 Old 03-15-2008, 03:05 PM   #81
Laloosh's Avatar
Posts: 5,166   (View Stats)
Laloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the world
Groaned at 196 Times in 127 Posts
well umm yeaa umm others dont have problems but we have a speed 3 coming in with the same problem....
Laloosh is offline   Reply With Quote
 Old 03-15-2008, 03:12 PM   #82
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
ghey. I've only heard good things about their exhaust stuff (and already ordered it all). hopefully they just jacked this one thing up (fmic)
 Old 03-15-2008, 05:45 PM   #83
dadasracecar's Avatar
Posts: 741   (View Stats)
dadasracecar is the leader of the worlddadasracecar is the leader of the worlddadasracecar is the leader of the worlddadasracecar is the leader of the worlddadasracecar is the leader of the worlddadasracecar is the leader of the worlddadasracecar is the leader of the worlddadasracecar is the leader of the worlddadasracecar is the leader of the worlddadasracecar is the leader of the worlddadasracecar is the leader of the world
Groaned at 70 Times in 44 Posts
Originally Posted by Laloosh View Post
After fixing the maf housing in a ghetto way im really happy with this kit. Boost temps are WAY down compared to the ets top mount. Ets top mount going from 1-5th i would see 200 degree post intercooler temps. Right now im seeing low 160s once i hit 5th. Then again the top mount was tested at 18 psi and right now im only seeing 15.
Another cool thing about this set up is the air intake temps, im only about 4-5 degree above amb once i get rolling
I did a datalog of my ambient air temp and boost air temp to see my numbers 1st through 4th at 17 psi.
I'm thinking the CAI makes the difference with my setup vs. the CS pan filter that sits on the engine. Boost temp never gets to 100.
dadasracecar is offline   Reply With Quote
 Old 03-15-2008, 06:10 PM   #84
I think its time i emailed CS themselves and have them come over and explain why they did this.
 Old 03-15-2008, 06:23 PM   #85
Laloosh's Avatar
The dh obviously doesnt record boost temps correctly. My cars been off for 8 hours, if i go and turn the key my boost temps will be at 140.
My 205 vs high 150s low 160s was done ont he same car so obviously i lost 40 degree by going to a fmic.
As for youre cai making a difference, its not. Like i said, the air going into the turbo is roughly 4-7 degrees higher than ambiant
 Old 03-15-2008, 06:55 PM   #86
well, go and download the lates version of the DH software 2.4preprod2 or something like that, do the same run and show your temps. If it's not the cai the why does your IC only cool to 160? If you don't trust the numbers, don't report them...
 Old 03-15-2008, 07:05 PM   #87
Laloosh's Avatar
im running production 1.
I dont trust the number for shit becuase like i said, with my car parked over night, the second i turn the key the boost temps are over 140. This is simply a comparrison btwn what i saw iwth the ets and what i see now. 1-5th the boost temps were at 205 in 5th, now they are at low 160s.
uploading movie for you as we speak....
 Old 03-15-2008, 07:22 PM   #88
Laloosh's Avatar
 Old 03-15-2008, 07:46 PM   #89
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
 Old 03-15-2008, 08:14 PM   #90
Looks like you've got a bad sensor or something. The DH just reads what the ECU says. If it's 47 deg F and your MAP IAT is saying the temp is 143 when the car is cold, that tells me you've got something wrong.
 Old 03-15-2008, 08:17 PM   #91
Laloosh's Avatar
im not the only ms3 who sees this, unless i didnt download the version correctly cause the commanded a/f ratio and actual are still the same in the mazda pid....i read it was suppose to be corrected.
 Old 03-16-2008, 02:56 PM   #92
bova's Avatar
Groans: 45
got a random misfire code P0300. i cleared it to see if it would come back and it didn't so i'm not sure. i am just running her easy for now til i get all the proper couplers and what not.
 Old 03-17-2008, 07:42 PM   #93
bova's Avatar
Groans: 45
bit of an update. took everything apart and checked all the connections. i had a stripped clamp which was where i had a leak so i had to cut that clamp off and replace it. then i had to realign a bunch of the pipes and what not. started it up and it seems to be ok. idle still bounces a bit but i might need to re learn again since i disconnected the battery. i can now get on boost without hearing the squeal thank god. although i don't want to push it to much because i have some worm clamps that will need replaced once my new t-bolt clamps come. i assume as soon as my car learns about its new found goods it will drive normal, because i do get somewhat of a studder and the idle does bounce every once and a while, anywhere from 700-1000 now that i sealed up all the leaks, before it was 600-700.
