 Old 01-11-2012, 07:43 PM   #1
mikelevi's Avatar
Posts: 362   (View Stats)
mikelevi is the leader of the worldmikelevi is the leader of the worldmikelevi is the leader of the worldmikelevi is the leader of the worldmikelevi is the leader of the worldmikelevi is the leader of the worldmikelevi is the leader of the worldmikelevi is the leader of the worldmikelevi is the leader of the worldmikelevi is the leader of the worldmikelevi is the leader of the world
Default DIY DP Gasket (M2 DP)
I had to replace my broken V Band clamp tonight. To my surprise, the gasket between the DP and the V Band was completely incinerated. Doing a little research, I discover that Header Gaskets are rated for the same temps as V Band gaskets.
So I drove down to Autozone. They only have 2.5" Header Mr. Gaskets.
I then go to Advance Auto. They have the 3" Mr. Gaskets as well as 3" Fel-Pro (5.99) which look a little better (steel core laminate).
When I get back to the garage I trace out the outline of the old gasket, pop it on the ban saw and cut it.
This thing feels so much better than what comes with the M2 DP on ebay.
I center it in the new clamp, torque and reassemble.
No leak, and no wait for an overpriced ordered V Band Gasket. Should hold up as well.
Figured I'd share if anyone finds themselves in a pinch!
mikelevi is offline   Reply With Quote
The Following 3 Users Say Thank You to mikelevi For This Useful Post:
karl-hungus (01-12-2012), redboat (01-07-2014), theschrum (02-23-2012)
 Old 01-11-2012, 08:07 PM   #2
crazyp's Avatar
Posts: 1,093   (View Stats)
Groans: 68
what is a vband gasket? Unless Im doing it wrong...........
The Following 3 Users Say Thank You to crazyp For This Useful Post:
86AmishMs3 (01-12-2012), EdgeAutosport.com (01-12-2012), kmac (01-17-2012)
 Old 01-11-2012, 08:08 PM   #3
zenger's Avatar
Posts: 602   (View Stats)
zenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the world
Groaned at 8 Times in 7 Posts
this
2007-Mazdaspeed 6
BNRSIII~all supportings
Zoom Zoom Boom part out.
zenger is offline   Reply With Quote
 Old 01-12-2012, 05:22 AM   #4
patrick failman
karl-hungus's Avatar
Posts: 4,635   (View Stats)
Groans: 74
you have nice hands.
The Following 3 Users Say Thank You to karl-hungus For This Useful Post:
Easter Bunny (01-12-2012), kmac (01-17-2012), mikelevi (01-12-2012)
 Old 01-12-2012, 07:12 AM   #5
mikelevi's Avatar
actually, those aren't mine. I brought in a hand model for that shot.
The Following 4 Users Say Thank You to mikelevi For This Useful Post:
Easter Bunny (01-12-2012), karl-hungus (01-12-2012), kmac (01-17-2012), Speed_j23 (02-20-2012)
 Old 01-12-2012, 08:07 AM   #6
You don't put a gasket in between the v band clamps, that's the beauty of the v bands.
 Old 01-12-2012, 08:10 AM   #7
mikelevi's Avatar
I've seen on other posts/sites although many say a gasket is not required many people experience leaks in between. I say rather safe than sorry.
The Following User Says Thank You to mikelevi For This Useful Post:
 Old 01-12-2012, 08:12 AM   #8
IMO that defeats the purpose of the beautiful flanges, they are machined like that for a reason. I didnt even think you could fit a gasket in between the two to be honest
Bucker (02-20-2012)
 Old 01-12-2012, 08:17 AM   #9
mikelevi's Avatar
thanks for the info! The M2 came with the gasket so my assumption was that is was needed.
 Old 01-17-2012, 10:56 AM   #10
crazyp's Avatar
Groans: 68
when I had a M2 I always wondered WTF that gasket was for. on aircraft none of the vbands take gaskets so thats how I looked at it. But your right it does seem to be a vband gasket after searching teh interwebz
 Old 01-17-2012, 11:04 AM   #11
v8 convert
p057's Avatar
Posts: 1,782   (View Stats)
p057 has disabled reputation
Groans: 220
its in there because the clamp sucks and doesnt fit properly.
then the gasket sucks.
so you're forced to fix a problem to fix another problem that shouldn't exist.
Thanks ebay!
PS: RTV copper is 10000% better and can get more uses out of the tube of leftovers when done.
p057 is offline   Reply With Quote
The Following 2 Users Say Thank You to p057 For This Useful Post:
kmac (01-17-2012), redboat (01-07-2014)
 Old 01-17-2012, 04:59 PM   #12
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
i need some worm clamp gaskets anyone got?
