 Old 02-16-2009, 08:27 PM   #1
asiandude74's Avatar
Posts: 276   (View Stats)
asiandude74 is the leader of the worldasiandude74 is the leader of the worldasiandude74 is the leader of the worldasiandude74 is the leader of the worldasiandude74 is the leader of the worldasiandude74 is the leader of the worldasiandude74 is the leader of the worldasiandude74 is the leader of the worldasiandude74 is the leader of the worldasiandude74 is the leader of the worldasiandude74 is the leader of the world
Default downpipe problem
Hey guys I just installed my downpipe and I started the car and it idles for a few seconds then it starts hiccuping and stalls. I dont know whats wrong. I checked the intercooler tubes and everything.
any help is appreciated
Thank You
-Dan
asiandude74 is offline   Reply With Quote
The Following User Says NO Thank You to asiandude74 For This Un-useful Post:
 Old 02-16-2009, 09:02 PM   #2
danesti's Avatar
Posts: 4,186   (View Stats)
Groans: 137
warm it up and see whats happens.
mine did the same thing at first, but then i said fuck it and went for a drive and by the time my car was warm it was fine.
2008 STi
Intake
Turboback
AP
The Following User Says Thank You to danesti For This Useful Post:
asiandude74 (02-16-2009)
 Old 02-16-2009, 09:19 PM   #3
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
r u sure u put everything back ok? did anything pop off?
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
 Old 02-16-2009, 09:31 PM   #4
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
i sprayed some of that copper gasket shit at the DP/turbo connection...guess i sprayed too much.....eh prob not the best idea, my car idled like shit and smoked a whole bunch for like 10 mins. Did you use anything like that?
 Old 02-16-2009, 09:35 PM   #5
i did i used pb blaster,but there was no smoke that i saw and it stalled twice when i started it up.
im pretty sure except my friend broke the bpv to cold pipe bolt and i had to use zip ties. I dont know if that would be the problem.
 Old 02-16-2009, 10:10 PM   #6
kingpin748's Avatar
Posts: 2,611   (View Stats)
Groans: 78
Did you reset the ECU? Would that screw it up?
In reality I love lenny
kingpin748 is offline   Reply With Quote
The Following User Says Thank You to kingpin748 For This Useful Post:
 Old 02-16-2009, 10:12 PM   #7
Yeah i unplugged the negative before install.
 Old 02-16-2009, 10:20 PM   #8
jayspeed3's Avatar
Posts: 356   (View Stats)
jayspeed3 has a reputation beyond reputejayspeed3 has a reputation beyond reputejayspeed3 has a reputation beyond reputejayspeed3 has a reputation beyond reputejayspeed3 has a reputation beyond reputejayspeed3 has a reputation beyond reputejayspeed3 has a reputation beyond reputejayspeed3 has a reputation beyond reputejayspeed3 has a reputation beyond reputejayspeed3 has a reputation beyond reputejayspeed3 has a reputation beyond repute
Groans: 60
+1, always remove the negative side.
jayspeed3 is offline   Reply With Quote
The Following User Says Thank You to jayspeed3 For This Useful Post:
 Old 02-17-2009, 12:29 AM   #9
bykeryder4life's Avatar
Posts: 1,032   (View Stats)
Groans: 38
my car didnt stall when I put a dp on and then started it, check over everything front to back that you had taken off. O2 sensors should be in place, hooked up to the car. the top one should be in the bung closest to the firewall if your DP has two bung-holes (beavis and butt-head). If you took any intake and intercooler stuff off check it again, and get a new bolt for the BOV so you dont get a vac leak which would make a rough idle maybe stall. Do you have any CEL's?
bykeryder4life is offline   Reply With Quote
 Old 02-17-2009, 12:32 AM   #10
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
hahahahaha
no one read that he's holding his valve on with a zip tie?
go get a fucking bolt and report back
danesti (02-17-2009)
 Old 02-17-2009, 01:01 AM   #11
mexicant's Avatar
Posts: 867   (View Stats)
mexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the world
Groans: 147
Groaned at 34 Times in 29 Posts
boost leak. . .
vacuum leak.. . . . . .
fuck off, its the same thing got ot fucking bed you fuckfffs and welches graep juices
"08, I hate to break it to you, but if it gives kevin a boner, its porn"
NATOR PERFORMANCE
Nylon washer sponsered
mexicant is offline   Reply With Quote
 Old 02-17-2009, 01:05 AM   #12
mexicant's Avatar
Groans: 147
get sme kraft sangles
NATOR PERFORMANCE
 Old 02-17-2009, 02:19 AM   #13
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
You zip tied you bov on?
