  • 1 Post By Dennisms3
  • 1 Post By Djohns
 Old 09-15-2017, 06:48 AM   #1
LenSpeed6's Avatar
Posts: 164   (View Stats)
LenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud of
Default down pipe suggestions
hi all,
my buddy with a MS6 is going to be putting a CorkSport turbo on his car and was wondering what the next best option for a down pipe next to a CorkSport one. Logic says that keeping with the same brand is ideal but if he chose a different route what would it be?
car has upgraded hpfp, cobb cai, cobb bov, CS cat back, CS race pipe, Cobb AP V3
Thanks
06 Speed6
White/Black interior
Sure Diff Mounts, JBR Intake, JBR I/C Hoses, Wiesco pistons .5mm over, Molnar H-Beam Rods, King bearings, New to me Cylinder Block, CS turbo, CS catted turbo back exhaust, CS HPFP, CS EBCS, CS injector seals, AP v3, FREEKTUNE, rebuilt clutch from Falcon Clutch with kevlar lining, DM PCV plate, DM stage 1 OCC, EcoBoost oil pump, vented oil cap with baffle, Speed Solutions PTO bearing caps, All Damond mounts
To think... this is suppose to be my winter car... because,
'72 AMC Javelin AMX 366 CI, 4speed 13.13 quickest 1/4 mile et so far
'12 1/2 Triumph Daytona 675R stock some how
'79 AMC Spirit AMX, 4.6L stroker I6
LenSpeed6 is offline   Reply With Quote
 Old 09-15-2017, 08:02 AM   #2
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
Originally Posted by LenSpeed6 View Post
hi all,
Thanks
+1 for CS downpipe. I like mine.
Several people here have had luck with the eBay downpipe.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 09-15-2017, 08:47 AM   #3
Djohns's Avatar
Posts: 3,944   (View Stats)
I don't like the cs downpipe because of its stupid divorced design. Restricts flow a lot. I guess it's all fine and dandy if you don't plan on making a lot of power.
2010 black mica speed3
Soon:built motor
 Old 09-15-2017, 08:49 AM   #4
Fstrnyou's Avatar
Obviously, because I bought it from you. Ha. I plan on keeping it mild...for as long as I can stand it.
Other rides:
History:
 Old 09-15-2017, 08:50 AM   #5
Djohns's Avatar
Nope. I didn't sell you a downpipe, I've never sold one lol.
Soon:built motor
 Old 09-15-2017, 10:22 AM   #6
Fstrnyou's Avatar
DOH! wrong D. It was daveychronic.
Other rides:
History:
 Old 09-15-2017, 04:13 PM   #7
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
Go CPE catted DP. Its what I run. Nicely crafted.
 Old 09-16-2017, 08:10 AM   #8
LenSpeed6's Avatar
thanks for the suggestions guys, ill see what he wants to do. plus ill know what i might want to do if i go this route too haha
06 Speed6
 Old 09-16-2017, 09:26 AM   #9
LenSpeed6's Avatar
so it would seem that most vote for a bell-mouth down pipe vs a divorced?
06 Speed6
 Old 09-16-2017, 11:19 AM   #10
Djohns's Avatar
Absolutely. Also, why are you asking for your friend? Why doesn't he just make an account?
Soon:built motor
Thepedigree13 (09-17-2017)
 Old 09-19-2017, 06:37 AM   #11
LenSpeed6's Avatar
donno if he does or not, im normally the friend that researches stuff for everyone haha
06 Speed6
 Old 09-19-2017, 07:58 AM   #12
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,992   (View Stats)
Groans: 546
Ebay, 100 percent.
94 M
MS6
IS350
 Old 09-19-2017, 09:07 AM   #13
Dennisms3's Avatar
Posts: 198   (View Stats)
Dennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant future
Get a manzo downpipe from eBay ~150$. Iv been running mine for a little over 2 years without a single issue. Fits perfect! Also my friend is running same one without issues. Plus it's only a pipe that goes after the turbo so it pointless spending 300$+ on a pipe put the money somewhere else that matters.
Bexar likes this.
Dennisms3 is offline   Reply With Quote
 Old 09-19-2017, 09:34 AM   #14
Bexar's Avatar
Posts: 195   (View Stats)
Bexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to behold
Groaned at 18 Times in 8 Posts
My thoughts entirely...as long as the ebay fitment is 100%
Cobb: APV3, shiftknob, TIP Corksport: intake, SSP, HPFP, strut tower bar, hoodscoop
JBR:
rear sway bar + big brackets, recirc hose, shifter bushings CP-E: stage 2 RMM GFB: blow off HKS: filter
To install: downpipe, Damond EGR delete
Bexar is offline   Reply With Quote
 Old 09-20-2017, 06:22 AM   #15
GroceryGtr's Avatar
Posts: 472   (View Stats)
I'm running the m1 style from ebay. The long version SS 3", came with the turbo adapter to v-band. Had to take a hammer to the area right by the drive shaft coupler to make some extra room via some strategic dents, but otherwise it fits great. Gave me tons of extra room, price was cheap, quality was oddly enough great, and other than a small dent by the DS it was a breeze to do. I see no reason to spend 4-5 times the cost for a name brand one.
