  • 1 Post By Jeff23spl
 Old 07-08-2019, 07:21 AM   #1
Jeff23spl's Avatar
Posts: 2,233   (View Stats)
humm ok, unless you datalog it to see if something wrong else where....
knock, temp or fuel could call for boost reduction at some points. your boost level isn,t far from spring pressure like if your ebcs isn,t working much to raise boost....make sure the 2 wires that connect to it, aren,t damaged and that the solenoid itself isn,t burned...
i would say to try an external manual boost control to see if you can increase it but i would wait to see datalogs unless you got something wrong to avoid zzb
BR1JZL likes this.
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
BR1JZL (08-12-2019)
cracked rim...fml hatchedspeed3 MazdaSpeed 3/6 - Wheels & Tires 8 04-21-2015 10:05 AM
Cracked windshield :( blackms3_71 Mazdaspeed3/6 General Discussion 19 06-11-2013 07:11 PM
Page generated in 0.22780 seconds with 22 queries