I dont need to say anymore.
2006 Mazdaspeed 6
 Old 02-17-2009, 06:32 AM   #14
I thought it would work temporarily, but i guess not. Ill just get a bit extractor and a new bolt and ill report back. I hope it is the bpv.
 Old 02-17-2009, 09:44 AM   #15
phillyb's Avatar
Groans: 1,940
it could be the leak caused by the zip tie. that's what i was eluding to. please get that shit fixed and report back
asiandude74 (02-17-2009)
 Old 02-17-2009, 09:56 AM   #16
phantom3's Avatar
Posts: 1,223   (View Stats)
Groans: 190
IF the BPV is not sealed correctly due to the bolt breaking off and leaking air into the system post MAF, then at idle your running uber lean causing it to stall. Replace the bolt, reset the ECU again, and then i bet your problem goes away.
My mission is to go fast.
Currently Designing:
The golden girdle of the gods
The CF "fuck your face" IM
phantom3 is offline   Reply With Quote
The Following 2 Users Say Thank You to phantom3 For This Useful Post:
aaronc7 (02-17-2009), asiandude74 (02-17-2009)
 Old 02-17-2009, 10:56 AM   #17
aaronc7's Avatar
Groans: 370
yeah i missed the whole ziptie thing...haha. fix that
 Old 02-17-2009, 11:25 AM   #18
aspiring turbo guru
08_ms3_gt's Avatar
Posts: 1,040   (View Stats)
you mean to tell me that a zip tie can't offer the torque-down capability of a 10mm bolt? god what is the world coming to.
OP - get it fixed, odds are your issues will go away. you might as well double-check your other clamps to make sure they're tight as well, since even a legit clamp that is loose will cause a boost leak.
08_ms3_gt is offline   Reply With Quote
The Following User Says Thank You to 08_ms3_gt For This Useful Post:
 Old 02-17-2009, 11:53 AM   #19
UltimateWhiteGuy's Avatar
Posts: 197   (View Stats)
UltimateWhiteGuy has a reputation beyond reputeUltimateWhiteGuy has a reputation beyond reputeUltimateWhiteGuy has a reputation beyond reputeUltimateWhiteGuy has a reputation beyond reputeUltimateWhiteGuy has a reputation beyond reputeUltimateWhiteGuy has a reputation beyond reputeUltimateWhiteGuy has a reputation beyond reputeUltimateWhiteGuy has a reputation beyond reputeUltimateWhiteGuy has a reputation beyond reputeUltimateWhiteGuy has a reputation beyond reputeUltimateWhiteGuy has a reputation beyond repute
Hi, my car is running funny. I replaced some botls with zip ties. Any ideas on what could be causing the problem?
I've got a belly full of white dog crap, and now you lay this shit on me?
UltimateWhiteGuy is offline   Reply With Quote
The Following User Says Thank You to UltimateWhiteGuy For This Useful Post:
martyxattack (02-17-2009)
The Following User Says NO Thank You to UltimateWhiteGuy For This Un-useful Post:
 Old 02-17-2009, 12:22 PM   #20
wisniaPl's Avatar
Posts: 933   (View Stats)
wisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond repute
not funny at all.... if you dont have anything smart to say shut the fuck up and leave
wisniaPl is offline   Reply With Quote
The Following User Says Thank You to wisniaPl For This Useful Post:
 Old 02-17-2009, 01:01 PM   #21
Meow!
 Old 02-17-2009, 01:21 PM   #22
y2kc0wb0y's Avatar
Posts: 808   (View Stats)
y2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the world
Good read
y2kc0wb0y is offline   Reply With Quote
The Following User Says Thank You to y2kc0wb0y For This Useful Post:
 Old 02-17-2009, 01:23 PM   #23
danesti's Avatar
Groans: 137
haha....
a rare one for me
+1...
sorry white guy.. you killed that one.. no need to beat a dead horse
2008 STi
Intake
Turboback
AP
 Old 02-17-2009, 01:37 PM   #24
SneakyP86's Avatar
Posts: 1,162   (View Stats)
Hey man I had to use duct tape my HKS on for a couple days when it blew off and I had to get a new Oring and it worked fine.Dont want to have to do it again but it worked.
The Following User Says Thank You to SneakyP86 For This Useful Post:
 Old 02-17-2009, 04:11 PM   #25
I got it to run it was the bpv. Just had to use vise grips to get that stud out. Thanks guys.
