-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the world
Groans: 87
Killer deal for sure!!!!
Death-From-A-Mile is offline   Reply With Quote
 Old 03-14-2008, 04:12 AM   #60
Laloosh's Avatar
The kit on your car first, see if you have any problems. If your car runs like shit and throws a cel post it in here and ill tell you what i did.
 Old 03-15-2008, 10:29 AM   #61
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
well i just finished installing my kit for my ms6, wasn't the greatest fitment but i got it all together. when i started it up the first couple times it died while trying to idle. after about the third time the rpms bounced around a bit then it levels out. did you have any problems like this? i am running recirc so i'm not sure whats wrong. it seems like anytime i start it up it will bounce around and then level. i have no CEL's.
i did have to use a 2.5" coupler in between the pipe off the turbo and the one that goes down in the fender cause corksport doesn't mention in the instructions that you need a new coupler for the turbo inlet to the turbo. so i called them up and they told me to just use one of the 2.25" from a tube that was easily accesible cause they sent me a new one for that spot. so i'm not sure if the 2.5" coupler there is causing sort of a bottle neck giving problems to idle. but i needed a coupler to put there for now.
so once it idled i took her out for a spin. got into some boost but once i hit about 12psi i got this weird squealing noise, i might also contribute this to that coupler or i might have a look at the pipe going into the throttle body and make sure that clamp is on right because the way the pipe goes from 2.25" to 2.75" its tough to get the clamp on right.
 Old 03-15-2008, 10:33 AM   #62
Laloosh's Avatar
my car died the first couple of times trying to start it as well. Let me know if you throw a cel
 Old 03-15-2008, 10:52 AM   #63
bova's Avatar
Groans: 45
did it idle rough once it did start?
 Old 03-15-2008, 11:01 AM   #64
Laloosh's Avatar
absolutly, it sounded liek it was misfiring.
 Old 03-15-2008, 12:40 PM   #65
bova's Avatar
Groans: 45
well i got 2 CEL's P2177 and P2187
 Old 03-15-2008, 12:42 PM   #66
Laloosh's Avatar
good ole 3 inch maf housing. I still dont know how corksport advertises this kit.
 Old 03-15-2008, 12:44 PM   #67
bova's Avatar
Groans: 45
here i did a log of my idle too. i think i have a leak somewhere. why both codes?
 Old 03-15-2008, 12:46 PM   #68
Laloosh's Avatar
trust me you dont have a leak anywhere.
 Old 03-15-2008, 12:48 PM   #69
bova's Avatar
Groans: 45
do you think it could be the bigger coupler size i have in temporarily as well? wonder why the other guys with this kit aren't experiencing issues.
 Old 03-15-2008, 12:50 PM   #70
Laloosh's Avatar
it has nothing to do with a bigger coupler. Half hte cars that have this kit throw cels and run like complete ass
 Old 03-15-2008, 12:52 PM   #71
bova's Avatar
Groans: 45
i also get a studder while driving i can feel.
 Old 03-15-2008, 12:52 PM   #72
bova's Avatar
Groans: 45
did you see how my log all the values are bouncing around.
 Old 03-15-2008, 12:54 PM   #73
Laloosh's Avatar
let me guess the stutter is right before your are about to build boost aka btwn -5 and 0
 Old 03-15-2008, 01:42 PM   #74
bova's Avatar
Groans: 45
yup. i went and did notice i had a few loose clamps so i tightened them all up. had to replace one of the 3" ones cause it just didn't fit right. and then i also noticed the hose for the PCV vent was kinked so that might be the P2187 code.
 Old 03-15-2008, 01:48 PM   #75
Laloosh's Avatar
your wasting your time, its the maf housing
 Old 03-15-2008, 02:04 PM   #76
bova's Avatar
Groans: 45
ok, i'll call them up monday and see what they say and i'll make sure i tell them others have that problem too.
 Old 03-15-2008, 02:17 PM   #77
Laloosh's Avatar
been there tried that...they have no solution but give it a shot, the more people bitch the better off well be.
 Old 03-15-2008, 02:53 PM   #78
bova's Avatar
Groans: 45
any reasoning to the wierd squeal noise i got at around 12psi of boost?
 Old 03-15-2008, 02:59 PM   #79
Laloosh's Avatar
no clue...maybe a pipe is rubbing
 Old 03-15-2008, 03:01 PM   #80
aaronc7's Avatar
Groans: 370
laloosh: what did corksport say about the incorrect MAF housing when you called? It sucks they can't get something as simple as that right.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/corksport-front-mount-intercooler-74/
Mazda Speed Forums: Mazdaspeed High Performance Forum with Gallery, Specs, discussion & more This thread Refback 03-25-2008 04:47 PM
Corksport Ram Air Box bova MazdaSpeed 3/6 - Turbo Induction 3 04-08-2010 06:42 PM
Corksport FMIC Kit bova MazdaSpeed 3/6 - Turbo Induction 22 06-12-2008 08:44 PM
Going all corksport exhaust it looks like... Haltech MazdaSpeed 3 - Engine, Transmission & Driveline 20 03-26-2008 11:22 PM
CorkSport DP + Vibrant SLS MS3 MazdaSpeed 3 - Engine, Transmission & Driveline 9 03-24-2008 10:57 AM
Page generated in 0.53504 seconds with 32 queries
