  • 1 Post By Jeff23spl
 Old 06-08-2019, 06:15 PM   #1
BR1JZL's Avatar
Posts: 40   (View Stats)
BR1JZL is a splendid one to beholdBR1JZL is a splendid one to beholdBR1JZL is a splendid one to beholdBR1JZL is a splendid one to beholdBR1JZL is a splendid one to beholdBR1JZL is a splendid one to beholdBR1JZL is a splendid one to behold
Default Cracked K04?
Hey all, I am hoping someone can help confirm something for me.
I have a '05 Mazda 6 MPS (or Mazdaspeed6) for about 6 months, and can't seem to ever get it to perform the way that other MS6's have (car produces boost, but feels like an NA car)
I have done all kinds of diagnostics, and everything seems to check out, so I've been chasing any kind of leak and been doing smoke tests on the intake side, and I have found nothing. I have done a smoke test of the exhaust side and the smoke has come out of the side of the turbo (wastegate actuator arm side). Is this normal, or this the reason for my car performing like a stock Corolla?
I've uploaded a video for reference.
Mods slowly coming along!!!! Autotech HPFP, CircuitWerks Down/Testpipe, Cobb Accessport V2 and a CPE Turbo Inlet Pipe (Waiting to put it on)
BR1JZL is offline   Reply With Quote
 Old 07-05-2019, 02:07 AM   #2
BR1JZL's Avatar
Has anyone had a similar thing?
 Old 07-05-2019, 09:58 AM   #3
Jeff23spl's Avatar
Posts: 2,233   (View Stats)
we dont see much but if exhaust side leak enough to decrease performance, you would hear an exaust leak and see black deposit where the crack is.
You can do a lot better than a smoke test by replacing inlet filter by a pipe with a nozzle to inject 15-20psi from a garage air compressor and check for leaks...
to diagnose those car you need a way to read and log obd2 parameters. the best tool is a cobb or versatuner....
btw if you have a downpipe you would usually need a tune different from the factory one...it should overboost cut a lot....
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 07-05-2019, 04:56 PM   #4
BR1JZL's Avatar
Thanks Jeff, should've mentioned I've done boost leak tests, exhaust leak test (using shop air and soapy water), compression test, leak down test, etc and I am wanting to get a Cobb AP, but have my wedding coming up, so car funds are on hold :/.
At the moment, car isn't overboosting, its hitting 15.6PSI and settling down to 10-12PSI, so no cut.
 Old 07-08-2019, 07:21 AM   #5
Jeff23spl's Avatar
humm ok, unless you datalog it to see if something wrong else where....
knock, temp or fuel could call for boost reduction at some points. your boost level isn,t far from spring pressure like if your ebcs isn,t working much to raise boost....make sure the 2 wires that connect to it, aren,t damaged and that the solenoid itself isn,t burned...
i would say to try an external manual boost control to see if you can increase it but i would wait to see datalogs unless you got something wrong to avoid zzb
BR1JZL likes this.
Wife drive 2010 CX7
BR1JZL (08-12-2019)
cracked rim...fml hatchedspeed3 MazdaSpeed 3/6 - Wheels & Tires 8 04-21-2015 10:05 AM
Cracked windshield :( blackms3_71 Mazdaspeed3/6 General Discussion 19 06-11-2013 07:11 PM
Page generated in 0.26248 seconds with 22 queries