 Old 03-17-2008, 07:48 PM   #94
Noted
 Old 03-17-2008, 07:55 PM   #95
bova's Avatar
Groans: 45
they were, but i bought it used so i was missing some and then some were stripped and one broke on me.
 Old 03-18-2008, 02:00 AM   #96
Kelly from CS has responded to my email, so we should have some people from their R&D dept replying to the thread.
 Old 03-18-2008, 06:24 AM   #97
bova's Avatar
Groans: 45
sounds awesome Haltech. hope they can offer assistance.
 Old 03-18-2008, 08:01 AM   #98
Laloosh's Avatar
Some1 responded to my email yesterday during the afternoon, asked for my phone number so i guess they want to talk some more. Always a good thing
 Old 03-18-2008, 08:23 AM   #99
bova's Avatar
Groans: 45
hey laloosh, when you started yours up for the first time and were running lean did you exhaust smell different? mine smells like its pretty pungent.
 Old 03-18-2008, 05:41 PM   #100
Hello All,
We have made a revision on the FMIC kit which has shown to take care of the lean at idle/lean off idle code a few Mazdaspeed 3s have seen that have our FMIC installed.
The CEL has only come up on a few Mazdaspeed 3s that have our FMIC kit and no Mazdaspeed 6 models.
We will be getting the revised part to the few Mazdaspeed 3s that have had the CEL come up out this week.
If anyone has any questions or concerns feel free to give us a call at 360 260 2675 or shoot me an email.
Thanks
Derrick
 Old 03-18-2008, 05:41 PM   #101
Laloosh's Avatar
BIG UPDATED;
Kelly from corksport just called me. They have a solution for the problem and are shipping me out a new maf housing tomorrow. This will be a prototype fix, the actual fix will be ready in 3 months. I am going to test it out and data log fuel trims and a/f ratios to make sure everythign is where it should be. I must say I am every surprised with the customer service and i hope their new piece fixes the past mistake with the incoreect size maf housing. I will report back with more infor once the piece gets here.
The Following User Says Thank You to Laloosh For This Useful Post:
NYpest (03-18-2008)
 Old 03-18-2008, 05:48 PM   #102
bova's Avatar
Groans: 45
i wonder if that would help my speed6. i just spoke with derrick and he was going to talk to a tech, but since i no other speed6's have the problem not sure what kind of luck i'll have. i did a simple log today on the highway 4th-6th just cruising not hard on throttle. its only been about 10miles or so since i reset the battery so that might be why its still all over the place.
my only other thought is that 2.5" coupler which i have in temporarily but i might be dwelling on it.
The Following User Says Thank You to bova For This Useful Post:
Koenig (02-06-2014)
 Old 03-18-2008, 05:53 PM   #103
Laloosh's Avatar
it will def help!
 Old 03-18-2008, 05:58 PM   #104
bova's Avatar
Groans: 45
maybe they could send me one to try out.
 Old 03-18-2008, 06:15 PM   #105
Laloosh's Avatar
call them and ask...
 Old 03-18-2008, 06:27 PM   #106
aaronc7's Avatar
Groans: 370
thats awesome. corksport gave me awesome customer service so far with the exhaust...glad they are taking care of this issue!
 Old 03-18-2008, 07:23 PM   #107
It's nice to see this taken care of finally!
 Old 03-18-2008, 07:37 PM   #108
BIG UPDATED;
Sorry, DOUBLE MOTHER FUCKING STANDARD dude. You talk shit about cp-e all the time. CS sends out an FMIC with an incorrect MAF housing and you're like, "oooh, great customer service?!?!" WTF? I specifically remember you giving a guy shit b/c he was happy with cp-e customer support for a problem with their DP. BIAS anyone? Laloosh has plenty.
2008 BMW 335i 6MT black on black
www.p3performance.net
 Old 03-18-2008, 07:40 PM   #109
Well in his defense, i had contacted CS about this. Infact, that is the way i will run this site... I figure, if were going to bitch about it, might as well get them involved.
If CPE wants to come over, they are more than welcome. The point i want to make is, i WANT these company's involved with the real people, who use their parts.
Ive sent CPE an email awhile back, but i havent received any response from them. Perhaps they are more involved over at the other forums.
 Old 03-18-2008, 07:52 PM   #110
Incorrect MAF housing. Umm, that's kind of important as it's the way the car knows how much fuel to inject last I checked...
