 Old 11-17-2014, 09:24 AM   #1
leo766's Avatar
Posts: 300   (View Stats)
Default Custom catch can media?
Is there really an issue with using aluminum vs SS mesh? I would think aluminum is just as safe in terms of anti corrosive properties(god knows most intakes are made from the ish) and I wanted to build my own mini can maybe for the valve cover to intake connection pre turbo... I got some aluminum mesh for like 7$ at hardware store, and was wondering since seeing almost all cans with filter media in them have stainless mesh if aluminum has some property I am not aware of that makes it a poor metal of choice for screens?
Fresh to High Rockies Colorado from VA DC area MS6 07 TiGray!
Cpe: FMIC, CAI, TIP, HPFP, bone engine mount
Cobb AP, Test pipe, turbosmart BPV, whitlenine swaybar
Turbine Tech: Extra front motor mount, both diff mounts +bushings
EGR Delete, mini 0803 Dash cam, Prosport Boost guage. Dash Hawk,
AWR: Trans mount with 88 duro bushings, End links front/rear(removed due to them being total garbage and got some moog stock ones for all around on rockauto.
17x7 Kosei K1 TS 15lb rims, goodyear 225/50r17 all season performance tires and RPM springs
Waiting to install: SPC Ball Joints, SS clutch line, lower engine mount bracket local car shop damaged during clutch install and thermal TB gasket and coolant inline plumbing line that can be turned on and off on demand
leo766 is offline   Reply With Quote
Embedded Media Expansion Haltech Website Help/Feedback 1 08-23-2008 06:02 AM
Page generated in 0.22547 seconds with 20 queries
