 Old 10-22-2015, 08:57 PM   #1
Just_Shep's Avatar
Posts: 8   (View Stats)
Just_Shep is on a distinguished road
Groaned at 4 Times in 1 Post
Default Cxracing fmic flange problems
Has anyone ever had this problem where the stock bpv leaks because of where the other wholes are? You can see where the oem gasket sits in the pic. Any ideas?
2008 ms3 20k miles MGM
Cobb RMM // Cobb SRI // Damond OCC // Cobb AP // Autotechs // Cobb TIP // CNT TBE... on back order // pilot super sport tires // CXRacing fmic // forge v2 //
Just_Shep is offline   Reply With Quote
 Old 10-22-2015, 09:40 PM   #2
blackms3_71's Avatar
Posts: 2,250   (View Stats)
Cheap kit is cheap.
Fill holes with rtv?
Last edited by blackms3_71; 10-22-2015 at 09:40 PM. Reason: MSF Database - Automerged Doublepost
 Old 10-22-2015, 10:49 PM   #3
stockms3's Avatar
Posts: 840   (View Stats)
Groans: 74
I have a forge v1, tuned to 21psi no leaks.
 Old 10-26-2015, 09:23 AM   #4
PurplFox's Avatar
Posts: 352   (View Stats)
I just reamed and tapped the holes for a set of plugs. Easy fix if you already have a tap. Other option, Fill holes with JB weld let cure overnight.
 Old 01-05-2016, 04:34 PM   #5
xliquidx's Avatar
Posts: 170   (View Stats)
xliquidx is the leader of the worldxliquidx is the leader of the worldxliquidx is the leader of the worldxliquidx is the leader of the worldxliquidx is the leader of the worldxliquidx is the leader of the worldxliquidx is the leader of the worldxliquidx is the leader of the worldxliquidx is the leader of the worldxliquidx is the leader of the worldxliquidx is the leader of the world
Obviously depends on the bpv and gasket... my synapse DV doesn't leak with the cx racing flange as it only has a small circle gasket unlike the stock bpv
xliquidx is offline   Reply With Quote
CxRacing FMIC question 11mazdaspeed3 Gen2 MS3 General Discussion 19 07-07-2011 11:17 AM
CXRacing FMIC dkspeed MazdaSpeed 3/6 - Turbo Induction 10 11-16-2010 03:10 AM
PG kit + CXRacing FMIC core D08SPEED3 MazdaSpeed 3/6 - Turbo Induction 22 11-06-2010 11:37 AM
Cxracing custom FMIC bcmurphy87 MazdaSpeed 6 - Engine, Transmission & Driveline 11 05-03-2009 10:24 PM
Page generated in 0.25805 seconds with 25 queries
