 Old 07-30-2008, 10:08 AM   #41
redrocketz's Avatar
Posts: 1,122   (View Stats)
redrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond repute
I like it but I would hide the tubing in the hood around the shroud for a cleaner install.
redrocketz is offline   Reply With Quote
 Old 07-30-2008, 10:18 AM   #42
gsrtype1's Avatar
Posts: 7,514   (View Stats)
Groans: 102
yeah I was thinking this too, and then have the misters pionted dwon straight on the intercooler
 Old 07-30-2008, 10:24 AM   #43
redrocketz's Avatar
exactly like the Subies do it.
 Old 07-30-2008, 11:33 AM   #44
Buildabong's Avatar
Posts: 3,034   (View Stats)
Buildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the world
Groans: 213
Groaned at 274 Times in 187 Posts
joe not haten or anything but it looks ghetto as hell! Like u paid 4wetbacks to come up with a desgin... Not Hagen on mexicans or Hispanics cause I'm a wetback =) but u could have made it better joe
Buildabong is offline   Reply With Quote
 Old 07-30-2008, 12:08 PM   #45
gsrtype1's Avatar
Groans: 102
U not a wetback u butthead! thats not a nice name for your race.. Yeah i'm gonna clean it up I think im gonna put everything up in the shroud in the hood so it sprays directly on the intercooler.
 Old 07-30-2008, 02:08 PM   #46
ztuner's Avatar
Posts: 554   (View Stats)
ztuner is the leader of the worldztuner is the leader of the worldztuner is the leader of the worldztuner is the leader of the worldztuner is the leader of the worldztuner is the leader of the worldztuner is the leader of the worldztuner is the leader of the worldztuner is the leader of the worldztuner is the leader of the worldztuner is the leader of the world
1. Rust won't be an issue since both the ic and valve cover are aluminum
2. If you are worried about hard water and its problems use alcohol (windsheild wiper fluid is 50 % water and 50 % alcohol) It evaporates faster than water if you spray it. If you want you can use higher concentrations of alohol for better evaporation and cooling
3. Sprayers can be hooked up with temp dependent controllers so they spray at certain temps. Doing it manually is pointless
4. You would need to spray a LOT of fluid to remove significant amount of heat from the ic.
Hope this helps
Harry
Z32 Specialist
07 Sport
Cobb AP - V103f map
Cobb Sri
ETS 3.25 TMIC
Vibrant Catted midpipeback exhaust
Forge BPV
CS inserts
Dashhawk logger
Soon to follow
SSR Wheels and wider tires
CS downpipe
Check out
http://ztuner.com/newdyno.htm
ztuner is offline   Reply With Quote
The Following 2 Users Say Thank You to ztuner For This Useful Post:
Demi (07-30-2008), gsrtype1 (07-30-2008)
 Old 07-30-2008, 02:17 PM   #47
gsrtype1's Avatar
Groans: 102
thanks! yeah i think my extudhone coldpipe that i havent installed yet has a meth whole already in it!! After the Flash then Cpe-dp and meth!!!
 Old 07-30-2008, 02:34 PM   #48
mk_slayr's Avatar
Posts: 182   (View Stats)
mk_slayr has a reputation beyond reputemk_slayr has a reputation beyond reputemk_slayr has a reputation beyond reputemk_slayr has a reputation beyond reputemk_slayr has a reputation beyond reputemk_slayr has a reputation beyond reputemk_slayr has a reputation beyond reputemk_slayr has a reputation beyond reputemk_slayr has a reputation beyond reputemk_slayr has a reputation beyond reputemk_slayr has a reputation beyond repute
Originally Posted by gsrtype1 View Post
by "DI" water you mean purfified water? i just installed one of those "PUR" water prurifiers for my fuacet so that might be a good idea
DI stands for De-Ionized, it's water that has passed through a filter to remove metal, salt and other ions present.
^ a few posts above,
a lot of water isn't necessary. Water can store a great deal of energy in a very small amount. Put some water on a stove and bring it to boil. Stick your hand over the steam and watch it condensate into droplets. When they go from gas to liquid they release a good deal of stored energy in the form of heat. It's not the steam that burns your hand, it's the energy from the state change. Likewise going from liquid to gas requires a good bit of energy given the atmosphere of the engine compartment. Even a little bit of water will make a slight difference. The amount being misted will make a noticeable change. I think the pump I bought flows around 1 gpm. Now if the water is in large droplets it will be much less effective than a fine mist. That goes back to the maximum surface area for a given volume. If the mist is fine enough a small amount of liquid (say 1 quart) should make a noticeable change.
I was talking with SLS about this sprayer a while ago and he made a good point. The majority of the heatsoak is occurying on the valve cover side of the intercooler. To make the spray effective it needs to hit both sides of the intercooler. He also suggested heat reflective tape to reduce the soak. I'm thinking about getting a piece of aluminum, covering it with the reflective tape then drilling the hole pattern of the mounting points on the IC. That way I can bolt the plate directly between the valve cover and the intercooler. I can then mount nozzels on the plate to spray on the underside of the IC. Shouldn't be more than 60 or 70 dollars for everything and I think it will make a notable reduction in boost temp. Idk though.