 Old 09-20-2017, 06:34 AM   #16
LenSpeed6's Avatar
how about a catted pipe? just to curb any BS from MassDOT
06 Speed6
 Old 09-20-2017, 07:13 AM   #17
KiwiFlavor's Avatar
Posts: 2,447   (View Stats)
Catted pipe will rob a few HP. But, it's better than not passing the inspection lol. Where are you in Mass?
2012 NASA Spaceship Gray MS3
 Old 09-20-2017, 12:59 PM   #18
Groans: 211
Well if MassDOT is like California any aftermarket cat will also be illegal. Hopefully not. If that's the case only reason to run one is if you REALLY care about trees and baby pandas.
Here in Cali it must have an EO (executive order) number/stamp.
Fortunately my smog tech turns a blind eye. Shhh.
KiwiFlavor (09-21-2017)
 Old 09-21-2017, 06:31 AM   #19
LenSpeed6's Avatar
western mass, northern berkshires
figured it would be better if anybody asked... we could say hey! its got a cat! honestly i dont care, i have a 72 Javelin AMX with no cats that gets 12 mpg highway...
06 Speed6
The Following User Says Thank You to LenSpeed6 For This Useful Post:
 Old 09-21-2017, 08:09 AM   #20
KiwiFlavor's Avatar
Unfortunately Mass requires all the inspection stations to have cameras installed in their shop.... so they won't be able to hook u up anymore.
 Old 09-21-2017, 08:10 AM   #21
MSMS3's Avatar
Posts: 2,826   (View Stats)
Be sure to get one with a raised sensor bung and a cast bellmouth design. The raised bung will reduce or totally eliminate the CEL. The cast bellmouth allows the hot gas to expand and cool a bit before entering the main 3" section.
I went with the more expensive TurboXS catless dp/rp. Fit is flawless. Materials are first class. I've been running it for eight years. No leaks, no rattles, no interference, no corrosion or rust.
 Old 09-21-2017, 09:05 AM   #22
Bexar's Avatar
I've got one sitting in my room to install, now I really want to put it in
JBR:
 Old 09-21-2017, 09:37 AM   #23
Fstrnyou's Avatar
Yay for SC being a non-inspection state. When I went catless, I just chopped the wire off my downstream O2 and used it to plug the hole. And obviously disconnected the pigtail from the main harness. And obviously disabled the code.
Other rides:
History:
 Old 09-21-2017, 09:59 AM   #24
LenSpeed6's Avatar
they dont take pictures of under the car...
you got a MS3 or 6?
06 Speed6
Thor Hammer (09-21-2017)
 Old 09-21-2017, 09:59 AM   #25
Groans: 211
That's insane! Wow, cameras? I sure hope they don't require that in Cali anytime soon!
 Old 09-21-2017, 11:05 AM   #26
Bingo's Avatar
Posts: 740   (View Stats)
Groaned at 9 Times in 7 Posts
Well I'm selling a CP-E catted DP (which is a cast bellmouth). I would be using it if my engine weren't vommiting all over itself right now.
Things that matter: CS "Stage 2" SRI/TIP, CS TMIC, AT HPFP, JBR 70 duro RMM, Stratified OTS +, Koni FSD's, Whiteline endlinks.
Things that don't: Gen Pu wheels, CPE center pod with Prosport boost, OP, and OT gauges, Eonon G9151A.
The Following User Says NO Thank You to Bingo For This Un-useful Post:
Pu Manchu (09-21-2017)
 Old 09-21-2017, 09:13 PM   #27
MSMS3's Avatar
you got a MS3 or 6?
Gen 1 MS3 as in sig below.
 Old 09-21-2017, 10:44 PM   #28
Pu Manchu's Avatar
Groans: 546
sigs don't always show up on mobile. turboxs doesn't have a ms6 dp, but if they did it would be made in china and cost twice as much as ebay.
94 M
MS6
IS350
 Old 09-22-2017, 10:49 PM   #29
MSMS3's Avatar
Please disclose your source on country of origin on the TurboXS dp. Sorry they do not make a MS6 version.
 Old 09-23-2017, 12:44 AM   #30
Djohns's Avatar
Bexar likes this.
Soon:built motor
 Old 09-23-2017, 06:16 PM   #31
Pu Manchu's Avatar
Groans: 546
i wasn't implying that it would be a bad part if they made it in china, just that they'd mark up the price on a low production run. there's a reason simple parts off ebay are popular.
if you're really interested, there are companies that aggregate supplier data, lookup TURBOXS LLC, and make of it what you will.
94 M
MS6
IS350
The Official Downpipe/Test Pipe/Race Pipe Thread MS3-a(sore)ASS-rex Mazdaspeed3/6 General Discussion 415 02-06-2020 08:55 PM
The Official Downpipe/Test Pipe/Race Pipe Thread MS3-a(sore)ASS-rex MSF KB - Mazdaspeed 3/6 - Engine, Transmission & Driveline 95 09-20-2012 05:58 AM
Page generated in 0.51343 seconds with 30 queries