Also another question, my vaccum when i first started it up it was jumping to 10 then back down then back up. Is this a problem? It seems when warmed up it doesnt do it but cold starts before dp never did that.
The Following User Says Thank You to asiandude74 For This Useful Post:
magoo (02-22-2009)
 Old 02-17-2009, 04:15 PM   #26
you were running rich since you are losing metered air and that's why you were stalling. If it ran long enough, you'd get a fault code.
after a few seconds idling the vacuum should be constant.
 Old 02-17-2009, 04:23 PM   #27
SneakyP86's Avatar
Did you reset your ECU this time if not try doing that.It needs to relearn again,it will take a few cycles of the key for it to be normal (or as normal as this car gets).
 Old 02-17-2009, 04:27 PM   #28
I need to reset the ecu again? I resetted it before and after I installed the dp
 Old 02-17-2009, 04:29 PM   #29
phantom3's Avatar
Groans: 190
at idle he would be in vacuum (gaining unmetered air), and running lean.
 Old 02-17-2009, 04:30 PM   #30
phantom3's Avatar
Groans: 190
Anytime you change something on the car that the ecu deals with you need to reset it. If your not sure reset it anyways.
It doesn't hurt to reset it again.
The Following User Says Thank You to phantom3 For This Useful Post:
 Old 02-17-2009, 05:33 PM   #31
aspiring turbo guru
08_ms3_gt's Avatar
is it necessary to reset the ECU or just baby it for ~50 miles until the LTFT's reach their new values? i swapped from Forge BPV to stock, i didn't reset the ECU but my LTFT's were holding steady @ adjusted values after ~50 miles (and a bunch of key cycles).
 Old 02-17-2009, 05:39 PM   #32
phantom3's Avatar
Groans: 190
Why chance anything going wrong? This car is pretty picky. I always reset.
 Old 02-17-2009, 06:00 PM   #33
hey guys thanks for the help it seems to be going good now. Now im just gonna drive normally and in a few miles im gonna go crazy! lol
 Old 02-17-2009, 06:45 PM   #34
phillyb's Avatar
Groans: 1,940
good shit man. glad you got the help you were looking for. now the next time some idiot zip ties his valve to the cold pipe and stalls, at least he can search for this fail thread...
hahahahahaha...
i'm just being an ass...you live and learn. and trust me, i've fucked up almost every single install on my car.
 Old 02-17-2009, 07:01 PM   #35
MS6_Auburn_Fan's Avatar
Posts: 481   (View Stats)
This is true. I know from experience after I installed the c-ring on my HKS upside and it blew off on my way to work. I drove to work and back at about 35 mph staying out of boost. When I would stop the AFRs would be down in the 9s sometimes lower and would try to stall the car out.
SneakyP where did you find a replacement o-ring? Were you able to find it at the hardware store or did you go to autozone?
MS6_Auburn_Fan is offline   Reply With Quote
 Old 02-17-2009, 07:02 PM   #36
hahahahahaha...
Haha i dont mind, now i wont try to half ass it to get it running because of this.
 Old 02-17-2009, 07:06 PM   #37
SneakyP86's Avatar
Well I cut out a rubber gasket out of a old innertube and got by using that.Until I got in touch with corksport and they got me one.
 Old 02-21-2009, 09:05 PM   #38
ZoomMS3's Avatar
Posts: 94   (View Stats)
ZoomMS3 has a spectacular aura aboutZoomMS3 has a spectacular aura about
lol... that bolt was defintially your problem.
On motor #3
Turbo #2
Now have a SSM 08 STi!!
ZoomMS3 is offline   Reply With Quote
 Old 02-22-2009, 03:51 AM   #39
Speeeeeed
06Speed6's Avatar
Glad you got it working bro.
2006 Mazdaspeed 6
asiandude74 (02-22-2009)
WTF Catless CEL problem, yea just look anyway superskaterxes MazdaSpeed 3/6 - ECU Computer Tuning 32 05-01-2011 03:43 PM
Corksport Downpipe Installation problem ItalianSA MazdaSpeed 6 - How-To's 32 03-28-2011 06:43 PM
devils own problem!!! help!! samsel450r MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 6 02-10-2009 12:33 AM
Lights problem. Demi MazdaSpeed 3/6 - Troubleshoot/Diagnostics 3 12-15-2008 10:53 PM
Page generated in 0.54850 seconds with 38 queries
