 Old 03-24-2008, 11:02 AM   #241
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
maybe this has been posted already but...what are the dimensions of the Corksport intercooler?
 Old 03-24-2008, 11:05 AM   #242
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
i think its listed on their site.
speed3: 24 in x 6 in x 3.6 in
speed6: 21 in x 10 in x 3 in
The Following User Says Thank You to bova For This Useful Post:
aaronc7 (03-24-2008)
 Old 03-24-2008, 01:38 PM   #243
bova's Avatar
Groans: 45
hey laloosh, how are your fuel trims today with the new maf housing? you talk to corksport at all?
 Old 03-24-2008, 01:57 PM   #244
Laloosh's Avatar
Posts: 5,166   (View Stats)
Laloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the world
Groaned at 196 Times in 127 Posts
same...14.1
I havnt talked to cs as i want to give the car a week or so of driving around to make sure they don't go any higher or it doesnt throw a cel.
Laloosh is offline   Reply With Quote
 Old 03-25-2008, 04:10 PM   #245
bova's Avatar
Groans: 45
here is the temporary fix i did, i took it apart to redo it. it appears the front side of the coupler didn't get sealed down so it could have been getting pushed up blocking some air flow before. the silicon is a bit sloppy but whatever here you go.
 Old 03-25-2008, 04:17 PM   #246
Laloosh's Avatar
HOLY SHIT...lol thats alot thicker than mine
 Old 03-25-2008, 04:23 PM   #247
NYpest's Avatar
Posts: 1,889   (View Stats)
NYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the world
wow
NYpest is offline   Reply With Quote
 Old 03-25-2008, 04:24 PM   #248
bova's Avatar
Groans: 45
i couldn't get that shit to sand down anymore and i think the silicon makes it look thicker cause i have it up on the coupler itself to smoothe it out.
i measured and with the coupler the housing is about 2.5", what is stock?
 Old 03-25-2008, 04:33 PM   #249
Laloosh's Avatar
 Old 03-25-2008, 04:49 PM   #250
bova's Avatar
Groans: 45
ok got a better measurment for you. its about 2.58
 Old 03-25-2008, 05:23 PM   #251
ZoomMS3's Avatar
Posts: 94   (View Stats)
ZoomMS3 has a spectacular aura aboutZoomMS3 has a spectacular aura about
Can you explain how you did that? Did you just put something in there to the size you want then filled everything around it with silicone?
Mine is going on once the car is back and I would like to have this stupid mistake fixed. Corksport never called me back about the new MAF, so hopefully they get back to me tommorow.
On motor #3
Turbo #2
Now have a SSM 08 STi!!
ZoomMS3 is offline   Reply With Quote
 Old 03-25-2008, 06:20 PM   #252
bova's Avatar
Groans: 45
basically i took a 2.75" coupler, cut it down the middle cause it was just a tad to big. then i cut a spot out near my cut down the middle for where the maf sits. then i put some silicon in the tube and then loaded up all the way around the coupler with it as well. its a messy job so have some garbage rags around. then all you have to do is slide it in and get is positioned just right. like loosh said you want about 1/4" of the coupler to go past where the maf sits. There is probably about an inch and to an inch and a half in front of the maf.
then when you have it in try and get some silicon in the cracks to make sure they are all sealed up, its tough to get the far end but i just put some on my finger and went around as best i could. once that is all said and done i would let it dry for at least an hour if not more.
last time i did it i don't think i waited long enough or put enough rtv silicon in cause when i took it apart today i noticed the front part of the coupler was peeling off the tube which leads me to believe some air was geting trapped under there and probably causing some turbulence and decreasing the size of the maf housing more.
since i fixed it today i haven't taken it out for a drive, i'm going to let it cure over night so i won't drive it til i head to work in the morning. but hopefully i don't have backfire anymore.
 Old 03-26-2008, 06:13 AM   #253
bova's Avatar
Groans: 45
new update for you. no backfires this morning since i fixed it. should also be hearing from corksport sometime today. (fingers crossed)
 Old 03-27-2008, 02:12 PM   #254
ZoomMS3's Avatar
Still no call back..
corksport
On motor #3
Turbo #2
 Old 03-27-2008, 02:25 PM   #255
bova's Avatar
Groans: 45
they called me yesterday and i'm waiting to hear back from kelly to see what they are going to do for me since i'm the first speed6 to have this problem.
 Old 03-29-2008, 12:30 PM   #256
Rican219's Avatar
Posts: 120   (View Stats)
Rican219 is the leader of the worldRican219 is the leader of the worldRican219 is the leader of the worldRican219 is the leader of the worldRican219 is the leader of the worldRican219 is the leader of the worldRican219 is the leader of the worldRican219 is the leader of the worldRican219 is the leader of the worldRican219 is the leader of the worldRican219 is the leader of the world
Still no call back here
[SIGPIC][/SIGPIC]www.myspace.com/rican219
MODS:
TWM Short Shifter Stage 2, CPE downpipe Highflow Cat, Corksport 3 inch Catback, SU motor Mount, HKS BOV VTA, Spin on Oil filter conversion, Greddy Turbo timer, H&R Springs, Sport Max wheels, Corksport Strut Tower Brace, Corksport FMIC,Turbine Tech Front Engine Mount, Turbine Tech Rear Diff Bracket and Bushings, PROcede EMS, 2871r, Dash Hawk
Rican219 is offline   Reply With Quote
 Old 03-29-2008, 01:49 PM   #257
bova's Avatar
Groans: 45
kelly called me yesterday and sent me an email. they are doing testing this weekend and she'll get back to me monday.
 Old 04-10-2008, 06:28 PM   #258
bova's Avatar
Groans: 45
ok so this hasn't been updated in a while but i just wanted to say that corksport was able to replicate my lean at idle issues and what not on another speed6 so they are sending me a new maf housing tomorrow.
 Old 04-11-2008, 07:37 AM   #259
ZoomMS3's Avatar
wtf i want a fukin new housing. im calling again today.
On motor #3
Turbo #2
 Old 04-11-2008, 07:51 AM   #260
bova's Avatar
Groans: 45
its still somewhat of a prototype i guess. they have to fab it up for me.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/corksport-front-mount-intercooler-74/
Mazda Speed Forums: Mazdaspeed High Performance Forum with Gallery, Specs, discussion & more This thread Refback 03-25-2008 04:47 PM
Corksport Ram Air Box bova MazdaSpeed 3/6 - Turbo Induction 3 04-08-2010 06:42 PM
Corksport FMIC Kit bova MazdaSpeed 3/6 - Turbo Induction 22 06-12-2008 08:44 PM
Going all corksport exhaust it looks like... Haltech MazdaSpeed 3 - Engine, Transmission & Driveline 20 03-26-2008 11:22 PM
CorkSport DP + Vibrant SLS MS3 MazdaSpeed 3 - Engine, Transmission & Driveline 9 03-24-2008 10:57 AM
Page generated in 0.37496 seconds with 26 queries
