 Old 04-26-2010, 10:08 AM   #41
Ms3speed's Avatar
Posts: 172   (View Stats)
Ms3speed has much to be proud ofMs3speed has much to be proud ofMs3speed has much to be proud ofMs3speed has much to be proud ofMs3speed has much to be proud ofMs3speed has much to be proud ofMs3speed has much to be proud ofMs3speed has much to be proud ofMs3speed has much to be proud ofMs3speed has much to be proud of
after looking at the pictures again I guess the pipeing it doesn't have a miror polished finish but I wouldn't say its brushed aluminum its just like the polishing done on polished lips of wheels.
2009 MS3 Sport (Crystal White) Hks catback, Turbosmart bpv, Ets 3.25" Tmic, dnp manifold, turbo Xs downpipe/racepipe, Su recirc line/vac lines, Su boost tubes, Injen cai, Hypertech flash, Trz tranz & rear mm, weapon r torq damper, Rpmc tip, Methnol, H&R springs, Fcmi bump stops, Grimmspeed ebc, Jb short shift plate, Su solid shifter bushings, Msd dash hawk, laminix yellow fog films, Mtec bulbs, Motegi sp10 18x8 40Et wheels with Nitto neogen 225/40tires, Muteki lugs, debadged rear emblem/removed side moldings, 15% window tint, Su black out M logos, nextmod rear spoiler lip.
SOLD!!! You will be missed
Ms3speed is offline   Reply With Quote
 Old 04-26-2010, 01:06 PM   #42
MS3_65's Avatar
Posts: 203   (View Stats)
MS3_65 has a reputation beyond reputeMS3_65 has a reputation beyond reputeMS3_65 has a reputation beyond reputeMS3_65 has a reputation beyond reputeMS3_65 has a reputation beyond reputeMS3_65 has a reputation beyond reputeMS3_65 has a reputation beyond reputeMS3_65 has a reputation beyond reputeMS3_65 has a reputation beyond reputeMS3_65 has a reputation beyond reputeMS3_65 has a reputation beyond repute
Groaned at 23 Times in 10 Posts
If you call CXRacing direct - he will honor the Ebay price as he did for me today. $499 + CA tax + $20 shipping to a CA address $567 shipped!
Originally Posted by DSIT995 View Post
yeah I emailed CXracing and its legit, if u type in "mazdaspeed 3" in the search on the homepage it'll come up, but its more expensive on CXRacing than on Ebay, dont know why.
Couple guys on here tried it, theres a thread on this exact subject...
US Air Force Retired - Gunner - AC-130 Spectre Gunship / Disabled American Veteran
4 tours Iraq / 3 tours Afghanistan "Smoked 56" But Who's Counting?
Vengeance From Above: http://www.youtube.com/watch?v=If-oQXk0oI4
COBB AP, COBB INTAKE, COBB Turbo Inlet Pipe, CP-E HPFP, CX-RACING FMIC, CP-E CATTED DP, CP-E EXHAUST, FORGE BPV, FORGE WGA, PTP PVC Restrictor Pill, Boon Turbo Bolt
MS3_65 is offline   Reply With Quote
 Old 04-26-2010, 07:43 PM   #43
MGM_GT3's Avatar
Posts: 207   (View Stats)
MGM_GT3 has a reputation beyond reputeMGM_GT3 has a reputation beyond reputeMGM_GT3 has a reputation beyond reputeMGM_GT3 has a reputation beyond reputeMGM_GT3 has a reputation beyond reputeMGM_GT3 has a reputation beyond reputeMGM_GT3 has a reputation beyond reputeMGM_GT3 has a reputation beyond reputeMGM_GT3 has a reputation beyond reputeMGM_GT3 has a reputation beyond reputeMGM_GT3 has a reputation beyond repute
Think I'm going to sell my turbine tech front motor mount and purchase the FMIC. Can't beat $550 for a complete FMIC... Sell the cheapo bpv
MGM_GT3 is offline   Reply With Quote
 Old 04-26-2010, 07:46 PM   #44
Addikted To Boost's Avatar
Posts: 1,837   (View Stats)
so is it completely necessary to have an upgraded fuel pump and tuning solution before going with a fmic? i really want to get some cooler bat's for this summer but dont want to mess with the fuel pump yet... it seems like the ecu could compensate for the cooler air on the stock tune right?
09 MGM MS3
 Old 04-26-2010, 07:59 PM   #45
serium's Avatar
Posts: 448   (View Stats)
serium is the leader of the worldserium is the leader of the worldserium is the leader of the worldserium is the leader of the worldserium is the leader of the worldserium is the leader of the worldserium is the leader of the worldserium is the leader of the worldserium is the leader of the worldserium is the leader of the worldserium is the leader of the world
Groaned at 34 Times in 12 Posts
Addikted To Boost
i dont see why not...if your pump is workin fine now, I dont think lower bats will change that.
2008.5 Red Mazdaspeed 3
Performance Mods: OBX RP | SURE Intake | SU-TMIC | Cobb TIH | Turbosmart Hybrid BOV | JBR 80 Duro RMM | Hypertech
Appearance Mods: 15% tint | Blacked-out Emblems, Side Markers and Side Reflectors
Monitoring: Dashhawk
serium is offline   Reply With Quote
 Old 04-26-2010, 08:08 PM   #46
08cosmic3's Avatar
Posts: 2,920   (View Stats)
I'm running a custom kit using black PC piping from CXRacing and their IC. I'm running Stg2 Cobb AP holding 19 psi and my fuel pump is holding up just fine. It seems that not all FP's are equal though. My piping might be slightly different but the routing is the same, it will fit but not straight down. My hot pipe angles down toward the fender and connects to the j pipe using the cold side coupler from my stock TMIC. You will remove some coating working it down but no one will see it anyway. I used the PG how-to when installing mine. You have to unconnect the power steering cooler from the lower bracket and just let it hang. You also have to remove a pieces plastic support. Look up PG install how-to on another forum I believe. I'll post a link, hope the mods are OK with this link to 24 7.
http://www.mazdas24 7.com/forum/showthread.php?t=123753503
Remove the space between the 4 and 7 . This thread was most helpful with my install.
 Old 04-27-2010, 03:43 AM   #47
Ms3speed's Avatar
You can run a fmic with stock tune but what really brings the power out of haveing one is more boost, with just a front mount your power will be more consistant but don't exspect big gains without 2-3 more psi. Also get a turbo inlet pipe at the very least that will help keep your boost preassure up because of the added volume the front mount will take over stock.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/cxracing-front-mount-intercooler-mazdaspeed-3-a-52668/
?????? This thread Refback 05-26-2014 06:02 AM
CXRacing FMIC dkspeed MazdaSpeed 3/6 - Turbo Induction 10 11-16-2010 03:10 AM
PG FMIC piping kit with CXRACING core skeeter149 MazdaSpeed 3/6 - Turbo Induction 69 03-18-2010 05:58 PM
Cxracing custom FMIC bcmurphy87 MazdaSpeed 6 - Engine, Transmission & Driveline 11 05-03-2009 10:24 PM
Page generated in 0.28438 seconds with 26 queries