 Old 03-18-2008, 08:00 PM   #111
Laloosh's Avatar
corksport didnt flat out lie to my like cpe did. Btw just did a pull with the newest version of the dh. Heatsoaked idling to all hell. Guess what at 16 psi in 5th the highest i saw was 78 degrees......kinda blows yours out of the water by about 20 degrees. Funny if you ask me.
uploading chart as we speak
 Old 03-18-2008, 08:01 PM   #112
bova's Avatar
Groans: 45
well if its incorrect on the speed3 then it is incorrect on the speed6
 Old 03-18-2008, 08:10 PM   #113
Laloosh's Avatar
fixed
 Old 03-18-2008, 08:12 PM   #114
Mellman's Avatar
Posts: 86   (View Stats)
Mellman is a jewel in the roughMellman is a jewel in the roughMellman is a jewel in the rough
I dunno...do you think CPE would really feel welcome about coming here?
Their history with several users that are not only here...but are admins/moderators here.
They've been beat to hell by some of the people here, for doing (in my eyes at least) exactly what ptperformance has done in the "PTP Claims interesting things" thread. Discuss new and exciting things about the MS3 that they've found.
In the past when they've done that...they've just been flamed to hell for it :-\
Mellman is offline   Reply With Quote
 Old 03-18-2008, 08:17 PM   #115
Laloosh's Avatar
this isnt about cpe, this is about mazda board not allowing members to speak out. I had a problem with the cs fmic and bashed it to hell. Would you like to see the email i wrote them? Every1 knew about it ont he boards and guess what 1 week later corksport fixed the issue. If cpe comes on here and gets prooven wrong, they better fix their issue instead of banning people for down talking their prodcuts. Cpe to this day still denies my fuel issues and blames it on a faulty stock fuel sysytem....LOL at that
BTW for the record
http://forum.mazda6club.com/index.ph...pic=94250&st=0
Dadaracecar jumped at the oppertunity to say how much more efficient his cpe ic was then then my cs ic, little did he know i was using old software and mine ended up to be more efficient at cooling. L M A O That backfired
 Old 03-18-2008, 08:20 PM   #116
Well if you are in this business, you need to be prepared for criticism. I dont know of one perfect product. Ive seen company's who were so-so with kicking out products, go from being flamed, to producing much better products and getting praised. CPE could do this if they want. Here, there is no protection hiding under the vendor badge.
I think it would be a good opportunity for them to start clean and come over. Ball's in their court at this time.
The only admin here is me... I havent done much to CPE. If you think what Loosh has done is bad, you havent seen me on my game. I could tear some people up as i have in the Ford community for screwing me around.
You either live for the past, or live for the future. Clean slate here
Davidb (03-18-2008)
 Old 03-18-2008, 08:24 PM   #117
Mellman's Avatar
BTW for the record
When will you ever understand CPE doesn't have the power to BAN people from a forum? They asked you not be allowed to post in their section...the moderators took it upon themselves to ban you
as for your FMIC being efficient...dadasracecar is also the one who said something is probably wrong...
 Old 03-18-2008, 08:24 PM   #118
bova's Avatar
Groans: 45
i am right with you loosh, my cs fmic on my speed6 sees the same temps yours does.
 Old 03-18-2008, 08:54 PM   #119
Laloosh's Avatar
no i treated corksport exactly the same way i treated cpe. I emailed them saying i have a problem. Cpe chose to ignore my problem and i believe they said i had a faulty stock fuel system. Corksport on the other hand emailed me asking me for my phone number and address, Called me the next day and said they want me to try a new maf housing. They didnt deny that i had a problem. Big difference.
And yes i find it odd how the dp owner who is throwing cels has to take it off and resend it to cpe to get a fixed one sent out. You know what corksport did, SENT ME A BRAN NEW ITEM with a return lable to send the old one back. This way i dont have any down time and i dont ahve to the the same job twice. Once again, great customer service, not the cpe way
 Old 03-18-2008, 09:01 PM   #120
BTW for the record
LMAO at the idiocy. YOU reported the data. I took it and compared it and lo and behold, your data was effed... hmmm. sound familiar?? Does to me.
More efficient? huh? not so much.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/corksport-front-mount-intercooler-74/
Mazda Speed Forums: Mazdaspeed High Performance Forum with Gallery, Specs, discussion & more This thread Refback 03-25-2008 04:47 PM
Corksport Ram Air Box bova MazdaSpeed 3/6 - Turbo Induction 3 04-08-2010 06:42 PM
Corksport FMIC Kit bova MazdaSpeed 3/6 - Turbo Induction 22 06-12-2008 08:44 PM
Going all corksport exhaust it looks like... Haltech MazdaSpeed 3 - Engine, Transmission & Driveline 20 03-26-2008 11:22 PM
CorkSport DP + Vibrant SLS MS3 MazdaSpeed 3 - Engine, Transmission & Driveline 9 03-24-2008 10:57 AM
Page generated in 0.58695 seconds with 27 queries