The Following 3 Users Say Thank You to dooderek For This Useful Post:
ABolewski (01-07-2014), crazyp (01-17-2012), kmac (01-17-2012)
 Old 02-01-2012, 08:41 AM   #13
mikelevi's Avatar
Update: After I made the DIY Gasket, I purchased a really solid new 3" V Band clamp from Amazon. When changing clamps the Gasket I made did the same thing, burned through on one side. Its because the V Band clamp that comes with the M2 sucks big floppy donkey dick. I didnt even bother making a new gasket for this new V Band clamps. You could tell that it is much better, and I dont believe this one will need a gasket.
My Recommendation is buy a new V Band Clamp, dont waste your time on a new gasket. With the M2 Clamp, you'll just continue to burn through.
 Old 02-19-2012, 05:26 PM   #14
Karmat's Avatar
Posts: 1,179   (View Stats)
Did you end up running the clamp without a gasket? Results?
2002 Corvette Z06 (Black)
 Old 02-20-2012, 07:18 AM   #15
mikelevi's Avatar
Yes, so far its been leak less. Although I've been having one hell of a time controlling the leak from DP to Exhaust pipe. I ended up just using my OEM Gasket again but there is still a slight leak.
Karmat (02-20-2012)
 Old 02-20-2012, 10:03 AM   #16
Karmat's Avatar
Sounds good. Ordered a clamp last night good to know that I don't need to get a gasket.
I also have a leak between the exhaust and the downpipe in the top portion of the connection. Wonder if a magnaflow exhaust would remedy the issue.
 Old 02-20-2012, 12:28 PM   #17
Speed_j23's Avatar
Posts: 611   (View Stats)
Speed_j23 is the leader of the worldSpeed_j23 is the leader of the worldSpeed_j23 is the leader of the worldSpeed_j23 is the leader of the worldSpeed_j23 is the leader of the worldSpeed_j23 is the leader of the worldSpeed_j23 is the leader of the worldSpeed_j23 is the leader of the worldSpeed_j23 is the leader of the worldSpeed_j23 is the leader of the worldSpeed_j23 is the leader of the world
The problem is OEM gasket sucks for anything other than on complete OEM exhaust. Just order a 3 inch vibrant gasket; that's what I have with no problems running 3 inch do and OEM CBE.
New: 06 WWP MS6
Old: 06 LPM MS6
Speed_j23 is offline   Reply With Quote
The Following User Says Thank You to Speed_j23 For This Useful Post:
mikelevi (02-20-2012)
 Old 02-20-2012, 01:49 PM   #18
mikelevi's Avatar
I wonder if I can justify the cost of the Magnaflow setup to my wife in order to fix this leak? I will say from clips the catless DP and Magnaflow combinations sounds really good. I went with stock CB because I HATE excessive drone.
 Old 02-20-2012, 01:57 PM   #19
v8 convert
p057's Avatar
Groans: 220
i left stock CBE, no gains to be seen from replacing it. cops leave me alone, and when i start it up in the morning it sounds sexy. compliments from the ladies at work when i take them out to lunch. "omgz you gots V8 in there?" lawl.
mikelevi (02-20-2012), redboat (01-07-2014)
 Old 01-07-2014, 11:15 PM   #20
redboat's Avatar
Posts: 634   (View Stats)
redboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the world
check my gasket today, it was toast. I'l be ordering a new V band clamp, I'll also get this for extra insurance
V-Band Sealing Gasket, 3", Multi-Layer Steel (MLS) - 034Motorsport | Performance Parts for Audi, Porsche, and Volkswagen
redboat is offline   Reply With Quote
 Old 02-01-2018, 06:34 AM   #21
GroceryGtr's Avatar
Posts: 472   (View Stats)
old ass thread, but wanted to update it as it came up on a recent thread I replied to and figured someone might reference this one. Seems people forget there are 2 styles of vband flanges...
the reason the ebay dps come with a gasket is because the majority use the old school flat/universal vband flanges instead of the male/female specific flanges. The male/female flanges have a lip that fits inside the other end making for a leak proof fit eliminating the need for a gasket. The cheapy ebay versions are just flat surfaces that mate together, no lip, hence the need for a gasket. So its not necessarily the cheap vband clamp(dont get me wrong I would still replaced it asap), but rather the flange style that causes most of the leaking issues.
Edit: I've been told there are a few new offerings on ebay that have the new lip style flanges... my advice would be do your homework. Flat styles shouldnt necessarily be a dealer breaker, just understand they require a quality gasket and clamp to seal correctly.
Exhaust gasket Feargod69 MazdaSpeed 3/6 - Turbo Induction 19 10-23-2014 06:11 PM
MS6 TP gasket help MS6FL Mazdaspeed3/6 General Discussion 14 06-14-2011 03:32 PM
bpv gasket boosthead MazdaSpeed 3/6 - Turbo Induction 3 08-01-2010 05:19 PM
BPV gasket? Zeya MazdaSpeed 3/6 - Turbo Induction 18 05-13-2008 06:18 PM
Page generated in 0.41148 seconds with 31 queries
