 Old 11-26-2013, 06:42 AM   #1
almcbs's Avatar
Posts: 267   (View Stats)
almcbs has a reputation beyond reputealmcbs has a reputation beyond reputealmcbs has a reputation beyond reputealmcbs has a reputation beyond reputealmcbs has a reputation beyond reputealmcbs has a reputation beyond reputealmcbs has a reputation beyond reputealmcbs has a reputation beyond reputealmcbs has a reputation beyond reputealmcbs has a reputation beyond reputealmcbs has a reputation beyond repute
Default DP finally installed
Finally after 2 rounds i was able to get the DP installed!!!
1st round we got everything off the car and ran into a issue with the O2 sensors being seized. After breaking the secondary O2 we decided to throw everything back on until i order new sensors since i didnt want to risk breaking the primary, which prob would of happened if not stripped it.
2nd round and after 2 weeks of my car sounding like a loud ass subi, we went back at it again. After 1 attempt at undoing the O2 sensor and it not budging, we decided to fuck the O2 sensor and just take a hacksaw to the heat shield. Everything after that was pretty much smooth sailing thanfully, even the flange bolts came out with a little finesse. Everything was going good up until the damn flebay vband clamp broke that came with the DP. Thankfully one of the members (do not know there name on here) from my Nator VA family came to the rescue with a extra vband. So out in the freezing cold we were able to get the vband on and everything secured. We forgot to put the heat shiel back on for the alternator, hopefully that wont cause any issues, and even after doubling up on gaskets i still have a exhaust leak where the DP bolts to the catback. Does anyone have a solution to this?
Big thanks to everyone in Nator VA that came out to give me a hand with the install, i couldnt have done it without you guys and gals!!
07 Speed6
ETS TMIC | HTP 3" Intake | Turboxs Hybrid BOV | JBR RMM | Ralco RZ STS | CP-E Triple Dash Pod | Prosport Gauges | Bilstein HD Shocks | H&R Springs | SPC Adjustable Ball Joints | Corksport Strut Bar | CP-E Diff Mount | Whiteline RSB | Autotech HPFP | Cobb AP V3 | M2 DP | PU Rims | Unicorn Jizz | Rotella T6 Blood
Next to come : ???????????
almcbs is offline   Reply With Quote
The Following User Says Thank You to almcbs For This Useful Post:
stanley0910 (11-26-2013)
 Old 11-27-2013, 08:38 PM   #2
sleeperstang1994's Avatar
Posts: 569   (View Stats)
sleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the world
Groaned at 7 Times in 5 Posts
glad to hear you got everything together. The constant heat cycles on the O2's makes them a real bear. well done!
sleeperstang1994 is offline   Reply With Quote
 Old 11-27-2013, 08:55 PM   #3
jk_ms3's Avatar
Posts: 1,390   (View Stats)
Groans: 40
Dp's on a speed6 tend to be a big pain in the butt. Congrats on the install.
On deck: VG Sharkfin Antenna
 Old 11-29-2013, 11:47 AM   #4
Cheeto's Avatar
Posts: 762   (View Stats)
Cheeto is the leader of the worldCheeto is the leader of the worldCheeto is the leader of the worldCheeto is the leader of the worldCheeto is the leader of the worldCheeto is the leader of the worldCheeto is the leader of the worldCheeto is the leader of the worldCheeto is the leader of the worldCheeto is the leader of the worldCheeto is the leader of the world
Check to make sure your DP and catback are all 3in. My DP was 3 and catback 2.5 at first but now I am all 3in.
Sent while playing boner leap frog.