I'll look at it today more. Being sick means no going to the gym.
mk_slayr is offline   Reply With Quote
 Old 08-01-2008, 12:45 AM   #49
HIGHBRED8's Avatar
Posts: 49   (View Stats)
HIGHBRED8 has a spectacular aura aboutHIGHBRED8 has a spectacular aura aboutHIGHBRED8 has a spectacular aura about
just a side note, if any of you fmic guys try this remember to put a "one way" valve in between the i/c and pump, might even need one between reservoir and pump depending on how you mount stuff.
if the i/c is lower than the pump then once you spray youll get a nice syphon going and youll be scratching your head when everytime you come to your car you water is empty even though you havent driven the car in 12hrs. top mounts shouldnt need this because the water is flowing upwards.
i had this on my fmic in my old srt and it took me a minute (week) to figure it out so i figured id save someone the headache.
08 black CSRT-4
e.d tbe
e.d sri
e.d fmic
HIGHBRED8 is offline   Reply With Quote
The Following 2 Users Say Thank You to HIGHBRED8 For This Useful Post:
Demi (08-01-2008), SyntaxEscobar (12-17-2008)
 Old 08-01-2008, 03:38 AM   #50
dkswim's Avatar
Posts: 175   (View Stats)
dkswim has much to be proud ofdkswim has much to be proud ofdkswim has much to be proud ofdkswim has much to be proud ofdkswim has much to be proud ofdkswim has much to be proud ofdkswim has much to be proud ofdkswim has much to be proud ofdkswim has much to be proud of
sweet
dkswim is offline   Reply With Quote
 Old 08-01-2008, 08:26 AM   #51
gsrtype1's Avatar
Groans: 102
Where doing my buddies EVO 9 AMS fmic this weekend i'll take some pics or vid.
 Old 08-03-2008, 10:34 AM   #52
gsrtype1's Avatar
Groans: 102
heres Ricks set up, he used his rear widsheild wiper resivior came out very clean looking and functional!
The Following User Says Thank You to gsrtype1 For This Useful Post:
Demi (08-03-2008)
 Old 08-03-2008, 11:27 AM   #53
Demi's Avatar
Posts: 1,107   (View Stats)
Demi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the world
Groans: 61
Groaned at 16 Times in 11 Posts
You da man!!!!
Beginners guide to turbos<- New to this? Give it a look!
-And for the rest of you, if it comes from Autozone and doesnt replace something that broke off your car or make your cabin smell like Coco Butter, its fucking rice.
Demi is offline   Reply With Quote
The Following User Says Thank You to Demi For This Useful Post:
gsrtype1 (08-04-2008)
 Old 08-03-2008, 01:27 PM   #54
Buildabong's Avatar
Groans: 213
c02 spray on the way
 Old 08-03-2008, 11:41 PM   #55
SyntaxEscobar's Avatar
Posts: 21   (View Stats)
SyntaxEscobar will become famous soon enough
Steel = Rust.
Aluminum = Corrosion.
Just a little kindergarten info for you noobs.
Water on any metal provides some type of eating it. However, I really doubt you will have problems, my valve cover gets hot enough to steam the water right off.
Props to the OP on this mod.
Life is hard. After all, it kills you.
SyntaxEscobar is offline   Reply With Quote
 Old 08-04-2008, 09:46 AM   #56
gsrtype1's Avatar
Groans: 102
Originally Posted by SyntaxEscobar View Post
Steel = Rust.
na bro it evaporates to quick like imidiatly...
 Old 08-04-2008, 09:46 AM   #57
gsrtype1's Avatar
Groans: 102
sweet!
 Old 08-04-2008, 10:43 AM   #58
Buildabong's Avatar
Groans: 213
f that gay hott water shit! I'm all bout freezing my damn intercooler! Hahaha
 Old 08-04-2008, 10:59 AM   #59
Fux Wit It
Darksun280's Avatar
Posts: 9,214   (View Stats)
Groans: 175
LOL
Carry on citizens....
10.7 @ 133 auto 1G DSM
 Old 08-04-2008, 12:11 PM   #60
gsrtype1's Avatar
Groans: 102
i am intrigued by the thought of spraying the intercooler with c02 or nitrous after Darksun results
Spy Shots: BMW X6 5.0iS puts the "sport" in "sports activity coupe" Haltech Automotive News 0 07-28-2008 06:30 AM
Separate "Appearance" from "Wheels/Tires" KaiserSoze Website Help/Feedback 1 04-21-2008 08:33 PM
Pics Aplenty: MANSORY McLaren SLR "Renovatio" and Ferrari 599 GTB "Stallone" Haltech Automotive News 0 04-08-2008 04:20 PM
Volkswagen drops "Passat" sticks with "CC" for new sedan Haltech Automotive News 1 04-03-2008 04:29 PM
BPI Plans Crackdown as BitTorrent Becomes "Too Easy" Haltech Computers & Technology News 0 03-29-2008 08:30 AM
Page generated in 0.38963 seconds with 29 queries