Chad Erwin -ATX
06 MazdaSpeed6 Gt AWD/Turbo/#5994
MODS:
COBB AP // MSD Dashhawk // Street Unit TMIC // Street Unit Test Pipe // CorkSport Power Series Catless DP // COBB SRI intake // Speedies TIP // Turbosmart BOV // RPM Street Spring // Bilstein Struts/Shocks // TWM Stage 2 Short Shifter // CPE Dogbone rear mount // CPE JuggerNaught Diff mount // COBB Shifter weight // HPFP Internals // Magnaflow FULL 3IN Back// Denso ITV 22s // Full TIGS // EGR Delete // Shorty Antenna // PA Engineering OCC // LED swap
Cheeto is offline   Reply With Quote
 Old 11-29-2013, 06:25 PM   #5
almcbs's Avatar
if it wasn't for the O2 sensors then it wouldn't have been to bad. I still have the factory cutback so its def not 3 inches.
I unfortunately am not suffering from smoking turbo syndrome. 110k miles so i guess its to be expected, time to turn up idle some and start saving for a bnr upgrade
07 Speed6
 Old 01-12-2014, 03:57 PM   #6
cocoleveo7686's Avatar
Posts: 238   (View Stats)
cocoleveo7686 is a name known to allcocoleveo7686 is a name known to allcocoleveo7686 is a name known to allcocoleveo7686 is a name known to allcocoleveo7686 is a name known to allcocoleveo7686 is a name known to all
Groaned at 34 Times in 21 Posts
Did you notice any gains in performance?
cocoleveo7686 is offline   Reply With Quote
 Old 01-12-2014, 05:36 PM   #7
@almcbs; I know this is old but you should definitely consider putting the alternator heat shield back on. I'm assuming you have the ebay downpipe and I really don't like how close it runs to the alternator.
 Old 01-12-2014, 06:45 PM   #8
memin's Avatar
Posts: 994   (View Stats)
almcbs; question how did you solve the leak problem in your exhaust???
 Old 01-12-2014, 07:02 PM   #9
As for the leak at the downpipe to catback try a good quality gasket with some RTV on it to seal it and let it cure before starting the car.
If you're asking about the vband try this
Amazon.com: Vibrant 1491C Stainless Steel Quick Release V-Band Clamp: AutomotiveAmazon.com: Vibrant 1491C Stainless Steel Quick Release V-Band Clamp: Automotive
memin (01-12-2014)
 Old 01-12-2014, 08:24 PM   #10
memin's Avatar
good info!!! so in resume you just use a single gasket on the downpipe--stock cat back connection??? sorry but I am kind of slow and I am planning on tagging this task sooon I want it to go down smoothly..
 Old 01-13-2014, 05:30 AM   #11
almcbs's Avatar
i def plan on it, I already have a vibrant vband and picked up 2 gaskets for the catback side just been waiting for it to get a little warmer outside. I do have my dp wrapped but i too def dont like how close it sits to the alt so i will be throwing that shield back up there.
I have two gaskets on there now (the one that came with the dp and one i made from exhaust gas material) but it is still leaking. I plan on putting two new gaskets on there with some rtv as well and pray that it doesnt leak this time
yes i can def feel the gains and im sure once i get it tuned it will feel much better. plus i love the sound of the dp with the stock exhaust.
07 Speed6
Last edited by almcbs; 01-13-2014 at 05:30 AM. Reason: MSF Database - Automerged Doublepost
The Following 2 Users Say Thank You to almcbs For This Useful Post:
Mazdazilla6 (01-13-2014), memin (01-13-2014)
 Old 01-12-2014, 09:48 PM   #12
Yes one gasket should do. I guess you could do two but one with RTV should be fine.
Finally installed my Nextmod lip Hectik1 MazdaSpeed 3/6 - Appearance 11 04-08-2012 06:56 PM
finally installed my downpipe Kx450f24 Gen2 MS3 General Discussion 18 04-04-2012 08:43 AM
finally installed rgvms6 Mazdaspeed3/6 General Discussion 38 03-06-2012 09:59 AM
So, I finally got my CP-E DP installed WorstEpEver MazdaSpeed 3/6 - ECU Computer Tuning 26 08-06-2011 12:11 PM
Page generated in 0.34821 seconds with 26 queries
